• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
My Chinese sat nav
Sign in to follow this
Followers 0
32 posts in this topic
OK folk, I feel I need to post this before any other fellow Briskodian gets stung too.
I decided to go for one of the Chinese sat nav/DVD players from eBay I'm not saying which seller as I will be contacting him very soon for reasons that will become very obvious.
The unit is described as suitable for Passat B6 and Octavia, and is fully CANBUS compatible.
Anyway, I received this yesterday, 17 days after paying in full for it, a value of $420 for the unit, plus an extra $50 upgrade for the inbuilt digital TV DVB-T. As promised,the unit arrived with green LED backlighting to match the car, and a Skoda splashscreen on start-up.
Apart from the mass of extra wiring which is VERY tight to accommodate behind the dash, the unit went in fine, and started up as planned. However, despite what may be advertised, it is not simply a case of plug into the existing VAG wiring loom. The VAG plug goes into the wiring supplied with the headunit, and because of the differences in this, the first problem was evident - 1. [b]THE BOOT MOUNTED CD CHANGER CANNOT BE CONNECTED UP[/b]
OK, so at first I was going to live with that, as it has full ipod control - WRONG - 2. [b]ALTHOUGH THERE IS A SOURCE SETTING FOR IPOD, ALL YOU GET IS THE WORD IPOD ON SCREEN AND ON THE MAXIDOT[/b] (yes it does communicate with the maxidot). You cannot control the ipod from the headunit touch screen.
Radio aerial - on the VAG loom and headunits, this is a FAKRA connector. On these, it is a standard aerial plug and socket, with a booster attached. - 3. [b]ALTHOUGH THERE IS POWER TO THE AERIAL AMP, IT IS IMPOSSIBLE TO LOCK ONTO ANY RADIO STATION[/b] so impossible to use the radio.
Whilst on the subject of radio stations, - 4. [b]THE UNIT IS DESCRIBED AS RDS - YES, EUROPEAN OR CHINESE, BUT NOT UK[/b], so it would be impossible to get radio station names showing, even if you could tune in to them
Inbuilt digital TV - 5. [b]THE SUPPLIED AERIAL IS UNAMPLIFIED, AND IT IS ALMOST IMPOSSIBLE TO GET MORE THAN A COUPLE OF TV STATIONS, AND THESE ARE TOTALLY UNWATCHABLE.[/b]. I've priced up a decent DVB-T antenna, and I'm looking the best part of £50 for an Alpine one.
Finally, the maxidot -- I got all excited when I first saw the maxidot display WELCOME and radio, CD/DVD details, and, as I said earlier, just showed IPOD, AUX and DVB, but 6. [b]VERY DISAPPOINTED THE MAXIDOT JUST SAID NAVI, AND THAT NO SAT NAV INFORMATION WAS RELAYED TO THE MAXIDOT[/b]
Also, on maxidot, 7.[b]ONCE SHOWING ANYTHING RELATED FROM THE HEADUNIT, THE MAXIDOT FROZE TOTALLY, AND EVEN AFTER SWITCHING BOTH HEADUNIT AND IGNITION OFF, THE ONLY WAY OF FREEING THE MAXIDOT WAS TO DO A RESET OF THE HEADUNIT[/b] - not good as it would wipe any stored radio and TV stations, audio settings, navigation favourites etc and reset the unit to factory defaults. And this happened EVERY time I tried it out.
Finally -8. [b]VCDS CODING - THE HEADUNIT IMMEDIATELY THREW UP FAULT CODES IN CAN GATEWAY, RADIO AND NAVIGATION CONTROLLERS WHICH WOULD NOT CLEAR EVEN AFTER PLAYING WITH ALL THE DIFFERENT VCDS SETTINGS[/b]
SO, there we have it it - that's my verdict on the Chinese headunits. I seriously regret getting rid of the Nexus now.
One or two folks did warn me, but never did I think things would be as bad as this.
Advice -- don't touch one of these with a barge pole
In future, I'm gonna listen to Simbo, Brimma and Pete8tch. But no, SImbo, I'm still not going for a Columbus.
EDIT:- Another thing I wasn't bargaining on was having to pay import duty/VAT to DHL before they would release the package to me. Nothing in the listing about that.
Mike (now with original Skoda Stream unit working perfectly in the car) Edited by mikeholroyd
Share this post
Link to post
Share on other sites
Sounds like similar issues to the ones some people in Australia have had. Let's see if it manages to flatten your car battery after a couple of days of not driving.
Share this post
Link to post
Mike
Sorry to hear about all the issues and that settles it for me, I won't be getting one of these. I still can't justify a Columbus though so I'll stick with the dash mounted Sat Nav (at least for the time being)
Just one thing though. No head unit will ever control a device plugged into the AUX input as it's just a stereo input so item 3 isn't really an issue, not that that is much consolation for you
Steve
Share this post
Link to post
[quote name='K1W1' date='30 June 2010 - 22:59' timestamp='1277935179' post='2029166']
[/quote]
It won't, it's out of the car ready to go back to Hong Kong!
[quote name='Raglits' date='30 June 2010 - 23:03' timestamp='1277935390' post='2029169']
MikeSorry to hear about all the issues and that settles it for me, I won't be getting one of these. I still can't justify a Columbus though so I'll stick with the dash mounted Sat Nav (at least for the time being)Just one thing though. No head unit will ever control a device plugged into the AUX input as it's just a stereo input so item 3 isn't really an issue, not that that is much consolation for youSteve
[/quote]
Corrected! and post edited, thanks
Mike
Share this post
Link to post
I'm really sorry to hear about this Mike...........
...........now will you stop taking the p*ss out of my (non) maxidot :wonder:
Share this post
Link to post
[quote name='Brimma' date='30 June 2010 - 23:12' timestamp='1277935929' post='2029182']
[/quote]
When was the last time I did that :giggle: Months ago. Its your grille I've been taking the p*ss out of recently :rofl:
Anyway, I wouldn't have the maxidot in my car if it wasn't for you.....
Will try to get to the meet on Sunday, if you could bring that chrome grille please? Ta!
Seriously, wish I'd listened to you, mate. Hopefully I'll get it refunded, otherwise, it's going on ebay to sell myself. However, I would not want a fellow Briskodian to buy it.
Mike Edited by mikeholroyd
Share this post
Link to post
Would you like to say which brand of headunit you purchased. There are numerous companies in China making these and they are not all the same.
I am currently using two units (one in a Fabia II and the other in an Octy II) and am reasonably happy with them.
They do not communicate with the Maxidot nor with the CD changer (which is not really a problem since they take SD cards and USB stick etc).
However radio reception is fine, and DVB-T (in my local area) is actually surprisingly good and I get a more or less perfect picture with the supplied antenna when parked. When moving the picture will break up, but this is normal with DVB-T unless you go for some fairly advanced antenna technology.
iPOD control is a bit clunky, but it works.
Overall, for the money paid, I would buy again.
Fitted in April and not had problems with flat battery, error codes or anything else so far. Edited by Hauptmann
Share this post
Link to post
[quote name='Hauptmann' date='30 June 2010 - 23:41' timestamp='1277937693' post='2029217']
[/quote]
There's absolutely no branding on either the head unit, the packaging, the box, or the instructions. All that's on the box is "special car DVD player"
Here's a picture of the unit
Mike
Share this post
Link to post
Well its 'special' all right.
Sorry to hear of your woes Mike, its a lot of dosh to not work as it should :no:
Is the manual also in that god awful chinglish?
Share this post
Link to post
[quote name='Rhoobarb' date='01 July 2010 - 00:09' timestamp='1277939355' post='2029244']
[/quote]
Yip. :giggle:
Share this post
Link to post
They are as useful as a chocolate teapot, but they do make for hilarious reading Edited by Rhoobarb
Share this post
Link to post
OK been in touch with the seller, and he wants to know if the radio is the same size as the original and if things would work OK if he sent me "wires specific to VW"
Have requested refund, also want return postage of around £40, and import duty of £15 paid, as I've already paid post for it to get from Hong Kong to here. If the item was incorrectly listed as OK, I don't see why I should be penalised for its return
Awaiting the sellers reponse
Mike
Share this post
Link to post
Just setup a paypal dispute if you paid by that. They will always go in your favour and auto refund you and the postage.
Share this post
Link to post
[quote name='jrw' date='01 July 2010 - 12:22' timestamp='1277983358' post='2029482']
[/quote]
You have to try to enter into negotiations with the seller first before you go down the dispute route, even if you paid with Paypal
Share this post
Link to post
Just had email back from seller, he's agreed to take it back for full refund, awaiting confirmation that includes return post and import duty as well.
Mike
Share this post
Link to post
[quote name='Brimma' date='01 July 2010 - 13:17' timestamp='1277986652' post='2029550']
[/quote]
Has done now, so just make sure you log it before the deadline to do so expires. Many vendors try and delay things so that you do pass this deadline and can't get a refund.
Share this post
Link to post
[quote name='mikeholroyd' date='30 June 2010 - 21:27' timestamp='1277933262' post='2029111']
[/quote]
What is the reason why you wont go for a Columbus, are they not very good?
Share this post
Link to post
[quote name='bertie1' date='01 July 2010 - 13:55' timestamp='1277988921' post='2029580']
[/quote]
Between £450 and £500 second hand, plus cost for a CANBUS upgrade as well. Very nice units, but way too pricey for me.
Mike
Share this post
Link to post
I'd be surprised if the seller refunds your import costs, but hope he does.
Share this post
Link to post
[/quote]
He had done by emailing to send it back - you always start a dispute as soon as you can - ive never had a problem with paypal before.
Share this post
Link to post
Just as a matter of interest why didn't you go to one of the factories direct? They are quite a bit cheaper than the Ebay resellers and you can still buy via PayPal and get buyer protection. I went to Timelesslong and they were very helpful with prompt replies and pretty good English.
I don't recognise the unit in the picture. There are some units that are known to work well and are discussed on the German China-RNS forums.
Share this post
Link to post
It's very difficult to tell many of the units apart as the one here looks very similar to another 'better' one but with no proper model numbers it's hard to search on them or find decent information.
John
Share this post
Link to post
Might be a bit late replying on this one... I think I dodged a bullet as I was going to get one from China as they do look really good and full of features. God myself a 2nd hand MFD2 which will hopefully be here for the weekend.
Had to order a new trim too, should be around £15 then some kind member in Hinkley said he would code it to my car with the CAN3.
Maybe it's not a Columbus but at least it will work better than those crappy ones from China
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
