• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
uprating front door speakers in a FABIA
Sign in to follow this
Followers 0
8 posts in this topic
Hi, i want up uprate my speakers in my fabia which is a sdi classic x reg.
Has anyone done this and could give me some tips, also could they recommend any speakers for the car?
cheers ROB
Share this post
Link to post
Share on other sites
The oem speakers are a strange size so it's not really a bolt off bolt on job i'm afraid.
You can get adapter collars from people like autoleads though, which allow after market speakers to be installed, but be aware that your new speakers will need to be quite shallow as there isn't much space in the door.
Most speaker manufacturers seem to do special ranges of slim line speakers.
To remove the oem speakers mounting you'll need to drill out some rivets and then rivet in the replacement collar or use some short self tappers.
Some people use mdf rings instead of plastic collars for better sound but be aware that if you do this they'll need to be treated against water as the fabia lets a notable amount of water through the door when it rains and this can cause non treated wood to swell and split as well as just go quite manky.
When you do it be sure to buy some door trim clips from skoda first as these are weak and your guaranteed to break some. They cost pennies.
Rob.
Share this post
Link to post
[quote name='robbied' date='08 February 2010 - 09:57' timestamp='1265623065' post='1888581']
Hi, i want up uprate my speakers in my fabia.
cheers ROB[/quote]
Hi, try CDT speakers which are shallow. (Phone K&M in Wigan for info on 07809-22 12 86
K&M fitted a set of Rockford Fosgate components to my Fabia (which I had in my previous car.)
Was expensive, but more than worth it as the sound quality is excellent.
Don't forget to fit some sound-deadening strips (e.g. Dynamat) to the door panels while you are at it.
Bob. Edited by BOBAD
Share this post
Link to post
Pioneer do OEM direct replacement speakers. I am sure when I looked at ones for the Fabia though I got the impression they listed the wrong size.
Share this post
Link to post
I'd change your headunit first, you'll notice a much better sound from the OE speakers when a decent HU is powering them.
Share this post
Link to post
I recently fitted some alpine front speakers that i picked up at halfords for 35 quid or something. had to shell out 15 on plastic adaptors too though. used the ones for a golf and the worked great, had to drill out the rivets on the original ones other than that pretty simple stuff. they sound great, much better than stock, obviously paired with a sub though.
Share this post
Link to post
Thanks for the info guys...problem is how do i take the door cards off? is it a quick job?
Share this post
Link to post
I did a tutorial on this ages ago - received a PM today by someone asking for the pics which have been lost or something. Will try and dig it out (pics may be somethign else!
edit: here it is, minus the pics: http://briskoda.net/forums/topic/8314-fabia-vrs-front-door-speaker-change-how-to-with-pics/page__p__117775&#entry117775 Edited by tfboy
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
