• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
The Law, Regarding Cracked Windscreens?
Sign in to follow this
Followers 0
20 posts in this topic
Hi all, had a little blonde moment tonight.
Basically, ive managed to apply light pressure to the edge of the windscreen. Which in turn shot a crack up about half way along the passenger windscreen wiper blade. And over to the drivers side slightly. Before it stops (It doesn't go past the half way point of the windscreen). It maybe about 1-2inches higher than the dashboard, it doesn't effect my field of view greatly either.
Now this is the point where im up the creak without a paddle, my insurance closes early on a saturday, neither are they open on a sunday.
So im going to have to wait till monday to call them now.
I obviously need the car over the weekend, and cant seem to find any links on google regarding legality of a cracked windscreen.
Can anyone offer any advice or even better a link explaining whats permissable until i get it replaced?
Share this post
Link to post
Share on other sites
Call the glass claims number which will go through to the glass repairer direct usually - you just need your policy details.
Legally you'll be fine as not in the drivers field of view.
Share this post
Link to post
I'll stand to be corrected, but I believe a cracked windscreen is merely an MOT fail. Unless your MOT is tomorrow, you'll be fine to get it fixed at your leisure.
Share this post
Link to post
And if your MOT did happen to be tommorow, taking the screen out would resolve the problem, as no screen = no crack, therfore it couldn't be failed.!
Share this post
Link to post
[quote name='gadgetman']Call the glass claims number which will go through to the glass repairer direct usually - you just need your policy details.
Legally you'll be fine as not in the drivers field of view.[/quote]
Which will probably be on monday now?
Thanks for the input guys :)
Share this post
Link to post
[quote name='Browny_37']Which will probably be on monday now?
Thanks for the input guys :)[/quote]
Depends if your local glass place opens Sunday or has a mobile service.
Who's the insurer stamped on your policy/certificate?
Share this post
Link to post
I drove around with a similar crack in my windscreen but at the top for a couple of weeks. I think it's OK as long as it doesn't extend through the main bit of the windscreen you look through. The bloke at autoglass said it was OK to drive around with it cracked after he looked at it.
Th crack in mine did start to grow though from a inch or so to about 8 over a few days.
Share this post
Link to post
[quote name='Kaiserb_uk']I'll stand to be corrected, but I believe a cracked windscreen is merely an MOT fail. Unless your MOT is tomorrow, you'll be fine to get it fixed at your leisure.[/quote]
If it would fail an MOT then it is technically unroadworthy.
Having said that I wouldn't worry about it too much.
Share this post
Link to post
I've had another look at it and it extends around 4-5 inch above the level of the dash.
Its around 12" in length, start to finish :(
I'm with adrain flux, but its Equity Redstar on the main certificate.
Share this post
Link to post
Its around 12" in length[/quote]
Now who's bragging? :D
Share this post
Link to post
Oouuuer!
And you thought i walked funny because i tore a ligament! :P
I got bored and ragged the radiator grill out and started prepping/priming it haha!
Share this post
Link to post
[quote name='shark_90']Now who's bragging? :D[/quote]
He's talking about his crack though Ben :rofl:
Share this post
Link to post
[quote name='Brimma']He's talking about his crack though Ben :rofl:[/quote]
Ahahahaha! Ya clever crack ;) :rofl:
Share this post
Link to post
[quote name='Browny_37']I've had another look at it and it extends around 4-5 inch above the level of the dash.
I'm with adrain flux, but its Equity Redstar on the main certificate.[/quote]
[B][SIZE=2]Windscreen[/SIZE] [SIZE=2]0870 608 1934[/SIZE][/B]
[url=http://www.equityredstar.co.uk/equityredstar/contactus/claims.jsp]Claims | Equity Red Star[/url]
Share this post
Link to post
Cool, will try in the morning.
I'd have thought i would have had to go through Adrian Flux.
Many Thanks for the help!
Share this post
Link to post
It depends what your policy documents says. Sometimes you have to phone your insurer to get an authorisation code (something the autoglass adverts don't say!!) and then go with their approved repair centre and give the repair centre the code.
Share this post
Link to post
[quote name='Brimma' date='05 September 2009 - 21:26' timestamp='1252185972' post='1745662']
[/quote]
And as thebloke with theBRUMMY accent says is what happens to an overheated chip ."it can't take the temperaturechange" - sounds like siomething to be found on "Act on C02"
Share this post
Link to post
Last November whilst putting my mother car in for MOT, I spoke to the mechanic/inspector about cracks in windscreens. He said if it a curtain size in a specific area (in drivers vision) or if the crack touches more than one side of the screen then it will fail. If it does not do this then it may pass the MOT. In theory you could have one that starts at the bottom and ends nearly at the top, say the sun strip all on the passenger side it will still pass.
I asked this because I had noticed I have a crack just above the tax disc, about the same radius of it that starts at one edge of the screen. I am still going to get it replaced this year anyway, even if it passes an MOT.
Share this post
Link to post
I have just looked it up and I was wrong (and so was he), this site tells you here. [url="http://www.motester.co.uk/CarOwnersGuidetoTheMOT/WhatIsTested.aspx"]MOT Tester.co.uk - What is Tested[/url]
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
