• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Where to install gps antenna?
Sign in to follow this
Followers 0
5 posts in this topic
I'm about to install a new headunit with gps in my octavia. The gps antenna. Is there a particular place in the octavia where it'll get good reception? It'll have to go somewhere in the dash as the cable comes out the back of the hu but I'm sure there must be others on here who have done the same.
Share this post
Link to post
Share on other sites
I have not had a problem with any gps item in mine. O2 orbit works fine in holder etc.
You should be able to put anywhere if equipment is good:thumbup:
Share this post
Link to post
if its to do with the octy mk1 then i have put mine under the glove box under the dash on a pice of metal pole that runs along the dash! but!! i have been looking into relocating it to the roof with one of those shark fin areials cause there so big you can hide the attena under them and i think there on a mk5 golf!! of cours i havent had the time or money to complete this so its a working project, but good luck
p.s mine does work fine under the dash
Share this post
Link to post
Mines sits in corner of dash on nearside works fine with MFD Satnav unit:thumbup:
Steve
Share this post
Link to post
I tried it under the dash but i wasn''t massively happy so I've run it from the hu along the dash, behind the a pillar trim and it now sits at the top of the windscreen. Shame I forgot to remove all the cds from the cd changer before I unplugged the original headunit :mad:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
