Octavia No start problem
martziniuk
Recommended Posts
Hi,
I've already posted a similar post in the Mk2 Octavia section but I think I will get more coverage here.
I drove to work yesterday no problems but four hours later the car wouldn't start. There were no lights on the dash except the door open light, all the other electrics work fine but it won't turn over at all.
I towed it to an Indy today but would like some opinions on the fault codes please. Here is a read out from VCDS.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1Z0 820 047 D
Component: Climatic PQ35 010 0301
Shop #: WSC 00000 000 00000
3 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
01316 - ABS Control Module
013 - Check DTC Memory
01314 - Engine Control Module
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004848514
Coding: 018C0F030004140000110D000000000000087F075C0000
Shop #: WSC 24064 210 13409
Part No: 1Z2 955 119 C
Component: Wischer 020407 022 0601
Coding: 00055223
Shop #: WSC 24064
4 Faults Found:
02403 - Terminal 15 for Interior
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 146341 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 146341 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 146341 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 146341 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
Shop #: WSC 73430 790 00000
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 C HW: 1Z0 920 912 C
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4140397
Coding: 0003401
Shop #: WSC 25071 576 92323
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 070407F1000571
Coding: 3D0F034007001303
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000628
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 1K0-959-433-46.lbl
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 80D002007F2D8505485B861004CC
Shop #: WSC 25032 576 88380
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
1 Fault Found:
01312 - Powertrain Data Bus
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000628
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0034
Revision: 00019000 Serial number: SKZ7Z3G0168430
Coding: 0000402
End ---------------------------------------------------------------------
Link to comment
Share on other sites
It looks like a power supply problem to the drivetrain ECUs to me. The engine, ABS, airbag and steering ECUs cannot be reached, so it could be a relay, fuse, earth, wiring or a central electrics controller fault.
Link to comment
Yep i thought it was drivetrain can bus problem but I didn't have a clue what controlled it. I checked all the fuses but thats as far as i got. Will find out today hopefully.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
