Car won't start any ideas?
Recommended Posts
Mk2 vrs Tfsi
Started fine this morning for the drive to work but I went to it later the only light on the dash was the door open light. All other electrics work fine but it just won't turn over.
I thought maybe the immobilizer so am heading back to work to try another key but I doubt it's this as at least some engine lights would show, also taking vcds.
Link to comment
Share on other sites
Frazzled ECU?
It maybe worthwhile taking the battery completely off, leave it for 30' then put it back on, see if it's a glitch in the system (Don't forget your radio code though!)
Took battery off, still wo't turn over, also tried other key.
Here is a scan, it doesn't look good for the Ecu :(
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1Z0 820 047 D
Component: Climatic PQ35 010 0301
Shop #: WSC 00000 000 00000
3 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
01316 - ABS Control Module
013 - Check DTC Memory
01314 - Engine Control Module
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004848514
Coding: 018C0F030004140000110D000000000000087F075C0000
Shop #: WSC 24064 210 13409
Part No: 1Z2 955 119 C
Component: Wischer 020407 022 0601
Coding: 00055223
Shop #: WSC 24064
4 Faults Found:
02403 - Terminal 15 for Interior
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 146341 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 146341 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 146341 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 146341 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
Shop #: WSC 73430 790 00000
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 C HW: 1Z0 920 912 C
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4140397
Coding: 0003401
Shop #: WSC 25071 576 92323
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 070407F1000571
Coding: 3D0F034007001303
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000628
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 1K0-959-433-46.lbl
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 80D002007F2D8505485B861004CC
Shop #: WSC 25032 576 88380
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
1 Fault Found:
01312 - Powertrain Data Bus
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000628
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0034
Revision: 00019000 Serial number: SKZ7Z3G0168430
Coding: 0000402
End ---------------------------------------------------------------------
Link to comment
Gut feeling is that's a fuse or relay. If your ECU, ABS and Airbags are all unreachable then I suspect that something powering them has failed.
Link to comment
Thanks Ben, I was hoping you would answer. I will check out the manuals for the relay and pray it's not the Ecu.
Link to comment
i'd check the battery under load, re-charge and try again 12.1v looks a tad low for a fully charged battery to me. I had similar issues a while back and it turned out to be the battery. It was showing 12.2 volts, but once you put it under load, zilch! Swapped for a known good battery and away we went! Much cheaper to try this first than either a dealer or new ECU.
Just remember if it is the battery you will still have fault warning lights on the dash until you have driven it for a while (can't remember which of them) some one will be able to advise you :thumbup:
Link to comment
But I only have one light on the dash and that's the door open light. I would have thought a dead battery would still display all the lights.
Link to comment
Check out the Terminal 15 power control relay - that's a probable cause of your difficulty.
Thanks I will take a look and possibly order a new one, I read a bit about this through google search. I presume it's in the engine bay but iirc there are about 3 relays any idea which is the correct one?
Link to comment
Not necessarily, there maybe enough juice to put the lights on, but not a high enough current to turn the engine & close the requisite relays to get it to turn.
What I'd like to know is why are we still dealing with silly fuses, when they are so out of date? Surely we should be dealing with MCBs by now!
Link to comment
Ok will put jump leads on tomorrow and see if any change :thumbup:
MCBs would be very nice :yes:
Really wouldn't advise jump leads.
MCB's are seldom used on cars because fuses cost about 0.01p each. MCB's are much more expensive!
Link to comment
Thinking about it I have just got back from a three week holiday and the car started up no problems at all surely a dud battery would have flattened by then?
Link to comment
Its the leftmost one on the power control board IIRC. Its relay B1. Check out the feeds to it (switching feed to the coil when ign turned on and permanent feed). You should hear it click when ign on.
Link to comment
Thankyou will have a good listen :yes:
I just wish my car were outside now to try it :S
Link to comment
Checking the Golf Haynes manual I may have hit gold!
The Drive train canbus controls airbag control unit, abs unit, Ecu and steering control unit. Thats pretty much all it controls on my car and all of those have no comms on my fault code list. I now need to find out what controls them.
Edited by vRSMart
Link to comment
Update:
Ben and Hauptmann you were correct, It was actually an ignition relay, one of two installed under the dash with the number 460 on top.
Took to local Indy
Price for relay: 8.38 +2h labour + fault scan + vat = £162.69 ouch!
Cheers for the help :thumbup:
Edited by vRSMart
Link to comment
Thanks for the update.
Result :thumbup:
£162 may seem a lot, but just think how much it could have been if it was the ECU etc...
Exactly and also if the garage was rubbish and took days to find the fault at my expense :o
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
