• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
17563/P1155
Sign in to follow this
Followers 0
17 posts in this topic
Hello Briskodians!
I currently have a problem with the motor. When driving, if I stray above 2.5k-3k rpm, the turbo 'shuts down' with NO warning lights or anything. If I switch off and restart, it is fine again, until 2.5k-3k rpm and the whole saga starts again. The code is as follows:
17563 - Manifold Pressure Sensor (G71): Short to plus P1155 - 35-10 - - - Intermittent
I disagree, it's NOT intermittent, its every bloody time! I've searched on here, and MAF, Sticky Vanes and replacement of the actual pressure sensor have all been mentioned.
Any ideas? I may be selling an Octavia real soon!
Cheers. Dave.
Share this post
Link to post
Share on other sites
[b][url="http://wiki.ross-tech.com/index.php/17563/P1155/004437"]17563/P1155/004437 - Manifold Abs.Pressure Sensor (G71): Circ. Short to B+[/url] [/b]
[b] Possible Symptoms [/b]
[list][*] Limp mode[/list] [url=""]
[b] Possible Causes [/b]
[list][*] Connection(s) to/from Manifold Abs.Pressure Sensor faulty[*] Manifold Abs.Pressure Sensor (G71) faulty[*] Pipes/hoses not/wrongly attached[/list] [/url]
[b] Possible Solutions [/b]
[list][*] Check wiring and connections[*] Check / Replace Manifold Abs.Pressure Sensor (G71)[*] Check pipes and hoses[/list] <a name="Special_Notes">
[b] Special Notes [/b]
[list][*] Someone with this dtc replaced the Boost Pressure Controle Valve (N75) and the dtc disappeared[*] More info about the Manifold Abs.Pressure Sensor (G71) (German language): [url="http://www.t4-wiki.de/wiki/Geber_G71_%28Saugrohrdruck%29"]http://www.t4-wiki.de/wiki/Geber_G71_(Saugrohrdruck)[/url][/list]
Share this post
Link to post
I've also noticed that the car has now acquired a loud sucking and chattering noise when throttling off. Is this connected in any way???
Share this post
Link to post
It sounds as if an intercooler hose has blown off?
Check all the large bore hoses (approx 4" dia) are still connected to the intercooler, EGR etc.
If they have blown out then the hose locating lug is probably worn so a replacement hose is needed, it's worth changing the clips at the same time as these ware and break as well (they are about 70p per clip)
HTH
Share this post
Link to post
My first thought was sticky turbo when I saw the code but that is normally logged as "postive deviation" rather than a short.
Is the car smoking at all? I think you often get black smoke if you have a boost leak.
Share this post
Link to post
[quote name='Gizmo68' date='18 December 2009 - 17:15' timestamp='1261156517' post='1836559']
It sounds as if an intercooler hose has blown off?Check all the large bore hoses (approx 4" dia) are still connected to the intercooler, EGR etc. If they have blown out then the hose locating lug is probably worn so a replacement hose is needed, it's worth changing the clips at the same time as these ware and break as well (they are about 70p per clip) HTH
[/quote]
Not something I would have thought of... will have to check tomorrow when it's light. Could this cause the 17563 code??? I've also just got 17564 Manifold Pressure Sensor (G71): Open/Short to Ground. It's not going well!
[quote name='trundlenut' date='18 December 2009 - 18:38' timestamp='1261161536' post='1836633']
My first thought was sticky turbo when I saw the code but that is normally logged as "postive deviation" rather than a short.Is the car smoking at all? I think you often get black smoke if you have a boost leak.
[/quote]
I'm not sure on smoke, however, I've just got the emissions code 17552, so looks like there may be! I'm starting to get quite worried now! Ha ha ha!
Share this post
Link to post
the G71 fault code applies to the sensor fitted on one of the intercooler pipes, i'd probably check the connections to this to start with and for any pipe leakages but more than likely its that sensor thats gone faulty £39.70 from the dealers
Share this post
Link to post
[quote name='bond007' date='19 December 2009 - 09:11' timestamp='1261213860' post='1836966']
[/quote]
Yep, my mechanic went straight to this, behind the O/S headlight. I've ordered one, and an N75 for good measure. Fingers crossed! Edited by DeeBe
Share this post
Link to post
Ok, just to finish this topic off. We replaced the MAP sensor and the N75 and it's back to it's good old self! Happy endings! Good times!
Thanks to those that helped me out with suggestions etc. It's really appreciated!
Share this post
Link to post
Hmm, maybe, just maybe I spoke too soon, it did it again last night. I booted it in neutral as far as it would go, and the black stuff POURED out the back, and it ran lumpy. Off/On with the igntion and all is well again. Hit the limiter again twice and no problems or smoke, but still have the whoosh/chatter sound when changing gear. Any problem pipes I should look for to see if they are split/missing/blown off?
Cheers!
Share this post
Link to post
[quote name='mbames' date='26 December 2009 - 20:18' timestamp='1261858724' post='1843002']
Anything showing in vag-com after it ran lumpy?
[/quote]
Nothing :S
Share this post
Link to post
could it be the MAF? This often seems to cause problems without causing fault codes. Try running the car with the MAF unplugged and see if it gets worse or if it is just as bad.
Share this post
Link to post
I shall check that first thing in the morning!!! Thanks trundlenut!
Share this post
Link to post
[quote name='DeeBe' date='27 December 2009 - 22:22' timestamp='1261952574' post='1843689']
[/quote]
also another thing, Had something along these lines when i worked for skoda but was more of a permanent clattering noise with loss of boost, was the turbo veins that had shattered.
Also MAF sensors can cause lots of weird and wonderful faults so removing it and then testing (like previous poster said) will show if its to blame.
Share this post
Link to post
[quote name='agent47c2000' date='28 December 2009 - 18:15' timestamp='1262024122' post='1844209']
[/quote]
Sorry it's taken so long to reply.
Right, I replaced the MAF and it made no difference at all. So, my mechanic spent a lot of his own time removing my turbo only to find the a couple of the veins were indeed shattered. I decided that the best cause of action was to put it back together and get shot. It was also FILTHY. Absolutely drowned the tank with Wynns Diesel treatment and brayed the living sdaylights out of it down my local motorway and it seemed ok - down on power but ok.
I traded it in and bought a Focus. I only paid a shade over 1400 quid for the Octy so couldn't justify the repair cost for a turbo. I was absolutely gutted. I got a healthy 2500 trade so definitely couldn't grumble. The guy at the garage said he was sending it to the auctions so no comebacks or anything!
I still hope to stick around though. Thanks for everyones help.
Dave.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
