Evap Simplification
Recommended Posts
Quite a simple thing but another step on tidying up the engine bay.
I've disconnected one of the two pipes from the evap system to the intake, enabling removal of the hard lines on the side of the engine block which were mostly unused after the N249 and SAI removal.
This is how it looks now
Had to disconnect this to be able to remove the hard lines
Lost more water than I meant to
This is what came out
So this is the new look engine diagram. Getting there!
Link to comment
Share on other sites
well done Rob. any side effects of this...
Is'nt there a pipe coming from the turbo pipe somewhere going to the evap system?
I recall another small black hose connected to the metal hard lines at the back end.
Mark
Link to comment
Guest westallc
well done rob i have now done the same but have gone to a bit more xtreme lol
n249 n112 secondary air system and all vac lines removed
left is brake vac feed from under manni and re routed and fuel reg and dv vac line thats it.
crank breather straight through to catch can
your guides helped thankyou.
Link to comment
Nice one Rob :thumbup:
You gonna remove the suction spray pump system? Mine's been running great without it for about 2500miles now, so consider that road tested! Pretty nice not having to worry about any vac lines under the inlet manifold!
I'm getting really tempted to plug the breather port on the turbo intake hose, and then just fit a small breather filter onto the outlet of the catch can. I might just get on and try it actually.
Clive, get some photos up! :rock:
Link to comment
Guest westallc
not yet not yet project secret not finished just yet :thumbup:
Link to comment
Yes that's my next task - want to do it in stages so I don't mess it up!
And I need to get it tidied as much as possible before my FMIC arrives :D
Intriguing..
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
