• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Cost of a Front wheel bearing fitted ?
Sign in to follow this
Followers 0
18 posts in this topic
Does anyone have an idea of how much a new front wheel bearing would cost inc fitting?
for my 2002 1.9tdi Fabia
Rough idea would be great :)
Share this post
Link to post
Share on other sites
[quote name='Gti Fly' date='17 August 2010 - 14:26' timestamp='1282051577' post='2076460']
[/quote]
Unfortunately the hub/bearings and ABS sensor ring are supplied as one piece and needs pressing out and in.
I was quoted between £150 and £200 per side supplied and fitted depending where you go.
Then add the cost of tracking afterwards
Share this post
Link to post
You could remove the complete hub assembly yourself, and trot it along to the garage with your new bearings etc, and get them to replace ??
Mark bottom swivel joint out before removal from wishbone, to assist replacing back into original position on wishbone, minimizing tracking error.
Good luck.[img]http://ww1.briskoda.net/forums/public/style_emoticons/default/emoticon-0148-yes.gif[/img] Edited by giandougl
Share this post
Link to post
No adjustment on the bottom ball joint so wont move.
You have to be very carefull if using a press rather than the propper puller kit, there is a ring mounted on the bearing that must sit correctly in the hub.
Share this post
Link to post
[quote name='giandougl' date='18 August 2010 - 08:39' timestamp='1282120775' post='2077328']
Mark bottom swivel joint out before removal from wishbone, to assist replacing back into original position minimizing tracking error.
[/quote]
Isnt tracking controlled by the track rod ends? Edited by vRSsunroof
Share this post
Link to post
[quote name='vRSsunroof' date='18 August 2010 - 11:27' timestamp='1282127254' post='2077438']
[/quote]
YES - but if any part of the suspension moves in relation to the track rod ends ( bottom ball joint, strut top mount, consol etc ) - the tracking will be out. Edited by DEAN0
Share this post
Link to post
Just had mine done again after I had a non-genuine one fitted. The ABS pickup ring failed after me giving it the beans exiting a roundabout. With a Courtesy Car Sinclair Skoda charged me £210
Share this post
Link to post
[quote name='Gti Fly' date='18 August 2010 - 01:32' timestamp='1282091563' post='2077203']
holy moses
[/quote]
lol best reply ever!
Share this post
Link to post
[quote name='DEAN0' date='18 August 2010 - 10:42' timestamp='1282128147' post='2077453']
[/quote]
[size="6"]YES[/size] But so will the camber! :smirk:
Share this post
Link to post
But the only thing that can move is the subframe and the track rod end so if neither are touched which they won't be when removing the hub no alignment will be altered.
Share this post
Link to post
[/quote]
My front wheel bearing could not be removed from hub by Skoda Dealer ,£532 for extra parts and labour!!!
Share this post
Link to post
[quote name='AndyPandy' date='19 August 2010 - 18:02' timestamp='1282237326' post='2079129']
[/quote]
Had a similar issue, ended up getting 2nd hand hub carriers and replacing the bearings in them first, then fitting them to the vehicle
Share this post
Link to post
£550?!
omg I'm gonna die if the skoda dealer tell me that.
It's really annoying, it's starting to make a very distinct wheel bearing noise pretty much 70% of the 30mile drive to work.
I took it under warrenty back to Skoda who could not diagnose the fault, they suggested it was tyre noise. I swapped the tyres around as they suggested and took the car back to them again, and low and behold, the car won't make the wheel bearing noise on any of the roads near the garage. Very very annoying, but sadly very true.
Now the warrenty has expired this week, I'm gonna have to stump up the cost of the wheel bearing job sooner rather than later.
Share this post
Link to post
Can you remove the hub and leave the bottom ball joint in the wishbone? If you can this will not alter the camber at all, if you do not adjust the trackrod end, the toe will not alter.
Share this post
Link to post
[quote name='Jim H' date='19 August 2010 - 22:10' timestamp='1282252256' post='2079465']
[/quote]
As I mentioned earlier, the wishbone is not slotted. The holes for the ball joint are round and the same size as the bolt so not adjustment is possible.
Share this post
Link to post
[quote name='Lummox' date='19 August 2010 - 22:23' timestamp='1282252983' post='2079480']
[/quote]
Thanks. :thumbup: I'm sure someone on here, on a different thread, mentioned not to touch these bolts as it may effect camber. I need to replace the bearings on my mothers car (the rumble sounds like a bearing) so will at lest be removing the hub. I will probably mark the ball joint just to be safe (as Haynes suggests).
The rumble seams to get noisier on right had turns. Will this more than likely be the left (Near Side) bearing? Edited by Jim H
Share this post
Link to post
Hello Jim H
Not necessarily so, with bearings (usually fitted with inner & outer) in the wheel hub, any could fail !!
Determine which side is the noisy side and replace that offender.
Have a front passenger with front windows down and create noise will soon isolate offending side. Edited by giandougl
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
