Telephone errors
darrenw
Recommended Posts
I've recently received my Ross-Tech cable (Thanks to Gendan) and have done a fault code scan. Recently I changed my factory-fit bluetooth module (rSAP only) for the rSAP and HFP module - part 3C8035730A.
Has anyone come across these errors before? Usual Google, here and Ross-Tech searches are not very enlightening.
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 A HW: 3C8 035 730 A
Component: Telefon 007 0078
Revision: -------- Serial number: 35909603039933
Coding: 020000000000000000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_SK35.rod
VCID: 21673241814F
7 Faults Found:
9457427 - Negative output audio channel for speech/telephone
B104F 13 [009] - Open Circuit
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 17
Reset counter: 67
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
9457937 - Telephone baseplate
B1051 11 [008] - Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
9457939 - Telephone baseplate
B1051 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 15
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
9458193 - Control Module for Cellular Telephone
B1052 14 [024] - Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
13636352 - Control Module Not Coded
U1013 00 [024] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12608768 - Infotainment CAN Bus (SAE Bus E): Performance
U0065 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
12608512 - Infotainment CAN Bus (SAE Bus E): Malfunction
U0064 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Link to comment
Share on other sites
Errors from when you were connecting it up? Look that way.
They're priority 4's, clear them then see if they come back. If so you'd be looking at either coding (easy to check) or a wiring error i'd think. If they don't come back after clearing, it'll just have been from when you first connected the module. The report these types of errors.
Link to comment
Thanks. I'll clear them at the weekend and see what happens.
It shouldn't be a wiring fault as it was a straight under-seat module swap and nothing else. Just the alarm errors now. :)
Link to comment
If it's working as expected then I'd say errors during the swapover as well. Was the ignition on at any point during the time the original module was removed, and the new one plugged in?
Otherwise it could be that the new module is coded slightly differently and you'll need to make some changes. But I've not heard of that being required from those who've done the swap.
Steve
Link to comment
Cleared the errors this morning and 4 came back. OK, that's an improvement on 7. The unit does work OK, apart from the occasional locking up when pairing. The engineer in me says if there are errors, there is a problem...
The latest scan produces
Address 77: Telephone Labels: 3C8-035-730-A.clb
Control Module Part Number: 3C8 035 730 A HW: 3C8 035 730 A
Component and/or Version: Telefon 007 0078
Software Coding: 020000000000000000000000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_UHVPremi A01005 (SK35)
VCID: 21673241814F
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 12528 km
Date: 2016.14.19
Time: 09:31:48
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 12528 km
Date: 2016.14.19
Time: 09:31:48
B1052 14 [009] - Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 12528 km
Date: 2016.14.19
Time: 09:31:48
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 12528 km
Date: 2016.14.19
Time: 09:31:48
Link to comment
A bit more googling and thanks to fourtitude.com
http://forums.fourtitude.com/showthread.php?5045985-GSM-Module-coding
I found the long coding for it.
All I have now is
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 12528 km
Date: 2016.14.19
Time: 09:31:48
Checking the additional values, it's the left side that is open, which is odd as sound does seem to come from there.
Link to comment
By changing the code I was able to get rid of this error, but this coding disable the A2DP so you lose the music play functionality.
here is the code
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668284095
Coding: 0200000001010110
Shop #: WSC 10034 663 88717
ASAM Dataset: UHVNA A01007
ROD: UHVNA_SK35.rod
VCID: 3261E2FAD6EF
No fault code found.
-Pramod
Link to comment
All I have now is
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 12528 km
Date: 2016.14.19
Time: 09:31:48
Hi Darren, what did your long code end up as???
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
