stupid front window jammed wide open *!@
Basil
Recommended Posts
hot tip:
make sure you are very gentle unclipping the door button bit (the one that goes up and down with the door locking). Do it as soon as you have the door carrier opened up.
Anyone knows if the LED has a fuse? Plugged it in correctly but it's refusing to blink...
Link to comment
Share on other sites
Almost certainly not just for the LED, that fuse would be miniscule - probably around 20 or 40 milliamps :D
Link to comment
sigh - yes I know - have to get out a multimeter and check that its getting its 5VDC and if so it's had it. Otherwise it must have disconnected itself while I was refitting the trim, although unlikely as I know I latched the connector securely...
Still- on the positives - I have a window that works, there's another layer of sound deadening inside the door proper, and I found that one of the capacitors on the X-over had broken its connector. Now soldered up the sound sounds soooo much better....
Link to comment
I added in a layer directly onto the inner metal door skin. Previously there was a layer on the door carrier only. I had half a roll left over from doing the doors, under the hood and the floor some time ago.
Sound insulation on door carrier alone = really noticeable - good
extra inside = even better - it is deffo a noticeable improvement.
I still have some left over material to do the front passenger door but I think I'll put off that project for a manic long weekend where I have nowt to do tbh...
HTH
Bas
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
