• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Windscreen Wipers
Sign in to follow this
Followers 0
17 posts in this topic
hi can anyone reccommed any windsreen wipers as i use skoda ones from dealer but they have changed from bosch(i like these ones so whould like to get something witch works aswell or better) to valeo as i have found them to be rubbish. iam looking for new ones i have tried halfords ones before aswell and did not like them ether.
Share this post
Link to post
Share on other sites
XOPC Acrobat Extremes. Best I've used. End of.
Silicon so outlast rubber ones and work in colder conditions and aren't affected by ice and frost.
http://www.xopc.co.uk/acrobat_extreme_wiperblades.htm
Steve
Share this post
Link to post
£43.40 for a 21in & 19in, are they really worth the cash Steve? Edited by reflex88
Share this post
Link to post
Freedom discount will shortly be re-applied to these, which brings them down to £30ish IIRC.
They are more expensive yes, but you'll spend £20ish on Bosch or flatblade replacements and these will easily outlast them. Plus you don't run the risk of having a slight bit of ice or frost on the screen now the cold mornings are back and ruining your rubber blades. The screen also gets coated with silicone as you use them, so gives glass protection, prevents the window icing up as much and also helps move water from the screen when at speed.
For me it's a no-brainer but can appreciate that it's a costlier purchase than other offerings.
Steve
1 person likes this
Share this post
Link to post
I've just bought the Bosch aero retrofit for mine and went to Wiltshire this weekend where it didn't stop raining and the wipers were brilliant.
Nice and quiet and cleared the windscreen well. Plus, they worked really well at speed in the wind, unlike the last flea-bay set I had which just created a rain curtain rather than clear the screen. However, I would have bought the Acrobat Extremes had I known there was going to be a Freedom discount :doh:
The Bosch were £26 icl. P+P from wiperblades.co.uk so for an extra £4 it'd be worth getting the Extremes I think.
Don't they do a normal Acrobat version as well though?
PS Why can't I use emoticons? Emoticons are my life. I'm incapable of expressing true emotion without them :(
Share this post
Link to post
I tried silicone wiper blades on SWMBOs old Peugeot years ago and they were nowhere near as good as Bosch ones. Had them replaced under warranty as they had apparently worn prematurely, but they were still rubbish. I have just fitted a set of genuine retro-fit Aero blades to my Octy and have been pleasantly surprised as they seem to be just as good as the Bosch ones.
Share this post
Link to post
Bosch retro fit Aero wipers (Aero-Twin) are the muts nuts. B) You can order them from the surprisingly called Wiperblades.co.uk [url="http://www.wiperblades.co.uk/product-list.php?Make=105&Model=1391&Mark=526&Year=2004&SearchAlive=1&Class=ncv&c="]Wiperblades.co.uk - Skoda Fabia 99-07[/url], I don't know how good their own brand of wipers are like. You could also try fleBay.
Don't bother with those silicone ones (eg, PAA ones), you might as well have ordinary ones and cover screen in RainX. Edited by Jim H
Share this post
Link to post
Sounds like a dumb question,
But have you tried manually cleaning the windscreen with something like Turtle Wax GLASS POLISH? or any decent glass polish for that matter?
Personally I do this once in a while, and I regularly treat the glass with Rain-X, which means you don't need to use the wipers above 40mph to be honest.
And on top of that, I buy the wipers from EuroCarParts, they sell bosch ones for something like silly cheap like £5 each.
All of the above works for me mate
Share this post
Link to post
these are the first set that have been rubbish and i fitted them the same. i do clean the windscreen the same but im better off not using them at all. any idears welcome
Share this post
Link to post
I bought some Bosch OE spec items from Euro car parts for less than £12 for the pair.
Highly recomended :)
Share this post
Link to post
i decided too give these ones ago Bosch retro fit Aero wipers (Aero-Twin) thanks for all the info you gave i might try rain x ago aswell
Share this post
Link to post
[quote name='reflex88' date='07 December 2009 - 16:55' timestamp='1260204923' post='1827889']
[/quote]
If they are as good as the PIAA silicon blades they are worth more. They pretty much last the life of the car and perform much better
They also make Rain X/Ombrello etc look like an expensive joke. Edited by Decron
Share this post
Link to post
I got the Bosch AeroTwin ones from autobulbsdirect.co.uk for £22.68 after applying the discount code briskoda010 for 10%. You will also get a pair of xenon sidelights free and if you use quidco.com can get another 12% cashback. The delivery is free. The wipers are good.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
