• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
gearbox oil?
Sign in to follow this
Followers 0
10 posts in this topic
HELP!
I'm working at Benfield at the moment.
I'm having to drive to work early in the mornings; but on cold mornings my 1.8t 5 speed gearbox can be stiff and notchy.
I've been advised by a Skoda mechanic at another branch to change the gearbox oil...
I wantt to upgrade from the oe oil. sea75w-90 gl4 semi synth.
A GL5 rating was stated to be the upgrade.
Has anyone used a sea75w-90 gl5 fully synth oil in theres? If so what brand?
I can buy Millers from work, but I'm thinking of the Mobil oil (Mobilube).
Can anyone shed some light?
Share this post
Link to post
Share on other sites
If I were you I would try the Genuine Skoda G52 oil. I tried Fuchs and it was notchy as hell, had to change back to a fresh batch of G52 and all was great again.
It's the only oil that is specifically designed for the car that is 100% known to work and it's cheap.
Share this post
Link to post
[quote name='pinkpolo' date='26 March 2010 - 21:07' timestamp='1269630453' post='1936742']
[color="#FF0000"]Can somebody help me[/color]????
I’m working at benfield at the moment and I’m having to drive to work early in the mornings, On cold mornings my 1.8t 5speed gearbox can be stiff and notchy. I’ve been advised by a Skoda mechanic at another branch to change the gearbox oil...
I wont to upgrade from the oe oil. sea75w-90 gl4 semi synth. a gl5 rating was stated to be the upgrade.
has anyone used a sea75w-90 gl5 fully synth oil in theres??? if so what brand??
I can buy millers from work, but I’m thinking of the [color="#0000FF"]M[/color]obil oil (mobilube) Can anyone shed some light on this predicament....?
[/quote]
you can try this one [color="#FF0000"]http://www.redlineoil.com/product.aspx?pid=46&pcid=7 [/color] it worked for me perfectly
Share this post
Link to post
Before you go changing oil suggest you check your cable alignment.
Sometime the gearlever through can cause notchy changes The Haynes manual describes how to do this(quite simple) It basically realigns the gear lever /cables to the change mechanism.
Mine was notchy as afterwards was very smooth. Typically with that condition 1st , 3rd and 5th are notchy.
Gearbox oil does not really need to be touched unless you have lost some / changing drive shafts etc. Edited by Bowders1
Share this post
Link to post
[quote name='Bowders1' date='26 March 2010 - 21:00' timestamp='1269637243' post='1936887']
[/quote]
All been realigned and checked... last weekend. it’s only notchy for a few mins before the car warms up...
According to Skoda it would be down to the syncro or to the oil degrading in the box but they don’t offer to change it on servicing as in theory it should last the life of the box, but they do admit this isnt always the case.
when you put the redline in was it 2.0 liters to fill it???????
Share this post
Link to post
I changed my gearbox oil last week as it was getting a bit notchy & crunchy when cold........i used genuine skoda gearbox oil,it cost me £4.84 + vat a litre,i used just under 2 litres & it has made a big improvement to my gearbox! :thumbup:
Share this post
Link to post
[quote name='pinkpolo' date='26 March 2010 - 23:27' timestamp='1269638853' post='1936907']
[/quote]
2 liters is more than enough :yes:
Share this post
Link to post
[quote name='mikey vrs' date='27 March 2010 - 01:06' timestamp='1269648397' post='1937016']
[/quote]
did you take your own container into skoda?
Share this post
Link to post
[quote name='Flybikeslee' date='07 October 2010 - 14:21' timestamp='1286457719' post='2127881']
[/quote]
No,you buy it in 1 litre bottles.
Share this post
Link to post
hello
i have my skoda octavia 1.6 MPI 2008 i went for oil change services in the skoda company ,they recommended to change the gearbox oil after 90,000 KM my question is do they have to change it ? i mean i know that the gearbox oil will be changed only if there is leak known that i live in hot country in the middle east
thank you
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
