• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Steering Angle Sensor Removal How To
Sign in to follow this
Followers 0
51 posts in this topic
Could any one give a good guide of how to remove a steering angel sensor as it seem to be a very common issue with most VW based cars and in particular the Fabia 1 any diagrams or steps how to access it safely and easily would be I'm sure a great help to the community.
This should may be pinned as as far as i can tell is the most common fault with the Fabia range and seems to be a DIY friendly job to both cure and diagnose some annoying faults
Please Help
Share this post
Link to post
Share on other sites
There is a good guide on Tom's site, fabia-vrs.com. I'm not sure it's anything like as common a fault as leaky doors - which is also covered there...
HTH
Share this post
Link to post
PS: Based on experience and 'site wisdom', poor battery condition can lead to symptoms similar to those attributed to PAS sensor failure, and it is probably worth making sure you've confirmed it's not that before replacing the sensor...
Share this post
Link to post
[quote name='ap0gee' date='18 January 2010 - 14:17' timestamp='1263824264' post='1864548']
HTH
[/quote]
thats a realy great site thanks for that ap0gee
do you no where in the site the steering angel sensor section is found i did see the pas sensor removal section but not the steering angel sensor one thanks
Share this post
Link to post
[quote name='ap0gee' date='18 January 2010 - 14:39' timestamp='1263825555' post='1864574']
[/quote]
i have a 000816 fault form the ecu when plugged in would that negate the battery issue or is it still a good idea to test it first
Share this post
Link to post
The PAS sensor is what you're looking for! :)
Here is an explanation of your 00816 code:
http://wiki.ross-tech.com/index.php/00816
...and fair enough, it points to the sensor being at fault. If your battery doesn't have a 'magic eye', it might still be worth checking it out, although the recent cold weather would probably have told you whether the battery was duff or not, to be honest...
Share this post
Link to post
humm so the 00816 refers to the sensor at the bump as apposed to the one behind the wheel. is there any good tricks to turble shoot this ie removing one or the other to see if the light flickering persists
Share this post
Link to post
one thing to note is there is a brand new power steering pump fit-ed only a moth ago buy the garage were i bought it before i got it. along with a new alternator and belt as i spoke to the mech that caryed out the work and he was the one who ran diagnostics and pointed me towards the steering angel sensor behind the wheel
thanks so much for your help BTW
Share this post
Link to post
I think you've misread Tom's guide. That first pic / instruction relates to the connector [i]at the other end[/i] of the cable that the PAS sensor is connected to! The sensor is on the rack, at the end of the steering column; not behind the wheel. What's been described by the mechanic sounds like the ABS sensor???
Share this post
Link to post
o relay he described it as a circular sensor behind the steering wheel so its at the end of the column were it meets the rack is it i see any good tips on weather one can disconnect or remove it and see if the lights keep flickering or will doing some thing like this cause more harm than good? Im just trying the trouble shoot to see if i cant identifi the root of the flicker to be sure
Share this post
Link to post
I can't think what your mechanic's describing...
The diagnostics code points pretty definitely at the sensor, but you could always disconnect it at the PAS pump end (as described at the beginning of Tom's guide, like we discussed earlier), and see if anything changes. If it doesn't make any difference, then it'll be the sensor or the connections...
Share this post
Link to post
yes steering sensor is located in the stem of the rack the wiring is about 4 tf long and plugs directly into the pump unless you have a very late car.
sensor is probly full of water/condensation
Share this post
Link to post
you guys are the best and im a bit Happyer not having to go near the steering wheel at all and i can much around with the wiring in the engine bay instead to try and see if any thing changes
any one no any were to get some diagrams of the assembly for the steering rack end of things
Share this post
Link to post
I was given to understand that there are two PAS sensors on some cars (with xenon lights) - the PAS sensor and the steering angle sensor, both of which can give flickering lights on full lock if they are dodgy. As has already been stated, bad batteries and poor charging also give the same symptoms.
Share this post
Link to post
I removed the fuse to The power stearing pump fuse 5 and no mote flickering and every things seems better is it safe to drive with it out for a few day may be 2 weeks till I can get the dosh for the parts I need? Will I strain or damage any thing buy driveing it with out the fuse in at all for tow weeks And that being sead is it a good idea as the flickering and pump noise are getting worce and I'm conserend about the fault damageing the pump or other systems on the car
Share this post
Link to post
In terms of there being two sensors, all I can think of is the yaw sensor on cars with ESP, but all this does is allow the ECU to determine the difference between the car's direction of travel and the way the front wheels are pointing. As regards flickering only at full lock, I believe the flickering will occur [i]at all times[/i] when the PAS sensor has gone, because it sends spurious signals to the PAS pump, making it activate and shut off repeatedly and in quick succession. As the pump draws around 60A, it's going to make heavy drains on the electrical supply of anyone's car! The lights [i]going dim[/i] during steering input (and especially at full lock) by contrast is therefore normal, particularly if you are manouevring with the engine at idle. I note that the OP hasn't actually made any mention of problems with the headlights; just the fault code, by the way!
Coming back to the yaw sensor, however, ESP works on the brakes not the steering, so I can't see how that would throw up the fault code mentioned at the beginning of the post.
In response to the question, however, if you take the fuse out, all you're doing is stepping back in time twenty years and driving a car without power steering. Hard work, but not dangerous as far as I know...
If you're having to save up for the work, I really would recommend double-checking the condition of the battery just to be sure. If the battery's more than four or five years old, you'll be on borrowed time as it is, so you'd only have to replace it sooner or later anyway. Plus, you'd obviously know for certain that it was a problem with the power steering and not the battery, of course!
Just my 2ps...
Share this post
Link to post
thanks for the advice mate i drove my car home last night and back into work this morning about 40 miles with the fuse out and she runs much much better the engine ticks over better and the mpg is much better i averaged 52.7mpg on the trip apposed to yesterdays 23.9mpg so seems to be a lot better on the engine with out the pump draining power all the time. Im a big guy 17 stone 6 foot 4 and the power steering being off isn't relay causing me any issue and in fact when cornering at speed it is a lot nicer to feel the road and the angel of the car better. the only thing im worried about is weather this is placing any extra pressure on the pump or the steering rack or any thing like that if i drive it like this for a few weeks.
Also if there are to sensors to the system one on the steering rack and the other at the pump whats the best way to figure out which one is gone. That being said the pump is new and was only fitter a few weeks ago before i bought the car so might this imply that its the sensor on the steering rack more likely
Share this post
Link to post
[quote name='chopperj' date='19 January 2010 - 09:19' timestamp='1263892742' post='1865453']
[/quote]
No, you're still misunderstanding, I'm afraid. The connector at the pump end isn't another sensor; it's the other end of the cable that the sensor's attached to. I think you need to forget about there being two sensors, as to the best of my knowledge, there aren't - at least not that could throw up an 00816 fault code. The whole thing needs replacing if the sensor's gone, as the sensor can't be detached from the cable.
It's definitely worth checking the connection is sound at the pump end and then putting the power steering fuse back in - if only to rule out a dodgy connection!
Share this post
Link to post
ahhh it sinks in so its all one sensor and any thing short of bad connection means that the sensor is gone that make life so much more simple now im going to check it all over on Saturday and then if im sure its not just a bit of bad wiring ill order the sensor would any one have a good on-line resource to buy the for-mentioned sensor at a good rate it will cost me about 90€ in vat here in Dublin Ireland from Skoda.
Share this post
Link to post
I think you need to make sure you're getting the right part before you order it, as I don't think they're compatible between the different types of PAS pump. Can't be more help than that, I'm afraid...
Share this post
Link to post
i wonder then when im ordering if other than giving skoda my chasey number that i should give them any info i can on the new pump ie serial number or some thing like that so they can tell what pump it is and match the sensor to that and not just the car
Share this post
Link to post
Unless the car's had a complete power steering system from another car fitted at some point, the chassis number will be fine for a dealer or a motor factor - it just wouldn't necessarily be enough information if you were going to order the part over the internet...
Share this post
Link to post
also if you were to disconnect the sensor from the pump the pump would then work in emergancy mode and give you some assistance. also you run the risk of damaging something by running the rack manually as it could start sucking air past the seals in the ram
1 person likes this
Share this post
Link to post
So no fuse bad idea so?
if so damn !
Would it be better to disconnect the sensor as you said to put her into emergency mode instead?
Share this post
Link to post
By the sounds of things, yeah.
If you're going to go down that route, make sure you tape up the socket and the connector, and tie the cable up so it's not flapping about.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
