Locate Octavia Glow Plug Relay
  • Please log in to reply
22 replies to this topic
#1 Paulfitzg
Paulfitzg
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 12 August 2010 - 14:46
I am trying to find where the glow plug relay is on a 2003/2004 skoda octavia - any ideas?
My problem is that the glow plug light comes on but goes off after a second even when the engine is cold. I have replaced the glow plugs and would like to try replacing the relay also.
Paul.
#2 trundlenut
trundlenut
    I am the God of Hellfire!
  • Members
  • PipPipPipPipPipPipPip
  • 10,404 posts
Posted 12 August 2010 - 15:28
Assuming it's a mkI you need to remove the trim that is directly above the pedals on the underside of the dashboard, then if you look up into the dash you will see a number of relays - the glowplug relay should have 109 printed on it and it's probably grey. You should be able to reach up and remove it, note which way round it is fitted and replace with a new one.
Could also be a probelm with the coolant temperature sensor. Also at the moment it is nowhere near cold enough to make the glow plugs come on. You could try unplugging the CTS and see if the glow plug light stays on (should be about 20 secs with the CTS unplugged).
#3 al bundy
al bundy
    Briskodian
  • Members
  • Pip
  • 49 posts
Posted 02 September 2010 - 04:18
109 isn't glow plug relay, but Coolant temperature senzor could be the problem.
#4 trundlenut
trundlenut
  • Members
  • 10,404 posts
Posted 02 September 2010 - 08:09
errr, yes it is!
#5 Paulfitzg
Paulfitzg
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 24 September 2010 - 16:17
Still having difficulty with this issue. I have tried the following;
1. Replaced glow plugs
2. Replaced relay 103 and 109
3. Removed cable from cooland tank
The problem still exists. When I turn the key the glow plug light comes on and goes off after about 2 seconds. It is not heating long enough so starting the car is difficult. Thanks for the help so far. Any more suggestions would be welcomed.
Regards
Paul.
#6 rwbaldwin
rwbaldwin
    Briskodian
  • FREEDOM
  • 6,258 posts
  • Car:Octavia TDi 110
Posted 24 September 2010 - 18:41
When you say cold, is it below 5 degC?
If not then the glowplug system should not operate and what you see is normal.
#7 Paulfitzg
Paulfitzg
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 26 September 2010 - 13:28
It was below 5C this morning and the glow plug light still went out after 2 secs. If I disconnect the coolant sensor it goes out after 2 secs also.
#8 rwbaldwin
rwbaldwin
    Briskodian
  • FREEDOM
  • 6,258 posts
Posted 26 September 2010 - 13:47
From memory, the tell-tale in the dash is fed from the glow-plug relay (180?), so if it was dead you wouldn't see a 2 second delay. It would go off at the same time as the other lights
#9 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • PipPipPipPipPipPipPipPip
  • 35,856 posts
  • Car:Fabia Saloon 20vt, Citroen Motor Caravan
Posted 26 September 2010 - 15:18
errr, yes it is!
109 is the main power relay for the engine ecu.
#10 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • 35,856 posts
Posted 26 September 2010 - 15:21
Regards
Paul.
Coolant temp sensor isn't in the header tank, that's the level sensor. The temp sensor is in the coolant hose above the gearbox.
#11 Paulfitzg
Paulfitzg
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 26 September 2010 - 17:31
Sounds difficult to a access. Should I be able to get at this from the engine compartment or should I go at it from underneath.
#12 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • 35,856 posts
Posted 26 September 2010 - 20:29
From up top, right hand side of the cylinderhead.
#13 Paulfitzg
Paulfitzg
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 10 October 2010 - 13:10
Still having problems unfortunately.
So far I have replaced the glow plugs, glow plug relay and coolant temperature sensor. The glow plug light still goes out almost immediately when i turn the key. Lots of difficulty starting in the mornings, have to turn key 5 or 6 times to get some heat into plugs.
I did notice that if I remove the cable from the CTS the glow plug light stays on for 10 second or so and car starts fine. Anyone got any ideas?
Thanks to everyone for the help so far.
Paul.
#14 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • 35,856 posts
Posted 10 October 2010 - 13:16
Did you fit the correct coolant temp sensor?
#15 Paulfitzg
Paulfitzg
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 10 October 2010 - 13:26
Looks the same as the one I took out. Got it from main dealer who located it using the chasis number.
#16 rwbaldwin
rwbaldwin
    Briskodian
  • FREEDOM
  • 6,258 posts
Posted 10 October 2010 - 13:36
Take a look inside the plug. Corroded contacts or crud between the contacts will cause the CTS to read high. The two wires go straight back to the ECU, so there isn't much more to check.
What was the actual temperature, when you tried to start the car? Was it below 5decC?
#17 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • 35,856 posts
Posted 10 October 2010 - 13:48
Im probably betting there is nothing wrong and as yet its just not cold enough for the glow plugs to operate. You dont say what engine it is but tbh the glow plugs dont really do much. I suspect your difficult start is another issue.
Any fault codes?
#18 Paulfitzg
Paulfitzg
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 21 October 2010 - 18:52
Still trying to resolve this issue unfortunately. The car is a Type 1U Octavia. I have replaced glow plug relay, glow plugs and coolant temp sensor. Glow plug light just stays on for about 1 second even though temperature is below freezing.
I am getting the following error from the computer
Address 01: Engine
Controller: 038 906 012 HA
Component: 1,9l R4 EDC 0000SG 4922
Coding: 00002
Shop # WSC 31480
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-00--
#19 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • 35,856 posts
Posted 21 October 2010 - 19:08
That means the coolant temp sensor is open circuit or disconnected.
You changed the sensor down the side of the head so I'd make sure the plug is on properly. If it is then the wiring needs to be checked back to the ecu.
#20 Paulfitzg
Paulfitzg
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 21 October 2010 - 19:10
Thanks for the reply, Do I just check the cable for wear ant tear of is there a way to check using a multi meter?
Paul
#21 rwbaldwin
rwbaldwin
    Briskodian
  • FREEDOM
  • 6,258 posts
Posted 21 October 2010 - 19:18
Assuming you have done #16, you are probably looking for a short circuit or water ingress (probably at the ECU end).
#22 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • 35,856 posts
Posted 21 October 2010 - 19:21
Open short to positive normally indicates a blown fuse or something open circuit.
If it's shorted to earth the wording changes, same with a resistive fault.
#23 rwbaldwin
rwbaldwin
    Briskodian
  • FREEDOM
  • 6,258 posts
Posted 21 October 2010 - 19:54
TBH, I don't think OP's problem is due to the CTS or glowplugs. My guess is the fault code was logged when the CTS was unplugged as a test. Surely, if it is o/c, the glowplug light would be on for longer than one second.
I started my TDi (AHF) at -1.5degC without waiting for the glowplug light to go off (first cold morning - forgot to wait) and whilst there was a slight hesitation, it only took a second or so.
My guess would be another issue such as fuel pump timing.
Edited by rwbaldwin, 21 October 2010 - 19:55.
