• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Tyre inflation with Nitrogen
Sign in to follow this
Followers 0
32 posts in this topic
While applying the stone chip protection film to the rear doors of my Yeti on Friday afternoon I discovered a screw through the tread of the passenger side rear wheel :doh:
At this point I was glad I'd spent the money on a full size spare (matching alloy wheel and tyre carried upside down in the boot) as it was too late to go anywhere to get it sorted and I had plans on the Saturday visiting parents that didn't include chasing around getting it sorted.
Anyway to get onto my question - I called into a tyre place near my parents on the way home and they were able to repair it which was good news - just threw it back in the boot for now as I was in a rush, when I got home just fileing the receipt away and noticed it says its been inflated with Nitrogen... why? I presume theres supposed to be some kind of benefit as I was charged £1.75 for this, but its new to me.
Can I still check the pressure correctly with a tyre pressure gauge it its not full of air, and if it needs pumping up, thats just going to be normal air I'm adding, so again, what was the point?
I'm hoping one of the knowledgeable people can explain this please?
Cheers,
Share this post
Link to post
Share on other sites
[color="#ff00ff"]I had this done to a set of tyres last year and it made absolutely no difference at all in either wear or economy (I should add it was done for free as I knew the fitter). I am told trucks notice a difference in wear rates, but as Nitrogen is roughly 80% of the air anyway, I reckon that mother nature gives me a pretty good deal to start with :D [/color]
Share this post
Link to post
[quote name='RallySimon' date='01 November 2010 - 11:50' timestamp='1288612257' post='2154504']
[/quote]
While I wouldn't claim to be particularly knowledgable about it, the reasons given are usually less variance in tyre pressure with temperature changes, and a slower rate of "air escape" from the tyre.
Of course, normal air is ~78% nitrogen anyway, so I'd suspect you wouldn't notice the difference in a normal road car...
Share this post
Link to post
I have seen photos of trucks in Nth America ( or Australia) with a externally plumbed central tyre inflation system "running" on Nitrogen.
Seems yes less varience with temps, and for the umpteen thousand mile per year usuage, a significent saving, incl less downtime (I presume)
Share this post
Link to post
The clowns at Costco made a big deal when they fitted my tyres.
Shame they under inflated them so badly that by the time I had them at the correct pressures it was pointless, as well as damaging 2 of my wheels but that's another story. :swear:
Share this post
Link to post
Had that done a few years back on my tires.
More confortable, less road noise
The tires looked good when they were changed ( they just had tread wear)
Puting nitrogen, airplanes and Formula 1 use this, the air inside the tire losses alot % of humidity, meaning long lasting tire and no downgrade on the rubber like the sidewalls becoming cut and lossing bits.
Also heat exchange control.
Share this post
Link to post
Nitrogen in tyres for road cars is snake oil!
Reason it is used is because it is cheaply available at high pressure in cylinders so you don't need the hassle of an air compressor with the associated noise, maintenance and water removal.
It is good for aircraft tyres as it is moisture free so it doesn't condense and freeze inside the tyre at high altitudes - I know our winters can be cold but...
Useful for consistency of heat/pressure characteristics where minute changes in tyre pressure will transform the handling of an F1 car - not really a must for road cars!
Slower deflation? - No! Rate of deflation depends on size of gas molecule. That is why kids' baloons filled with hydrogen deflate so quickly. Nitrogen is the smallest of the molecules of the main constitiuents of air so draw your own conclusion.
Reduced degradation cos no oxygen in the tyre? Ermm... the tiny bit inside the tyre is as nothing compared to the amount outside.
It is a marketing ploy! A money making scheme! Don't be suckered in!
Share this post
Link to post
RallySimon - any chance of your description of fitting those protection foils? Easy / Difficult et cetera?
Share this post
Link to post
[quote name='eccleshill' date='01 November 2010 - 13:59' timestamp='1288619968' post='2154696']
Slower deflation? - No! Rate of deflation depends on size of gas molecule.[/quote]
No it doesn't. Despite oxygen and nitrogen being roughly the same size and density, oxygen permeates through rubber much quicker (approximately twice as fast).
Share this post
Link to post
Yes, if you choice was O2 vs N2 for tyres you'd go with N2 of course, I cant imagine anyone using O2 for their tyres though!
Regarding air vs N2 then the difference isnt as big, hence N2 isnt much more use in a road car. You'd never notice the difference unless its a racing (F1) car etc.
Share this post
Link to post
[quote name='Keith Lard' date='01 November 2010 - 15:14' timestamp='1288624492' post='2154789']
Regarding air vs N2 then the difference isnt as big, hence N2 isnt much more use in a road car.[/quote]
Indeed, it'd probably be better to check the air pressure every week or two with a normal airline than to rely on pure-nitrogen filling to maintain the pressure (after all, if you've got a dodgy valve you'll lose any gas that's in there!).
Share this post
Link to post
[quote name='robmawer' date='01 November 2010 - 14:57' timestamp='1288623428' post='2154769']
[/quote]
If that is true then even more reason not to fill with nitrogen. If the oxygen leaks faster than the nitrogen then the nitrogen content will increase over time as oxygen leaks out preferentially.
However in the real world 3/5 of bu66er all escapes anyway. In 3yrs with my last Octavia the only time I added any air to the tyres was in winter as the temperature fall caused the pressure to drop, then let a bit out in summer as it went the other way. I think you loose more air checking the pressure than you lose through leakage.
Share this post
Link to post
[quote name='eccleshill' date='01 November 2010 - 15:30' timestamp='1288625425' post='2154808']
If that is true then even more reason not to fill with nitrogen. If the oxygen leaks faster than the nitrogen then the nitrogen content will increase over time as oxygen leaks out preferentially.[/quote]
This is probably going to take a lot more time to achieve than just filling with nitrogen in the first place though.
[quote]I think you loose more air checking the pressure than you lose through leakage.
[/quote]
Most likely, yes...
Share this post
Link to post
The Nissan GTR famously has its round bits filled with Nitrogen as standard. You could knock me over with a feather if anyone but a driving god on the 'Ring' would be able to tell the difference. On a Yeti - excellent though the handling is, total overkill.
Share this post
Link to post
I've only heard of Nitrogen fills being used for track work, certainly would never bother with a road car.
Share this post
Link to post
[quote]That is why kids' baloons filled with hydrogen deflate so quickly. [/quote]
I believe you mean Helium.
Hydrogen would be interesting inside party balloons though, particularly near birthday cake candles. Lots of little Hindenburg disasters :rofl:
Share this post
Link to post
[color="#ff00ff"]the fitter who did mine said that the oxygen leaked out of the tyre much faster than the nitrogen. I pointed out that if I kept topping up my tyres with air and only the oxygen kept leaking out, I would effectively end up with tyres that where almost entirely filled with nitrogen anyway. He wasn't impressed :D[/color]
Share this post
Link to post
[/quote]
Hi
How well did the alloy wheel and tyre fit into the spare wheel well?
I'm under the impression it won't because its wider than the standard spare, i.e. 225 rather than 195 and raises the boot floor by about 30 mm.
Fred
Share this post
Link to post
[quote name='eccleshill' date='01 November 2010 - 16:40' timestamp='1288626051' post='2154822']
Here is wha the AA have to say on the matter
http://www.theaa.com/motoring_advice/safety/filling-tyres-with-nitrogen.html
[/quote]
My local garages uses 'Uniflate', as do Demon Tweeks. Here is their info as to the whys and wherefores - http://www.uniflate.com/
Personally I have had my tyres filled with nitrogen for quite a few years and experience the benefits of more stable pressures under all conditions.
Share this post
Link to post
So, if you keep your tyres at the correct pressure, there is not much point in going down the nitrogen route, by checking them on a regular basis, at least weekly.
Mike
Share this post
Link to post
Thanks for all the replies. Nothing to get excited about then, I'll just check it the same as all my other air filled wheels and pump it up as and when needed. Glad it didn't cost much extra!
[quote name='allena' date='01 November 2010 - 14:17' timestamp='1288621075' post='2154718']
[/quote]
I didn't find them difficult to fit but then I've done that sort of thing quite a few times before as its the same as applying vinal vehicle graphics, which I've had plenty of on former rally cars and sunstrips on the top of the windscreen of most of my recent cars, including this one.
Make sure its spotlessly clean, then apply slightly soapy water to bodywork, peel it off the backing, lay it on the now wet area, more wet soapy water on top, slide it around until you're happy its in the correct place, then use the supplied rubber squeegee to smoothly and carefully force all the water and air out from behind it, and then leave to dry/set overnight (in the garage in my case). They did come with an instruction sheet which basically said the same thing.
[quote name='Fred_Bristol' date='01 November 2010 - 17:06' timestamp='1288631201' post='2154946']
Hi
Fred
[/quote]
You're right, the full size 225 doesn't fit properly into the wheel well as it won't go fully under the plastic lip behind where the latch fastening point is. I have left the normal floor in and just put it upside down on top of the carpet to one side of the boot. I have a large plastic bowl trimmed to fit perfectly inside it which is full of all sorts of nik-naks like foot pump, torch, few tools etc, and then an old towel is laid over the top of it all which is about level with the edge of the boot. Theres plenty of room to put stuff to the side of it or on top of it, certainly more than enough boot space for me, but with the peace of mind of the full size matching spare when needed (like it was this weekend!).
I did actually buy the alternative floor kit as you get the jack and wheel brace with it too, but having tried it out with this full size wheel, I decided to go without the raised floor as it took up far more boot space than the above described layout.
Cheers,
Share this post
Link to post
[quote name='bahnstormer vrs' date='01 November 2010 - 18:03' timestamp='1288634610' post='2155039']
[/quote]
http://www.uniflate.com/benefits-of-nitrogen-tyre-inflation
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Well we all believe that don't we. What a splendidly scientific demonstration of the benefits of nitrogen. Just look how quickly my air-filled tyres will deflate. Better stop every 100 feet or so to check the pressures then.
Case for the advertising standards methinks!!!
Share this post
Link to post
[quote name='eccleshill' date='02 November 2010 - 08:57' timestamp='1288688243' post='2155636']
[/quote]
That's a quality webiste, made me chuckle!
1. Better handling and road holding
2. Reduces tread wear and increases tyre life by up to 25%
3. Correct inflation pressures reduce puncture risk by up to 33%
4. Reduced rolling resistance improves miles per gallon by 2%
5. Improved pressure retention
I notice a distinct lack of any technical reference for these quotes! 25% increase in tyre life?! What a load of ar5e.
Good old air (78% N2!) will do me just fine. Edited by Keith Lard
Share this post
Link to post
[quote name='Keith Lard' date='02 November 2010 - 11:25' timestamp='1288697127' post='2155804']
25% increase in tyre life?! What a load of ar5e.[/quote]
[i]Up to[/i] 25%. Which includes any values from 0-25, so they're not lying... :D
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
