Felicia 1.4-16v engine transplant
TeflonTom
Recommended Posts
the wire on the starter is in the wrong place, you've attached it to the casing, so you've created a short circuit. There is a little rubber black cover next to that Yellow wire with the spade terminal, under that cover will be a stud with a nut on there, that cable should be attached there instead, the wire that goes to the alternator should aldosterone be attached there too.
Link to comment
Share on other sites
Put the wire in the correct place tonight, checked everything over and connected the battery, was fine. So thought id see if it would start, turned the key and it started first time! I am very pleased with this, only a few things left to sort out now and it will be finished. Warmp!
  • Like 1
Link to comment
Well i think we may have fooked it! Went to start the engine again and the belt slipped across the top of the cams, tensioner was the cause, anyhow we tried to set the cambelt back up but the bottom end wouldnt go into tdc, took all the spark plugs out and spark plug number 1 looks like it has been struck by the piston, but all the rest were fine, so looks like taking the head off to inspect damage :( guessing the valves will be bent and the reason it wont go to tdc?
Will we have to replace the headbolts for new ones again or can we re-use?
Link to comment
I know, im gutted as it was nearly finished.
Im not too sure what made it come loose tbh, the belt was nice and taut, admitedly we didnt use a new tensioner so maybe it was knackered. If its just a few valves that have been hit would you say replace just those or all? Or just get a new head?
Link to comment
Depends how bad it is, you should be able to see the valves that have been touched by the pistons, it will more likely be the intake valves that are worse.
Whip the head off and have a look.
Link to comment
Yeah will do, probs be sunday. I would probably opt for a new head tbh because i dont think i have the skills to change valves, unless im thinking its more complicated than it is
Link to comment
Took the head off today and as expected the valves are bent, two of them are actually smashed to bits.
The number one piston has some marks on it which look pretty rough but not that deep, would that be ok to go again or is it no good?
Edited by nu99et18
Link to comment
That cylinder head is scrap, looks like one of the valve seats is damaged.. That piston will live again though, just clean it up and jobs a gooden... That engine is burning oil though I would say judging by the marking round the edges of the piston crown.
Link to comment
If im replacing piston rings i may aswell swap the avy internals into the afh block hadnt i?
What new parts are required when doing this? Or can i re-use the lot?
Link to comment
  • 2 months later...
  • 2 months later...
I don't think it mentions in the guide that VW Polo and Skoda Felicia Oil pressure switches work the opposite way round to each other.
So you need an AEE 1.6 Skoda Oil switch to put in your 16V.
If you don't use a Skoda one the oil pressure light stays on. It is mentioned by Teflon Tom  somewhere else on here so I didn't panic when it happened to me today!
Link to comment
  • 11 months later...
  • 6 months later...
i got some timing belt covers from a seat ibiza 1.4 16v (also with AFH engine code), although the engine code is the same in the seat ibiza version, the belt covers are different in this car becuase the ibiza has no engine mounting on the timing belt end of the engine. i cut a hole in the lower section of the cover to let my custom mount stick through.. good times emoticon-0148-yes.gif
it's certainly a lot neater than the last one i made emoticon-0136-giggle.gif there is still an inner cover missing that i need to put on first before the timing belt etc, unfortunately it's on back order at the dealer
still in need of 2 parts to finish this off
1. felicia 1.6 petrol flywheel
2. alternator
i've decided to freshen up the gearbox a little too, going to steam clean it, and replace all the oil seals, and fit a new clutch release sleeve.. and put a new mounting into the end casing whilst it's all out emoticon-0112-wondering.gif
Sorry to revive a very old thread but this is just what I'm looking for, don't suppose you can remember a rough (I know it was a loooong time ago but) cost on this can you or have any part numbers anywhere?
Link to comment
Found part numbers for this done a lot of ringing around today and struggling to find now, most dealers saying discontinued!!!!! NOOOOOOOOOOOOOOOO :'(
Link to comment
  • 7 years later...
Hey
Im looking for more power on my Fun, its a 1.6.
Granted I dont understand much of the technical stuff mentioned here but I know I have most of the parts I since its a 1.6 right?
I dont think I can buy 2 engines to make this build (to expensive) so my question is what engine is the most straight forward swap?
If I buy the AFH I on only need to build the mount right?
If I buy the AVY stuff gets more complicated because of the IMMO right?
Sorry but this topic got way to complex :)
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
