FMIC finally fitted :)
Recommended Posts
Finally got around to fitting my Seat sport intercooler, fitting was fairly straight forward, only minor adjustments were needed to the crash bar. I bought a pipe kit from forge that is designed to fit the intercooler to the ibiza's, they all fitted spot on! Here are some pictures i took along the way
intercooler bolted on
crash bar on
this shows just how little i had to trim the bar
all connected up :)
and finally, bumper back on!
Link to comment
Share on other sites
The size...Couldn't you fit a bigger one :giggle:
It is a little on the large side but as they say, if your going to do it, do it properly!
Thats sport on mate, and very pleasing to hear, i`v just ordered one up! :thumbup:
Matt
Have you ordered a Seat sport? If you have, make sure you order the mounting brackets aswell, makes life so much easier!! If you need any info or help just drop me a pm!
Link to comment
Cracking job there :thumbup:
Much better fit in my Eye's than the Forge item... Shorter pipe runs as you don't have that silly loop back underneath the intercooler........
How is the intercooler fastened to the Car then ? You can't actually see ...
& how much was/is the Seat sport intercooler & pipe Kit please ?
Cheers.
Dean ;)
Edited by dfullb
Link to comment
Cheers.
Dean ;)
Its meant to be much more efficient than the forge kit, certainly looks a whole lot better. The intercooler is mounted on 2 brackets which bolt on to the radiator mounting points, ive got the part no's if anybody needs them. As for price. the intercooler retails at £265+vat and the pipes were £225 so a fair bit cheaper than the forge one aswell. I did have to modify the bumper a little though, had to cut some of the supports out to clear the pipes, also had to lose one of the top mounting brackets! And i can no longer use my towing eye, there's a boost pipe in the way!
Link to comment
Yes please to part Numbers ;)
Dean
Link to comment
ah i want one now!
*looks for somthing to sell*
looks brilliant :thumbup:
out of interest which seat are they actually supposed to be fitted on?
They are fitted on the mk4 ibiza cupra derv and 1.8t as standard!
Link to comment
  • 3 months later...
Guest BigJase88
not as great detail as gaz but heres a pic of mines, i believe mine is on custom brackets so sits lower.... also i dont lose a bumper fixing either
my ic looks a bit tatty after all it is 60k old!!
i now have new pipes like gaz and have cleaned it up a bit, put some holes in crash bar for air and sprayed it up
et voila
Link to comment
et voila
Wicked! :thumbup:
Link to comment
The forge pipes are a bloody tight fit!!
Had to lose the drivers side bumper mount, which isn't really a big deal.
Quite a lot of the plastic meshy bit inside the bumper needed cutting away (couldn't see this mentioned anywhere. I dont have pictures of that though) because the forge pipes were in the way.
Some trimming of the passenger side bumper mount was required but can be kept (just).
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
