• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Innotec Turbo Clean
Sign in to follow this
Followers 0
25 posts in this topic
I used this the other day on my TDi110 and I'm left in no doubt whatsoever that it works. Although specifically designed and intended to cure the sticky vane problem on VNT turbos I decided to give it a go on a routine service. I followed the instructions in the kit and the result is that the turbo power now is greater and much more evenly distributed. I'd recommend it to anyone who suspects they have the dreaded sticky vane problem, or even a slight overboost on their turbo.....
http://www.innotecworld.com/c-1064-turbo-clean-set.aspx
Share this post
Link to post
Share on other sites
I had this recommended by Simon Coe of CCC Technology. He showed me before and after VAGcom logs from an engine with a sticky vaned turbo, before it would overboost and make no attempt to return to the correct level, but after treatment it worked as it should.
May I ask how much this stuff costs?
You need to register on the website to see prices.
Share this post
Link to post
As a bit of a non-believer, I think you should demo this to me.... on my car :giggle:
What do you do? I guess it goes on the air side rather than the exhaust gasses side?
Share this post
Link to post
the add talks about 'Turbo Clean 1 ... dissolve carbon deposits', which I assumed could only build up on the hot side ?
sort of looks like carb cleaner in a fancy applicator to me ...
Share this post
Link to post
I paid £39 direct from Innotec. The kit comes with three products and full instructions.
Remove the exhaust frontpipe from the turbo and using the gasket as a template mark out the holes in the card supplied in the kit. Refit the frontpipe gasket to hold the card in place over the turbo outlet. You will need to make a small hole in the card, and push the flexible tube through it into the exhaust turbine. Spray in half the contents of Turbo Clean 1 and operate the actuator link to work it around. After 10 minutes spray in the rest of the Turbo Clean 1. This will turn to a gel and effectively dissolve soot and carbon from inside the variable ring. Every so often work the actuator link again. After one hour remove the frontpipe gasket and card from the turbo outlet and allow the Turbo Clean 1 to drop into a drip tray. Spray in Turbo Clean 2 using the same flexible pipe to rinse out the remaining Turbo Clean 1. Re-assemble the exhaust frontpipe.
Pour the contents of Turbo Clean 3 into the fuel filter is possible. This is preferrable, but if you can't then tip it into the fuel tank. Start the engine and allow it to run. The Turbo Clean 3 is a very powerful cleaner that will remove carbon deposits from the injectors, and finish the turbo cleaning process. It's easy to do and well worth it if you have a turbo with the sticky vane problem.
Share this post
Link to post
Application is with exhaust downpipe off. You apply cleaner, leave it for a while, exersise VNT mechanism, apply alkali neutraliser and it comes with a fuel additive.
It's a bit like using the Mr Muscle technique, with something to make it a bit safer for the cat, followed by a high dose of Millers. Heck of a markup really but a lot cheaper than turbo off and manual clean.
R-Tech in Hinkley used to do the Innotec Method for about £90 all in. I believe that they now advise customers to remove and properly clean the turbo as Innotec turned out to usually only offer a temporary improvement (plus once they started doing it they saw what Innotec left behind). I think they now do turbo removal and cleaning for a little over £200. Edited by Uriel
Share this post
Link to post
[url="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350470008499"]£38.66, fleabay[/url] :thumbup:
Share this post
Link to post
Mr Muscle Oven Cleaner and Millers, plus a bit of cardboard and a tube could be had for £15 though...
Share this post
Link to post
[quote name='snow_muncher' timestamp='1308170756' post='2422677']
[/quote]
I see they stole the pictures from here http://www.technologie-entwicklung.de/Gasturbines/VNT15-Turbo/body_vnt15-turbo.html
No way would Innotec would clean a completely stuck turbo as shown and no way would it lead to a fully cleaned turbo as shown in the other picture.
It can free up a turbo if the deposits have not completely hardened and you manage to spray the stuff on every bit of the crud. I have seen a good number of turbos where the owner has used this stuff and it has stuck again.
Share this post
Link to post
[quote name='Uriel' timestamp='1308171559' post='2422691']
[/quote]
are you going to do a youtube video demonstration for us ? :rofl:
Share this post
Link to post
[quote name='snow_muncher' timestamp='1308172010' post='2422700']
[/quote]
Nope. Instructions here though: http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/107121-un-sticking-your-tdi-vnt-turbo-vanes.html
[i]Caveat emptor[/i] and all that...
Share this post
Link to post
[/quote]
I used my mothers kitchen table and sink when she was out one Sunday morning :giggle:
Control ring:
[img]http://www.matthewames.co.uk/briskoda/20101112_turbo_clean/P1000656.JPG[/img]
Vanes:
[img]http://www.matthewames.co.uk/briskoda/20101112_turbo_clean/P1000661.JPG[/img]
Share this post
Link to post
[quote name='mbames' timestamp='1308173440' post='2422746']
[/quote]
Out of interest, did you reuse or replace the bolts in the turbo?
Share this post
Link to post
[quote name='Uriel' timestamp='1308174307' post='2422767']
[/quote]
...and is your Mother speaking to you again yet? :rofl:
Share this post
Link to post
[/quote]
I replaced all the gaskets (inlet manifold, exhaust manifold, exhaust pipe, oil return), but all the nuts / bolts / studs were reused.
[quote name='ExAudiSi' timestamp='1308174744' post='2422784']
[/quote]
Yes.... surprisingly :rofl: She much like her oldest son :giggle:
Share this post
Link to post
Awwww man, I missed the Bishops Sutton fundraising dance yet again!!!
Share this post
Link to post
[quote name='demonufo' timestamp='1308258797' post='2423859']
[/quote]
and the Barn Dance too.... shame on you. :dull:
Share this post
Link to post
I had a Mondeo TDCi in today. The customer had bought his own Innotec Turbo Clean kit and asked us to give it a go to see if it would free his turbo which had become stuck. The engine management lamp was on and the overboost code was stored. At first I thought that the actuator motor was seized because it would not move, but after I had disconnected the link I quickly discovered that the fault was inside the turbo unit and it was seized solid. On a Mondeo the exhaust outlet is below the turbine and so spraying in the cleaner this way would not have worked, and so I decided to separate the two halves of the turbo unit and gain access to the variable geometry. When I pulled it apart I found the vane ring was full of soot and corrosion. I sprayed the turbo cleaner all around the best I could and in no time at all it had loosened. The cleaner was dropping off the vane ring together with all the crap right in front of my eyes. I worked the vane ring back and forth and it became more free than I could've ever imagined. After a while I sprayed the second can all around to rinse away the remains of the first. The result was a spotless vane ring that moved very easily and effortless. I didn't do any scraping or use anything other than the turbo clean product. I took the car up the road when I had re-assembled it and it drove like it had a new turbo. I am highly impressed with the results. I took a couple of photos but I can't figure out how to get them onto this site. If anyone can tell me how to do it I'll post them up.
Share this post
Link to post
http://img64.imageshack.us/img64/8443/22062011355.th.jpg[/IMG][/URL][/img]
Would've preferred it a bit larger, but there you are. Edited by Railroad
Share this post
Link to post
[quote name='mbames' timestamp='1308768040' post='2430111']
That does look nice and clean.
[/quote]
Well I'm the first one to be critical of these kind of products mbames but I tried it on my TDi110 and the turbo power is more even and smoother, and on this Mondeo the inside of the turbo was transformed from a mess to looking like brand new. I would've never believed it but I am impressed with this stuff.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
