• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Wing mirror glass and cover removal
Sign in to follow this
Followers 0
6 posts in this topic
Hi
I need to replace the mirror glass on my octy II (2005) However the heated element cables are really short and it looks like I may need to remove the shell/case. I've looked on this site but can't find any of the links to a more pictorial guide that actually work.
Can anyone help with clear instructions of a working link to a pictorial website.
Share this post
Link to post
Share on other sites
I cannot remember exact details, try this: the glass will prise off with care, and then you should be able to disconnect the terminals from the back of the mirror. If not, you will be able to see several screws, one of which is at an awkward angle and these will release the front cover. Sorry I cannot be more specific, almost a year since I did this job.
Share this post
Link to post
The cover is just clipped on with 3 clips, to access them remove the mirror by gently pulling at the sides and the clips holding it in place should just release, once the mirror is lose the clips are obvious.
Share this post
Link to post
I have a prob with the glass - I broke it by gently prising it off. Wanted to do this to check the heated element connections as it wasn't working as well!!! I have stripped and rebuilt a Golf 5 mirror before with no probs, but the octy is being a sod!!! I have order a replacement mirror but due to the heater connection being so short I wanted to remove cover before removing mirror to get better access to them.
I try lifting if I can get to the clips from the front side.
Share this post
Link to post
My car is an Octavia 2 and I certainly remember that I had to unclip the mirror first and then remove the cover which was retained by at least 2 screws. I was actually trying to get access to the indicator bulb in the housing.
The mirror wires on your car should be long enough, perhaps need released or pulled a bit.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
