Window Regulator Clip Problem
Recommended Posts
Hello, I'm really frustrated because of window regulator clip breaking and window dropping inside door after, it broke about 10 times in a 3 years period, all doors suffered from this.
I don't know whats the problem that causes it to break so often.
Any help will be appreciated.
Edited by HeNz
Link to comment
Share on other sites
Rail looks dry and seems to require greasing, (knowingly/ visually seeing it has a plastic runner attachment), couldn't do any harm by lagging it with grease???
Link to comment
If it happens that often there is a problem.
It could be...
the motor is faulty and doesn't switch off when the window reaches the limit.
the tension is incorrect - there is a block with multiple slots that adjusts the overall regulator tension.
the tension is incorrect - the 'stall springs' are too weak - the motor should stop before they are fully compressed.
the regulator is faulty - does the slide bind on the rail? does the window sometimes stop half way?
the window binds in its rails
Link to comment
I know VW updated the clips to metal items however unsure if these would fit an Octavia....
This is brilliant, I hope someone know if they can fit in Octavia or not
Sorry for not stating that the photos are not mine, I found them online.
Sorry for not stating that the photos are not mine, I found them online. I did try lubricating rails before but didn't help much.
It could be...
1-the motor is faulty and doesn't switch off when the window reaches the limit.
2-the tension is incorrect - there is a block with multiple slots that adjusts the overall regulator tension.
3-the tension is incorrect - the 'stall springs' are too weak - the motor should stop before they are fully compressed.
4-the regulator is faulty - does the slide bind on the rail? does the window sometimes stop half way?
1- Tested, and its fine.
2 & 3- I don't actually understand them really well, I don't replace the clips by myself. But all doors suffered from the clips problem so either the clips plastic design was a bad idea from Skoda or something gets expanded by sun heat (Egypt) and causes problem ... just my thought.
4- No never stopped halfway
Thanks all for replying and still any help in this problem is appreciated.
Link to comment
  • 3 years later...
Hi,
I know the main  post is three years old but someone may stumble across it looking for a solution.
Both clips on my Octavia Mk1 estate failed after taking the whole lot apart I came to the conclusion that the Skoda/ VW clips were not really up to the mark so after a bit of searching came across this site
http://tgdesign-uk.yolasite.com/
Now Thomas being a Skoda owner, like me wasn't overly pleased with the design, so designed his own ones which are far more substantial. I have fitted one so far and it works a treat.
A bit more expensive than the OEM ones but I think worth it
Tony
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
