• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
ABS and Brake warning Light on during Cold weather
Sign in to follow this
Followers 0
9 posts in this topic
I have aproblem with my beloved Fabia VRS, in that in this cold weather the ABS and Brake Warning lights are coming on initially and are taking about an hour to reset. This reset will only happen when I stop and restart the vehicle. What I would like to know has anyone out there experienced this before, is it common and should I be now worried? I know I should not drive with it on but this only seems to be happening since this cold snap.
Andy
Share this post
Link to post
Share on other sites
Since the cold weather started I have noticed on my 2006 VRS when you turn the key to the first position all the warning lights come on and go off as they all self check and are error free I presume.
When I start the car the ABS and Traction Control light come back on and then go off after a couple of seconds.
When the car has been warmed up after a journey and you come back to it and restart the car, the warning lights do not come back on after engine start up. (normal condition)
Also had the water warning light come on whilst ticking over in the drive whilst de-icing the out side of the car - water level is fine
Share this post
Link to post
[quote name='MoggyTech' date='23 December 2009 - 12:16' timestamp='1261570612' post='1840647']
Battery.
[/quote]
Sounds like it as they reset once it has got a decent charge in it.....
Share this post
Link to post
[quote name='engpk' date='23 December 2009 - 14:02' timestamp='1261576928' post='1840776']
[/quote]
Classic symptoms of a battery on it's last legs. With a good battery, warning lights all go off and stay off after starting (handbrake light is the exception.) Basically after cranking, the battery volts are so low, you get false PAS/ABS/ASR warnings.
Share this post
Link to post
[quote name='MoggyTech' date='23 December 2009 - 14:19' timestamp='1261577943' post='1840790']
[/quote]
Mine's just started doing this, it is an 06 plate on its original battery. Is 3 and a half years about right battery lifespan? Any other checks I can do to see if battery is going?
Share this post
Link to post
[quote name='TeebsVRS' date='23 December 2009 - 16:55' timestamp='1261587344' post='1840949']
[/quote]
The problem with diesels is they hammer the battery. My car is an 07 plate, and I fitted a new battery in July, due to the PAS/ABS/ASR lights coming back on for a few seconds after starting from cold. My old battery passes all normal tests, including heavy load test. The only test it fails is 24 hour open circuit voltage which should be 12.5 volts or more, but is only 12.27 volts. My battery age meter shows the battery is 60% efficient.
Obviously I have more test equipment than most folk :rofl: However, a simple test, is to charge the battery to maximum, then check the voltage across the two terminals with a multimeter 24 hours after charge, and the car not being used. Anything under 12.4 volts, the battery needs replacing. Test is best done with battery disconnected from the car.
One thing I have discovered about car batteries, is they will fail on you at the worst possible time. Something to do with Sod and Murphy apparently.
Share this post
Link to post
don't want to tempt fate, but i'm still on my original battery, 04VRS :doh:
it does crank slightly slower at present, but i will give it a good charge tomorrow at work, well until dinner time anyway ;)
Share this post
Link to post
[quote name='ric04vrs' date='23 December 2009 - 17:34' timestamp='1261589692' post='1840981']
[/quote]
Consider fate tempted to the extreme mate :rofl:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
