• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Cigarette Lighter Fuse Keeps Blowing
Sign in to follow this
Followers 0
4 posts in this topic
I have just purchased a new Michelin tyre inflator to replace my old digital one which i have had for 6 years now. The problem i am having is that every time i use it on my vRS the cigarette lighter fuse keeps blowing.
When i plug the inflator in the lights come on and it displays the tyre pressure, however as soon as i press the on switch to inflate the tyre the fuse immediately blows.
This has happened about 4 times now and i keep having to replace the blue 15A fuse. I always have the car started, and have tried it with everything else switched off but it still does it. This never happened once with the old tyre inflator which i had.
I have been using this Michelin tyre inflator on the other cars with no problems, its just everytime i use it on the Fabia the fuse keeps blowing.
Any ideas why this keeps happening?
Share this post
Link to post
Share on other sites
[quote name='RiCh_vRS' date='27 March 2010 - 20:48' timestamp='1269719287' post='1937600']
[/quote]
I have experiences this same problem but with a Halford inflator on a different car. It turned out to be the inflator that was at fault so I bought a new one.If theres anyway to check the volts you could try this or replace the inflator.
Share this post
Link to post
When first turned on the motor is under full load turning the compressor. The motor draws a large current initally before the motor gets up to speed, this time is long ,and current is large enough to blow the fuse . If the inflator is found not to be at fault, you could uprate the 15 amp fuse to 20amp,but no higher. It may be that in other vehicles the circuit is fused at a higher rate,and other makes of inflator take less current. Edited by AndyPandy
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
