New Croatian VRS 236hp 19inches
davojuri
Recommended Posts
Updates in blue
034 motorsport free flowing exhaust manifold
034motorsport Vortex breather kit
034motorpsort fuel pressure gauge
42DraftDesign 3" modular race (decat) ceramic coated downpipe
OE EGT probe from 225hp
Miltek cat back resonated 2.5 inch system
Denso Iridium IK 24 pregapped to 0,024"
Hyperboost adj. DV
Ecotek Emissions Control Valve CB26-P Blue
Piperross Chrome Valve for CB26-P
ECS Tuning Adjustable Fuel Pressure Regulator
ECS Race N75 Frequency Valve 1.8T
ECS Silver Lightweight/Under Drive Pulley Set For 1.8T/2.0
Air intake VDT www.modshack.com
MAF Audi TT 225HP
Air diffusor and 90mm air duct to air box
HKS turbo timer
www.rsrmotorsport.com new custom remap on MAHA LPS 3000
K04-001 turbo,
Siemens Deka 440cc injectors
Large port intake manifold 06A 133 223P
034motorsport Phenolic spacer with transition from large to small port head
Forge FMIC- FMSKOFMIC
Forge TIP FMGOLFIND
Forge Silicon Turbo Hose Kit 1.8T 180 FMKT005
Forge DV relocation kit 150/180hp 1.8T
Forge Quickshifter 5spd FMVAG5QS
Verdict Motorsport Shift Bracket Bushings 42DraftDesign Mk4 & Mk5 Shifter Cable Bushings Fitment Guide
SFS performance custom TIP
LCR (or Lamborghini Galardo) 4bar fuel pump sender unit 8L0919051H (thanks to your site I found perfect match without starvation problems that I had with 044),
Neuspeed 1.8T 180 Degree Thermostat
Neuspeed 180 Degree 3 Pole Fan Switch
Neuspeed Connector Conversion Kit for 3 pole fan switch
Neuspeed Front Anti-Roll Bar 25mm
Neuspeed Rear Anti-Roll Bar 28mm
Neuspeed Lower Strut Brace Billet
APR carbon strut bar
SPEC SV363F Skoda Octavia 1U 97-05 1.8T STAGE 3+ clutch
SPEC SV21S Skoda Octavia 1U 97-05 1.8T STEEL FLYWHEEL
D2racing Track racing coilovers
Ground Control camber caster kit
H2Sport - Sport Spindle H2S1J0407001K
LSD QUAIFE QDF10R
Audi TT bigger tier rods and tie rod ends (16mm thread)
R32 cast control arms with bigger front bushing (OE upgrade)
Powerflex front and rear control arms bushings
R32 steering rack
Powerflex bushing all around
Zimmermann Formula 312mm drilled front discs,
Zimmermann Formula 256mm drilled rear discs
EBC yellow stuf front and rear pads-track tested by myself-great ones
BHP (Brake Hose Production) braided brake hoses front and rear
Mintex racing brake fluid,
Castrol EDGE Sport 10W60 engie oil,
Castrol TAF-X transmission oil,
TWS 8x19 ET35
Falken 215/35/19 F452 outer diameter 24.9" instead of 25.1" for 225/40/18
Bixenon kit 6000K
Painted in red and covered with clear lack rear lights,
Dark grey perforated leather seats and door panel inserts,
SPC Performance Camber and Toe Shims 71520 and 71530.
TyrolSport Brake Caliper stiffenings kit with SS rings snap upgrade Qstarz BT818X 5Hz GPS reciever
02J 6 speed custom made powder coated gearbox with Quaife LSD
Edited by davojuri
Link to comment
Share on other sites
  • 2 months later...
Today arriwed from ceramic coating in Slovenia JBS audtodesign exhaust manifold.
Coating has been aplied in double layer from outside and also double layer from inside
here:
ww.kavsmotorsport.com
only 150eur!!!!.
Mounting today in the afternoon. More pics to come
http://s856.photobuc...ust%20manifold/
emoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gif
Edited by davojuri
Link to comment
tomorrow large port intake manifold together with already present new JBS exhaust manifold and 43DD 3" downpipe with 225hp EGT probe will be put on dyno and EGT connected. First I will measure improwement only gained with JBS and 42DD and than if possible with large port AGU intake mani, and final figureas after adjusting all that.
Will post dyno chart.
emoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gif
Link to comment
Latest news.
Tomorrow we did remove N249, N112, SAI, put Forge blanking plate, conected OE EGT probe to the ECU-hard and technicaly demanding job.
We did that all without putting any resistors-picture to come.
I forgot to take with me my phenoloc spacer-transitional one to accomodate new large port intake manifold to my small port head, so we did just measure horsepower gained with simply bolt on new JBS exhaust manifold and 42 draft design 3" deat downpipe, both ceramic coated.
10.7.2010. I had 243hp, and now without any other mods it measured 269,5 hp and 375Nm on K04-001 only 1.3bar, not to say that turbo is still only 1.3bar because of that silly discharge pipe that slips of due to the ring instead of the clip. So I removed that to, bought pipe and tube from AGU engine-older version but better, no ring but clip holding them together.
So I scheduled 8.1.2011. for new dyno tuning together with large port inlet and software adjustment and I hope to see figures arround 280p for my K04-001!!!!!!!!!!!
So regards to all those telling me that 240-250 is the limit for K04-001.
Will post pictures and dynochart to.emoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gifemoticon-0148-yes.gif
Edited by davojuri
Link to comment
  • 2 months later...
Latest news is my new <STRONG><FONT size=5>02J 6 speed gearbox</FONT></STRONG>, some pics to dcome :-) <BR>and double inner measure bearings from A4 that can sustain more of axial pressure than OE ones, they are 75mm outer diameter instead of 74 OE ones. Can be pulled out of a spindle without breaking them.<BR>Gearbox is calculated to shift at 7200rpm and drops only to 6000rpm where I do have most of torque-pulls like hell.<BR>Pics are here:<BR><A href="http://s537.photobucket.com/albums/ff340/davojuri/02J%206%20speed%20close%20ratio%20synchromesh%20gearbox/">http://s537.photobucket.com/albums/ff340/davojuri/02J%206%20speed%20close%20ratio%20synchromesh%20gearbox/</A> <BR><IMG class=bbc_emoticon alt=:D src="http://ww1.briskoda.net/forums/public/style_emoticons/default/emoticon-0102-bigsmile.gif"> <IMG class=bbc_emoticon alt=:D src="http://ww1.briskoda.net/forums/public/style_emoticons/default/emoticon-0102-bigsmile.gif"> <IMG class=bbc_emoticon alt=:D src="http://ww1.briskoda.net/forums/public/style_emoticons/default/emoticon-0102-bigsmile.gif"> <IMG class=bbc_emoticon alt=:D src="http://ww1.briskoda.net/forums/public/style_emoticons/default/emoticon-0102-bigsmile.gif"> <IMG class=bbc_emoticon alt=:D src="http://ww1.briskoda.net/forums/public/style_emoticons/default/emoticon-0102-bigsmile.gif">
Edited by davojuri
Link to comment
Even still in the wrong section here are the speed ratios of my GREAT NEW 02J 6 SPEED GEARBOX:
1. 3.7
2. 2.2
3. 1.6
4. 1.25
5. 1.04
6. 0.87
Final Drive 3.64
First two remained OE for the comfortable daily driving without killing the clutch and the rest ius killing machine.
It is calculated for shifting on 7200rpm and drops only to 6000rpom where I do have 270hp - meaning pulls like hell all the way.
Edited by davojuri
Link to comment
isuse! Koliko si potrosio na auto boze sacuvaj! lol
Looks great by the way. I'll be driving my MK1 from London down to Zadar this summer.
Pozdrav
Paul
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
