• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Continental Driving - Headlight adjustment
Sign in to follow this
Followers 0
6 posts in this topic
Hi
I've seen the link to the vRS website detailing how to adjust pre-FL headlights for driving on the continent, and I'm aware that if you've bi-zenons this can be done via maxidot.
However, is it possible to adjust the facelift halogen headlights for continental driving?
Share this post
Link to post
Share on other sites
[quote name='Rab-k' date='24 January 2011 - 23:18' timestamp='1295875081' post='2252305']
Hi
[/quote]
the occty does not have bi-xenons (pre-FL or FL)!!
yes, if u do have xenons with maxidot, then u can set it via the maxidot to [b]"tourist mode"[/b] for intercontinental driving.
i don't think non-xenons (halogen) have this. correct me if i'm wrong.
Share this post
Link to post
[quote name='ian-inhome' date='25 January 2011 - 11:19' timestamp='1295954345' post='2253851']
I set mine to flat beam as per instructions on this forum. No problems
[/quote]
Still none the wiser.... "flat beam"... where do you find that?
Share this post
Link to post
Rab,
Try this thread...
http://briskoda.net/forums/topic/187734-european-headlight-adjustment/
Your set up (facelift, standard halogen, non-maxidot) can be altered for continental driving.
Flat beaming is basically as it sounds; sliding a lever on the back of the headlight flattens the light beam to avoid dazzling oncoming drivers when driving on the right.
As per the above thread it requires removal of the headlights but it is supposed to be a quite straight forward DIY.
One word of warning, this is a temporary measure for short periods such as holidays etc. If you plan to stay over seas for any length of time you'll need new LHD headlights.
Share this post
Link to post
[quote name='silver1011' date='25 January 2011 - 21:37' timestamp='1295991437' post='2254721']
Rab,
Try this thread...
[/quote]
Excellent! Thanks for the link. Off to Sweden for a week this summer so will only be needed for short period. My Passat headlights have a switch for this but I wasn't sure if the FL Octy had similar; sounds as though they do.
Cheers!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
