HELP ! 1.2 12v engine problem
  • Please log in to reply
8 replies to this topic
#1 aladin
aladin
    Briskodian
  • Members
  • Pip
  • 18 posts
  • Car:Skoda Fabia 2004 1.2 HTP , Skoda OCTAVIA 2007 1.6 MPI
Posted 21 March 2010 - 08:50
Dear All ,
I have Fabia Sedan 1.2 V12 2004 and it has been running for 92000 KM (57000 Miles)
I purchased the car brand new from the dealer 5 years ago and since then it suffers this serious problem occasionaly:
When I start the engine it starts to tremble and the RPM will refuse to cross 2000 even when maximum throttling , it seems that one of the 3 cylinders is not getting fuel
it is useless to restart the engine or wait for it to warm up , the problem will be over after an unspecified period of time and the car wil run again normaly
sometimes I lift the engine cover and hit injectors slightly and the problem is solved but not always
The amazing thing is that this problem follows no time pattern it happens once a year or once a month or twice a week , but sometimes it causes major embarrasment if I'm outside town or with other people
I took the car many times to service but the diagnosis computer shows no faults , injectors are periodicaly cleaned , fuel filter regularly replaced at the authorized workshops
at the workshop they suggested that the problem maybe within the car computer , but I doubt it , and most 1.2 v12 Fabias suffer the same problem
So any information from you guys could be of great importance .... thanks in advance
#2 mudyf0x
mudyf0x
    Member
  • Members
  • PipPipPip
  • 171 posts
Posted 21 March 2010 - 11:21
I was going suggest, changing your fuel filter but see you have all ready do that...
what about your plugs... have you took them out and had a look at them lately?.. or one of your coil packs could be dodgy, or you may be buying inferior fuel from somewhere ( unwittingly)
#3 aladin
aladin
    Briskodian
  • Members
  • Pip
  • 18 posts
Posted 21 March 2010 - 11:48
Thanx i'm at the workshop they are changing the 3 coil packs plus one of the injectors (for about 300 usd) but they say if the problem persists they will have to deal with cylinders and will cost me a fortune
#4 mudyf0x
mudyf0x
    Member
  • Members
  • PipPipPip
  • 171 posts
Posted 21 March 2010 - 11:56
check your plugs and check condition, gaps and if any have oil on them
#5 Irvtheswerv
Irvtheswerv
    Big oaf
  • Members
  • PipPipPipPip
  • 650 posts
Posted 21 March 2010 - 12:01
If it's not coil packs/plugs/injectors, could be a stretched chain cam is causing a misfire, could be piston rings. The cylinder head will have to come off to find out what the issue is.
#6 Leodhasach
Leodhasach
    April 1990-October 2011. RIP.
  • Members
  • PipPipPipPipPip
  • 2,350 posts
Posted 21 March 2010 - 19:04
Didn't know Skoda made a V12 engine :giggle:
#7 allytech
allytech
    www.unit18.co.uk
  • Non-Supporting Trader
  • PipPipPipPip
  • 580 posts
  • Car:Citigo, Track 200SX, VAN
Posted 21 March 2010 - 19:46
This engine suffered with valve problems, the cure was a new cylinder head, get the compressions checked before paying for all those bits
#8 Jim H
Jim H
    Happy Briskodian
  • FREEDOM
  • PipPipPipPipPipPip
  • 6,195 posts
Posted 22 March 2010 - 00:56
I guess he means a 12v (12 valve not 12 cylinders in a V). Having said that the 3 cylinder engine does sound like a V6 or V12 when you rev it.
P.S. Sorry I can't help you with your engine problem.
#9 aladin
aladin
    Briskodian
  • Members
  • Pip
  • 18 posts
Posted 22 March 2010 - 06:28
Oh yes it is 12v (12 valve) I wish it was a V12 !
They checked the compression it is OK , the car is working fine now but if the problem occured again I guess I will have to check the cylinder heads
thank you guys for the help
