40,556 Members 1,516,192 Posts
Engine Oil Pressure Warning Light
This is a discussion on Engine Oil Pressure Warning Light within the Fabia I forums, part of the Skoda Model Discussion Area category; Hello again all. Cheerfully driving our Fabia 1.4 Classic around this afternoon and, nearning home, the Engine Oil Pressure warning ...
Old 01-05-2005, 22:27   #1
Hello again all.
Cheerfully driving our Fabia 1.4 Classic around this afternoon and, nearning home, the Engine Oil Pressure warning light came on with a loud beep. Only a mile home so - despite the "don't go any further whatever you do" alert in the manual - we returned to base with no ill effects.
Let engine cool down and noted no oil loss at all - everything seemed fine. Started up again and, as soon as reaching the end of the road the warning light is one again. Called out rescue service - very helpful chap from On-Time recovery had a look - confirmed no oil loss, looked into the oil filler and noted that the oil pump was clearly pumping oil round and therefore suggested that the oil pressue switch / sender / sensor had probably gone faulty. He suggested it was almost certainly fine to drive to the garage for a fix.
Anyone had any experience of this? Does the diagnosis sound reasonable? (If it is, it would be the third darn sensor that has failed on this vehicle - we've already replaced a power steering angle sensor and a temperature sensor!)
Grateful for any thoughts / suggestions. Would this be an expensive fix, or could it even be DIYed?
Best wishes,
D.
dunder101 is offline
Old 02-05-2005, 09:39   #2
Partner
Lummox's Avatar
Images: 2
Interested in how he could tell the oil pressure is fine by looking onto the oil filter..lol.
I take its a red light coming up on the dash. Personally if its not easy for you to get the oil pressure checked bung a switch on anyhow, should be able to get one from any motor factors. Worth a go.
www.unit18.co.uk
Lummox is offline
Old 02-05-2005, 09:40   #3
Partner
Lummox's Avatar
Images: 2
Addition,
And dont worry about further failures, the other two sensors are pretty common and you should have changed just about all of em now
www.unit18.co.uk
Lummox is offline
Old 02-05-2005, 10:59   #4
Members Car:
Hi
Yes I worked for the warranty dept. for a skoda dealer for 5 years.
The sensors are pretty renowned to go.
I think though the 3 sensors are the most common.
You can usually tell if there is a common fault on them if the old parts have been superceeded.
But after them 3 sensors you should be fine.
The Yaw angle sensor is the most expensive but the oil sensor is not that bad.
But just keep checking the oil level before you drive just to check that all is good.
On the Classics there was a problem with head gaskets though , could be worth checking that.
A call to the dealer should be able to let you know whether this had been done in the past and get it checked.
The front head bolts on a few went through without the correct torque on them.
JBS Auto Design is offline
Old 02-05-2005, 19:21   #5
Thanks
Hello all ...
... this is all very useful. Perhaps Skoda should sell a gift set with the three sensors in it?! Haha.
Anyway, I have delegated getting the car taken to the garage to my wife tomorrow. She had a day off to go shopping, but I think a drive to Sidcup Auto Centre will be a far better use of her time. Haha.
I shall let you all know the official diagnosis.
BTW - do you think cars have feelings? This fault occured as we were coming home from Elmside Garage in Beckenham yesterday having been looking at a rather nice black Octavia 1.9 TDI Elegance which we are thinking of part-exchanging to. I think my Fabia is sulking.
Old 03-05-2005, 11:03   #6
DIY Time
Hello again,
Well - none of our local Skoda garages could do this until late next week, so I have ordered an oil pressure sensor / switch for a few pounds to fit myself (given that this seems to be the likely cause).
I did something like this on my old Favorit some years ago and recall it was just a case of unscrewing the existing one from the engine and then screwing the new one in (+ connecting the lead). Can anyone guide me to exactly where it is on the engine?
Thanks,
D.
Old 03-05-2005, 11:34   #7
"Bones"
flatfourburble's Avatar
Members Car: Fabia vRS
yes I do, my mother just sold her Rover 214, the day before the guy was meant to come a collect the water cooling pipe burst spilling it's guts all over the place I think it was upset about being sold!
Oh to have the internet back..................oh have I missed it
flatfourburble is offline
Old 07-05-2005, 18:13   #8
Success!
It was indeed the oil pressure switch - bought and delivered first class from Butt's of Bawtry for £8.21! Most satisying to have resolved this problem myself - thanks for all your help.
Should anyone encounter the same problem in future and be unsure where the oil pressure switch is located, the photo points it out.
Old 07-05-2005, 18:14   #9
Partner
Lummox's Avatar
Images: 2
Glad you got it sorted an we were of some help to you.
www.unit18.co.uk
Lummox is offline
Old 09-04-2006, 18:39   #10
Ger
Members Car:
Re: Engine Oil Pressure Warning Light
Thanks a million for the info given in the posting above. Had the same problem with the oil light coming on for no apparent reason and changing the oil pressure switch fixed it.
Ger is offline
Old 30-06-2008, 18:21   #11
I'm in the middle of trying to change my oil pressure swicth (appreciate the photo above). Does anyone know how to remove the plastic cap that the wire is attached to? I'm struggling to get it off.
Thanks
itgoodson is offline
Old 30-06-2008, 20:56   #12
Members Car:
I've not looked at this switch, but seeing as most of these sensors have similar connector types, have a look at the new switch and you will probably see protrusion on it for latching the connector onto, if this is so then the connector will have a slightly "flexible" release/locking tag which needs to be eased back as the connector is push further onto the sensor, then while holding this release/locking tag back, just pull the connector off. Obviously the connector just needs pushed on the new sensor until it "clicks" after you have screwed the new sensor in.
rum4mo is offline
Similar Threads
Fabia Power Steering Warning Light ceepan Maintenance & Performance 8 18-02-2005 19:53
Warning Light KentStu Diagnostics & VAG-COM 15 13-01-2005 11:09
Need Oil clv101 Maintenance & Performance 12 25-11-2004 22:54
Modded your Skoda? Some Oil Advice! oilman Maintenance & Performance 82 11-10-2004 12:09
Variable servicing and oil changes SkodiRS Maintenance & Performance 10 29-12-2002 16:35
