Can't centre steering wheel
  • Please log in to reply
10 replies to this topic
#1 thebloyn
thebloyn
    Briskodian
  • Members
  • PipPipPip
  • 391 posts
Posted 27 April 2010 - 12:58
Now ive had this Fabia VRS for a few weeks and the off centre steering wheel drives me mad so went to my usual alignment place in Nottm to get it sorted.
Ive used them loads before and they have a hunter machine and they did it all properly clamped the wheel centre and I checked, and they did their adjustments.
On driving out the wheel is still not centered when going straight, its at about 11 o clock, put it straight and car drives to the right, quite a bit.
I took it back and had it redone, still the same, ive got a printout which looks fine but its driving me mad not having a straight wheel.
by the way the car does not pull to either side when i let go of the wheel, its just the wheel is not centered.
Ive checked the pressures are fine, there was no sign of damage when it was up on the ramps so im stumped.
The front tyres are not the same make but it pulls so much even going slow that I cant think that is responsible.
I was thinking of getting 4 new tyres anyway as they are some auful brand and quite noisy, but is there any other obvious fault, is this gonna get expensive.
It may seem small but an off centre wheel is something i cannot live with.
#2 tag1_uk
tag1_uk
    Briskodian
  • Members
  • PipPipPip
  • 323 posts
  • Car:2002 Skoda Fabia 1.4 16v Comfort
Posted 27 April 2010 - 16:08
I had the same problem after some work that was done by a garage on the dash which required the steering wheel to come off - they had not put it back on straight. I think if it isn't pulling to the side then the wheels and tracking are ok and you have to take the steering wheel off itself and adjust the position of that.
#3 thebloyn
thebloyn
    Briskodian
  • Members
  • PipPipPip
  • 391 posts
Posted 27 April 2010 - 16:36
lol really something as simple as that?
#4 JulieD
JulieD
    Uber Member
  • Members
  • PipPipPipPipPip
  • 1,253 posts
  • Car:2013 Yeti Adventure 4x4, 2012 Yeti Elegance 170 4x4, 2010 Octavia vRS TSI estate
Posted 27 April 2010 - 16:39
I think if I were you I'd go back to the garage that did the alignment and get them to do it, which I'd expect to be done free of charge. If you do it yourself be careful with the airbag.
#5 DEAN0
DEAN0
    Member
  • Members
  • PipPipPip
  • 223 posts
Posted 27 April 2010 - 17:05
Does the print out show the drift angle from straight ?
If alignment is done properly it should take account of the rear axle drift angle and be set so that the steering wheel is straight when the car goes straight.
All the adjustments in the world on the front end are not going to have the steering wheel straight unless the rear end is accounted for.
Do not move the steering wheel round on it's splines - you will confuse the steering angle sensor.
I tried 4 different places until i found one that knew how to use their equipment properly.
Edited by DEAN0, 27 April 2010 - 17:06.
#6 jasc1988
jasc1988
    Briskodian
  • Members
  • PipPipPipPipPip
  • 3,550 posts
  • Car:vRS
Posted 27 April 2010 - 22:08
they usually align the car to the steering wheel, they should fix the wheel in place (straight) then align the car to this!
take it somewhere else!
#7 thebloyn
thebloyn
    Briskodian
  • Members
  • PipPipPip
  • 391 posts
Posted 07 May 2010 - 23:06
ok had new tyres, alloys refurbed, cambelt and service on my newly aquired fabia, the stearing could be out due towork wishbone bushed according to my (trusted) mechanic, you can move the front wheels about, theres a fair bit of play in them, he showed me the new uprated bush for them
Is this likely to sort the issue and theres nothing else he could say with certainly that it was.
#8 R1chard
R1chard
    Slowly goes...
  • Members
  • PipPipPipPipPip
  • 2,123 posts
  • Car:Fabia Monte Carlo tech TDI
Posted 07 May 2010 - 23:45
My steering wheel is off centre since I had my console bushes done, it was perfectly straight beforehand, I've lived with it for ages now so I'm not really that bothered !
#9 mannyo
mannyo
    Now where's that petrol station
  • Super Moderators
  • 22,885 posts
Posted 08 May 2010 - 06:12
Duff bushes will cause all kinds of geometry issues which may only become apparent when driving. The alignment should always be redone after any suspension work and preferably a 4WA.
#10 rum4mo
rum4mo
    Briskodian
  • Members
  • PipPipPipPipPip
  • 3,368 posts
  • Car:B8 S4 3.0TFSI + 6R C0 Polo 1.2TSI 110 + 6J Ibiza 1.4 SC
Posted 08 May 2010 - 22:24
I agree fully, strangely it was when my VW dealer changed the ARB (also involves dropping the cross member), that my wife's Polo ended up with the steering wheel "not straight" - she lived with it for 6 months until I got Cupra bushes fitted and the indie re-aligned it (4WA) correctly.
#11 convictvrs
convictvrs
    Finding my Feet
  • Members
  • PipPip
  • 59 posts
Posted 09 May 2010 - 15:14
They do the alignment of the wheels while the steering wheel is dead centre.If it isnt dead centre it will be out after adjustment!!
