Warning: Fabia Door Leaks
Recommended Posts
Following seeing this thread I've become a little paranoid. Presently (well since I got the car a couple of months ago) the carpets haven't ever been wet, the door cards are bone dry and there's no smell or condensation in the car however I have noticed every now and then there will be a small patch of water sitting on the black rubber door seal when I open the door. No bigger than a couple of inches and all 4 doors do it but as I said not damp carpets or anything else. What do people think? Do I have a leak?
Most likely, take the door card off for the one which is leaking the most.... the leak is extremely obvious to spot. If dry you should still see a residue trail from the water.
Link to comment
Share on other sites
Yep I'd agree, mine was obviously leaking and when I took the door card off the door carrier seal fell out so was obviously the issue.
It is a relatively easy fix. Took me no more than 1 hour for both rear doors.
Link to comment
Just popped out to the car this morning put a couple of jugs of water into the gaps at the base of each window. After opening the doors all 4 are bone dry no water on the black door seals.
Link to comment
Ben, I don't think that's a great test, reassuring as it probably seemed. I'm in the same position, new-to-me (well the missus really) Fabia, thought I didn't have this issue, but then...it sat out in the heavy rain for a couple of days last week and I too had the wet seals, but not carpets (rear only I think). I don't think a short sharp test will necessarily reveal the problem if the door-carrier seal is just 'oozing' a bit rather than really boogered, if you see what I mean. If a lot of water goes by quickly, it'll go straight out of the drain holes at the bottom of the door and cause not much bother. Only if there's a steady trickle of moistness coming down the inside of the carrier for a fair while will you see much getting past the seal. I think. I've resigned myself to addressing this, and have already bought some trim clips and a tube of 'gutter and drain' sealant.
Link to comment
I agree with WIno this isn't a very good test to do. The foam seal takes time to absorb the water like a sponge then leak, I have noticed movement between the carrier and door acts as a pump to squeeze the water through the seal so this only happens when you are moving or winding the window or trying to dry it out to reseal :)
My latest attempt I have ripped all the foam I can out with a knife because it is obviously porous now (due to rivited carriers) and filled the gap with gutter tape and sealant. For good measure I have also covered over the top with duck tape with is supposed to be waterproof.
It would be a good idea for VAG to come up with a sticky plastic like used to be on the inside of old car doors to seal the inside from the elements.
Link to comment
  • 4 weeks later...
Do skoda do this repair as a good will ?
I won't say "No" - but I didn't try asking and others have reported not even getting it under the Skoda Used Car Warranty. It may have been done under the original new car warranty in a few cases. My car had already been done and botched when I bought it - but the garage assured me it hadn't been done under warranty.
Link to comment
I brought my vrs of a private seller sold as seen but ive had problems very minor cheap fixes. Mine is a 55 plate and i cant believe this is happening and car with this fault covered by warrenty or not should be repaired free of charge by skoda. This is there fault not ours
Link to comment
OK - but you try convincing them. Even contacting Skoda UK is difficult.
Edited by DRJ
Link to comment
Depends. It is not that hard to get to and do but as you will see on here; there is no guarantee it will seal. I have done my offending door twice and it looks like last owner did them all previously. There is no guarantee either that getting a dealer to do it will be any better and it will cost you of course.
Link to comment
Mine sealed first time, plenty of good quality sealant will help, really squeezed into the gap. I wouldnt use gutter and drain sealant as it never gets hard/rubberey just stays gooey and gets everywhere. Follow the guide on youtube.
Link to comment
Has anyone recently done the repair and can advise me weather its easier to pay at skida or attempt myself ?
Do it properly and it's easy. Don't do as someone had done on mine - add self tapping screws to better secure the carrier, then not seal the actual screws. I've done both rear doors on my 2007vRS and it's been perfect both times - the 2004vRS didn't need doing having screwed carriers. Make sure you use a decent sealant NOT silicone, and preferably one totally unaffected by water such as the Plumbers Gold I used.
Link to comment
Have you watched the video? It depends what you find. In my case there was some old sealant on the offside door so I peeled off as much as I could. On the other side it was "factory fresh" so I pulled out as much of the sealant strip as I could.
Before:
During - the sealant has been applied to the edge but not yet the self-tapping screws (which you'll probably not find) or the rivets:
Edited by DRJ
Link to comment
"whats the wooden spoon for" - the wooden FORK is to hold the door card up, since you don't take it completely off.
"how does the old sealent just give up" - I presume you're saying "Why does the old sealant fail?" - well in my case, as I said, the sealant hadn't particularly failed, though it was very thinly applied at one point; rather the water was coming through the holes created for the retro-fitted screws. No point in sealing it up if you don't stop all the possible moisture paths.
Link to comment
Good use of bbq tools :) i think im going to attempt this tommorow with a friend who is more mechanically minded :/ what sealant did you use ? And where sells it if possible please
Link to comment
Technically I wouldn't recommend the use of a wooden fork on a barbecue - but I would recommend Plumbers Gold from Toolstation, specifically since it cures when water's present, something silicone does not, and is much "cleaner" than gutter sealant which many also use successfully.
Link to comment
You'll also need door card clips as this topic mentions - Skoda have recently increased the charge for these from around 30p to around 60p.
Link to comment
Does anyone know the part number for the clips that hold the rear door cards on as I have broken a couple whilst removing them today :( and where can I get them from maybe trade part specialist ? Cheers
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
