Temperature Gauge Fluctuation
This is a discussion on Temperature Gauge Fluctuation within the Fabia I forums, part of the Skoda Model Discussion Area category; Hi There, My Temperature gauge Keeps fluctuating and the engine management light is on...it sometimes just stays in the in ...
Old 22-11-2006, 02:14   #1
Default Temperature Gauge Fluctuation
Hi There,
My Temperature gauge Keeps fluctuating and the engine management light is on...it sometimes just stays in the in the cool end or it will go to mid temp as usual then drop back down again..What could it be.... I'd be most grateful for any advice
Skodainhood is offline
Old 22-11-2006, 07:51   #2
bahnstormer vrs's Avatar
Default Re: Temperature Gauge Fluctuation
What engine have you got?
Could be a stuck, open, theromostat but this ought not to put your engine management light on. May be the temperature sender on the radiator giving false (hopefully) readings.
Have you checked your coolant level; OK? Any signs of leaks?
bahnstormer vrs is offline
Old 22-11-2006, 08:02   #3
Escorted Estate
Certainly would check the fluid levels, and I'd get it checked out asap - it could be nothing serious but you don't want to end up with a messed up (overheated) engine.
Thermostat sure sounds like a great candidate though + low fluid level
WW --->> Project Journal (pic links in first post there)
Fabia vRS alloys for sale incl tyres, spare wheel with tyre + spare tyre - make me an offer via PM
WW_VRS is offline
Old 22-11-2006, 08:47   #4
ASZ Eternal
ap0gee's Avatar
Coolant temp sensor?
(I'm gonna plug my posts for all they're worth! One day they'll get listed on Google )
ap0gee is offline
Old 12-12-2006, 10:56   #5
I had no engine management light showing, but noticed that the engine was taking an age to heat up. A couple of times the needle would flick up to normal and then back to cold again, but that would be it. Took the thermostat out and found it to be IN BITS (!) inside the plastic housing. It was just opening and closing when it please as nothing was really holding it in. Had to get a whole new part (plastic housing included) which cost £35. Could be a problem with older cars, like mine (1.4 MPi, X reg).
Lobes is offline
Old 12-12-2006, 11:07   #6
EXACTLY what happened to mine , '02 reg 1.4mpi 60,000 miles and YES you need the complete houseing with thermostat for £35. Had mine changed a month ago and all running sweetly since.
