• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Superb oil
Sign in to follow this
Followers 0
61 posts in this topic
Guys recently found a local motor factor called TPS who sold me 5 ltrs of VW507.00 oil for £25. this was way cheaper i found anywhere else.
Then found out Trade Part Specialist (TPS) are in fact owned by VW and offer better prices than GSF ( german sweedish and french) on almost all parts. Worth googling for your own area!!!
Share this post
Link to post
Share on other sites
Good price, personally I think any good grade fully synthetic oil is good enough, I use the GM own brand stuff in mine, 50k on a 100k engine and it's not given any trouble yet, famous last words.
Share this post
Link to post
To be fair, 25 quid for a sumpful is cheap, even compared to non-conpliant oil. I think it's especially important to use the right oil in the PD engines rather than the CR ones...
Share this post
Link to post
Exactly what is the correct grade / spec of oil?
I have a QG1 96KW AWX engine. The book says VW 506 01 or VW 506 00 - does not apply to unit injection engine.???? I feel like the original document was badly translated from chinese or korean...as clear as mud.
What are they on about??? I dont even know for sure whether I have a PD angine or not. Its nowhere in the book or on any stickers. Most forums say the 130bhp is a PDi engine though marked TDi. How can any sane person tell?
Share this post
Link to post
You have the PD (unit injection) engine, which needs 506.00 or 507.00 on variable (QG1) servicing, if I remember rightly...
Share this post
Link to post
[quote name='ap0gee']You have the PD (unit injection) engine, which needs 506.00 or 507.00 on variable (QG1) servicing, if I remember rightly...[/QUOTE]
You can also use VW506.01 for variable servicing. (providing your car isn't fitted with a DPF - which the 130 PD is not)
Share this post
Link to post
Thanks Guys for that. Currently buying my 2nd right front link in 2 years :confused: and figured I would get some good oil also.
Share this post
Link to post
i had a similar prob as the spec in my manual had been superceeded, they replied as follows :
Dear Mr Howe
Škoda Superb 1.9 TDi GN03VRZ
In response to our telephone conversation held 5 August 2009, regarding your vehicle.
I can confirm after speaking with our Technical Support Team, that the correct recommended oil specification for your vehicle is VW 507 00 and VW 506 01 for the variable service regime.
I trust this I have answered your enquiry.
If you require any further assistance please do not hesitate to contact me.
Share this post
Link to post
[quote name='mcsweeney']Exactly what is the correct grade / spec of oil?
What are they on about??? I dont even know for sure whether I have a PD angine or not. Its nowhere in the book or on any stickers. Most forums say the 130bhp is a PDi engine though marked TDi. How can any sane person tell?[/QUOTE]
It's all horse mate, if you go to a VW dealer they have semi synthetic oil that meets the specs, only difference is that it isn't as long life, imo, anyone running oil longer than 12k is a fool, all this was made up so that fleets would only need one serivce in 3 years, there's no magic ingredient, the figures to look for are the viscosity ones, any oil meeting that grade is good enough VAG invented the 500 spec so you will go to them for oil, sadly the likes of Fuchs jumped on the bandwagon also, as long as you change every 10k Castrol GTX will suffice.
Share this post
Link to post
Up to you if you follow that advice, but like I said before, with TPS selling the correct oil at a very good price, it's worth it to know your injectors are protected (which is the key thing with the PD engines...)
Share this post
Link to post
[quote name='ap0gee']Up to you if you follow that advice, but like I said before, with TPS selling the correct oil at a very good price, it's worth it to know your injectors are protected (which is the key thing with the PD engines...)[/QUOTE]
Absolutely, but oil goes on it's viscosity for suitability, VAG has invented it's own spec of oil to confuse ppl into buying their oil only, there's no magic ingredient in 500 spec oils, they are simply good quality oils rebranded.
Share this post
Link to post
Well, that and shear resistance. A semi-synthetic oil like GTX will degrade faster, especially in the high-shear conditions found in a PD cylinder head. It's right enough that regular oil changes will mitigate this, and while I'd cautiously agree that one fully-synthetic 5W-30 is probably the same as the next, I really don't think GTX is a good idea except in an emergency. But you pays your money...
Share this post
Link to post
[quote name='Supurbia']It's all horse mate, ........there's no magic ingredient, the figures to look for are the viscosity ones, [B]any oil meeting that grade is good enough[/B] VAG invented the 500 spec so you will go to them for oil, sadly the likes of Fuchs jumped on the bandwagon also, as long as you change every 10k Castrol GTX will suffice.[/QUOTE]
Plus to name but a few others:
Gulf
Mobil
Castrol
Motul
So you want to use your Castrol GTX, you now have a choice or either 10w-40, 15w-40, both which meet VW505.00 (now i can understand the argument that a certain brand of oil that has not been tested for the VW spec [I]might[/I] possibly be good enough in a PD) but why run an oil that fails to meet the VW507.00 (which BTW is 5W-30) when Castrol make an oil that does? (Castrol Edge 5W-30)
I could try saving money by running Wanli tyres, i mean they are 2/3rds the price of the Dunlops i have bought, they are the same size, meet the same load and speed ratings so they [I][B]MUST[/B][/I] be as good right? :rolleyes: the differance being with normal use i should get another 20K out of a pair of fronts, you however can't wait to wear your Wanli's out so you can change them ;)
I have no issues with [I]anybody[/I] wishing to use non approved parts or oil, i don't think however it's good idea to be recommending others to do it.
The spec's are there for a reason, either take heed of them or take the gamble that your cheaper oil that does not reach the required spec will hopefully be good enough.
Share this post
Link to post
Nope, Wanli are sheet full stop, all I'm saying is oil is oil when it comes to it's branded or labelled capability, the 500 spec is a VAG invention, mines run on 5/30 GM fully synthetic for the last 50k and there's not a rattle or missed beat to be found, generally I have it out after 12k sometimes 15k, obviously I wouldn't tell someone to go to Tesco and buy £3.99 oil for the engine, but at the sametime I think it's a con to frighten ppl to use a certain spec, when it's a simple case of White vs Blanc, two words same meaning, I've heard some great ones regarding the PD engine since I've had one, oooh don't use fuel inj cleaners it kills the pump?????? really is that why when someone brings a car in misfiring the first thing a VAG mechhanic will do is to bung a treatrment in the tank, it's all cash generation with VAG I'm afraid, lovely cars, lousy company.
Share this post
Link to post
Vaux, have their own spec, as do ford, BMW, Merc and others.
The PD injectors put a massive point pressure ont he cam and have friction modifiers and other compounds to provide high lubrication and wear resistance in a thin layer.
Don't use it and it won't suddenly die, but you will get faster cam and injector wear.
Share this post
Link to post
Sorry I am with Superbia on this one. Lets get real BMW GM VW and Merc DO NOT make oil ! FACT. They use manafactors to do this. now imagine how expensive an oil would be if it was made just for one engine type. Well the real important fact with oil is viscosity. If you get a cheap oill or wrong viscosity then I can understand how a PD engine can be damaged. My Dad works on commercial vehicles and cars and do you think they have 18 barrels of oil lying around. If you want to believe all this 505, 506 507 then thats ok. My Superb is out of warrenty and I know that with regular oil changes the car will be fine. Oh I have the blue coolant in my radiator not the pink Well the radiator failed after 40k so the pink cannot be that good. God I am a rebel.
Share this post
Link to post
It's up to you. You're on blue coolant, so that's a big bottle every two years rather than every five - so that's costing you five or ten quid extra a year over five years doing it that way? And you're saving a tenner an oil change using similar logic, so let's say you're "up" by a tenner a year. Is it really worth it? Presumably you don't bother with fully comp insurance either?
Share this post
Link to post
From an oil supplier:
[url]http://pics.tdiclub.com/data/529/16120Motul50501points.pdf[/url]
An interesting thread:
[url]http://forums.tdiclub.com/showthread.php?t=94811[/url]
Share this post
Link to post
But the radiator failed with pink coolant after 3 years so how did that save me money! Of course it could be the rubbish VAG radiator. Every two years gives me peace of mind. Again the oil mentioned in the articles were 0W or 5W of which I use 5W, changed every 10k and not 20K I cannot see how this is going to impact a PD engine just because it does not say 507 on the tin. Viscosity, Viscosity Viscosity. We have had over 500k and 8 different cars with PD engines. Bora, Fabiax 2, Superb, Golf Plus, Octavia, Jetta, and Passat (new shape). Not a single turbo or oil related problem. Hand on heart, honest. Sorry the Passat had a new oil pump on recall. Rubbish 2.0 TDi engine though. ALL were using the GM oil. I am not arguing against anyone using VW authorised oils in there cars, just that there is a bigger commercial picture. Oh I do have comp insurance. (even the remap is added !)
Share this post
Link to post
[quote name='berr0010']But the radiator failed with pink coolant after 3 years so how did that save me money! ... ...Oh I do have comp insurance. (even the remap is added !)[/QUOTE]
You know for sure that the radiator failed because of the coolant, then, and not a manufacturing defect or an unlucky stone strike? And you feel it's worth paying hundreds of extra pounds a year for the 'peace of mind' of fully comp insurance, but not an extra tenner or so to use the specified oil? :confused: Interestingly as far as the 'VAG conspiracy' goes, I was in TPS yesterday, and noticed that Ford specify the same oil for their PD-engined Galaxies as VAG do for their PD cars. They call the spec something different, but it comes in the same bottle. They're in on it too, presumably? ;)
Share this post
Link to post
[quote name='berr0010']But the radiator failed with pink coolant after 3 years so how did that save me money! Of course it could be the rubbish VAG radiator. [/QUOTE]
Yes i would put that down to VAG radiators, they do seem to be a week link failing fairly regularly after around 5 years.
Share this post
Link to post
[quote name='ap0gee']You know for sure that the radiator failed because of the coolant, then, and not a manufacturing defect or an unlucky stone strike? And you feel it's worth paying hundreds of extra pounds a year for the 'peace of mind' of fully comp insurance, but not an extra tenner or so to use the specified oil? :confused: Interestingly as far as the 'VAG conspiracy' goes, I was in TPS yesterday, and noticed that Ford specify the same oil for their PD-engined Galaxies as VAG do for their PD cars. They call the spec something different, but it comes in the same bottle. They're in on it too, presumably? ;)[/QUOTE]
You just answered your own question there regarding Ford PD oil and VAG PD oil, and it's not a tenner, it's more like £35 more than a suitable non manufacturer branded oil, if there was a magic ingredient both Ford and VAG would spec the same spec on the bottle, as they don't yet both go in the same engine what does that tell you Sherlock?
Share this post
Link to post
[quote name='Supurbia']what does that tell you Sherlock?[/QUOTE]
It tells me that you're so convinced you're correct, you didn't read my post correctly:[quote name='ap0gee][B']They call the spec something different, but it comes in the same bottle.[/B][/quote]Here's the spec sheet, 'Sherlock'
[URL]http://www.thetradepartsspecialists.co.uk/flash/quantum/product/102131%20Quantum%20Platinum%20Product%20Data%20Sheet.pdf[/URL]
Ooh, look! SAE 5W-40; API SL/CF; ACEA A3/B4/C3; VW 502 00 / 505 00 / 505 01, and [B]Ford WSS M2C-917A[/B] ;)
Whether it's a tenner or 35 quid, once or twice a year, I can't see how you think it's worth the risk for less than the cost of a packet of fags, a couple of pints, or whatever your poison is each month. Like I mentioned earlier, by that logic you should just insure third-party, as anything else is an unnecessary expense. But I bet you don't... Edited by ap0gee
Fixed link
Share this post
Link to post
[quote name='Supurbia']You just answered your own question there regarding Ford PD oil and VAG PD oil, and it's not a tenner, it's more like £35 more than a suitable non manufacturer branded oil, if there was a magic ingredient both Ford and VAG would spec the same spec on the bottle, as they don't yet both go in the same engine what does that tell you Sherlock?[/QUOTE]
How do you work that out then?
Normal 5w-30 or 0w-30 fully synthetic is about £25 to £30 a bottle.
VAG 5w-30 VW507 longlife is about £35 a bottle.
Seems like £5-£10 per bottle to me. (and yes that is 5L vs 5L price from the same motor factors)
Halfords example:
[url]http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_230739_langId_-1_categoryId_165581[/url]
That oil is a differing standard to the stuff used in fords own in house engine designs.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
