• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Car pulling to the left
Sign in to follow this
Followers 0
11 posts in this topic
Booked car in to get wheels balanced, tracking, caster and camber checked.
Work has been done and I need to collect the car (only wheels balanced), but I asked if the car is still pulling to the left. I was told it would do as its a German designed car and designed for FLAT German roads and that UK roads are cambered to the left, the car will pull to the left?
I call bullsh*t on this, but is there some truth in this? If its BS and cars still pulling to left im going to to have some serious words with garage in question.
Share this post
Link to post
Share on other sites
The explanation is BS, but the statement may be correct as far as it goes. If it only pulls left hands-off it's a safety feature to keep you away from other traffic if you go to sleep at the wheel.
Share this post
Link to post
My Superb2 pulled to the left before having a full 4 wheel alignment done and now it runs as straight as an arrow.
Share this post
Link to post
A correctly set up B5.5 goes straight on a flat road - mine does. Any car will run down a camber, so test it on the flat.
The problem is that the B5.5 has a complex front suspension which is both wear-prone and very difficult to set up accurately. If you're having the alignment done, ask them how they set the "raised toe". If they don't know or cannot produce the VAG tool and describe the method - walk away.
(Raised toe set the height of the track rod end ball joint in the knuckle lever to give the correct toe under all conditions of suspension deflection. You adjust it with the seemingly superfluous bolt which threads into the end of the ball pin, from the top).
rotodiesel.
Share this post
Link to post
[quote name='ian0x0r' date='30 March 2010 - 14:09' timestamp='1269958140' post='1940349']
[/quote]
Hi Ian
Not getting into buls**t or not but check for broken spring !
My lad complained about is Octavia pulling to the left, when we checked out found a broken spring, replace (both) and now ok
Radiotwo
Share this post
Link to post
Thanks for quick replies guys.
Ill ask them about the raised toe when I pick it up roto :thumbup:
I had a check of the spring before I took it in Radiotwo, they seemed to look ok. Im wary of this as it has happened to me in the past :smirk:
Share this post
Link to post
I wonder if broken springs are an unseen issue on this car? My company car 1.9d 130bhp 55reg, 50,000 mile car has just had both broken front springs replaced.
Only sympton was a slight graunching noise from the drivers side on going over speed bumps with one wheel, and a slight pull to the left. I am not aware on any particular potholes or bumps which could have caused this?, although I now realise the ground clearance had reduced as well. I thought it was going to be a worn roll bar bush! Drivers side had seperatedcompletely and the broken ends overlapped causing the noise, the passenger side fell apart when raised on the ramp.
Share this post
Link to post
[quote name='kenfowler3966' date='07 April 2010 - 17:35' timestamp='1270658109' post='1948366']
I wonder if broken springs are an unseen issue on this car? My company car 1.9d 130bhp 55reg, 50,000 mile car has just had both broken front springs replaced.Only sympton was a slight graunching noise from the drivers side on going over speed bumps with one wheel, and a slight pull to the left. I am not aware on any particular potholes or bumps which could have caused this?, although I now realise the ground clearance had reduced as well. I thought it was going to be a worn roll bar bush! Drivers side had seperatedcompletely and the broken ends overlapped causing the noise, the passenger side fell apart when raised on the ramp.
[/quote]
Yeh I had the noise from the drivers side when the spring was snapped. I didnt notice that it was snapped either at the time. Snapped at around 50k miles as well.
On another note, having the wheels balanced seems to of cured the problem somewhat but im still not happy with the ride. Car seems to of developed a strange noise from passenger side as well which is most noticable at 70mph. It doesnt really sound like a wheel bearing is going though (had 3 different carf with knackered wheelbearings) Im wondering if its th tire tread. Going to fit my spare when I get a chance to eliminate tire noise.
Car also seems to vibrate a bit more than I would expect at speed, could this be caused by having 4 mismatched tires? Vibration is what you would expect from unbalanced wheels, but ive just had this done. Edited by ian0x0r
Share this post
Link to post
[quote name='ian0x0r' date='07 April 2010 - 22:34' timestamp='1270676084' post='1948757']
[/quote]
Are all the tyres the same design?
Share this post
Link to post
Utter Bullchit, mines only ever pulled to the left as of incorrect tracking.
Although i would agree broken/worn suspension parts could lead to it pulling to one side. Edited by Browny_37
Share this post
Link to post
[quote name='m_zafar' date='11 April 2010 - 21:13' timestamp='1271016781' post='1952214']
[/quote]
No they are all different.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
