MK1 vRS - Stage 2 R-Tech Tuned
Phil-W
Recommended Posts
Thanks, yeah you see a lot more silver or black ones with the MK1!
Another little job done, bumper trims were terribly faded and wouldn't clean up very well, so I bought a tin of Plastidip and gave them a couple of costs!
Not the best pic but you get the idea...
Link to comment
Share on other sites
Bought a tub of this stuff in preparation for doing the brakes...
The joys of having my mum work for Morris :D hopefully doing them this weekend weather pending, will paint the calipers too if the rain holds off!
Link to comment
Well, hit a stumbling block today. Got the DP out to check measurements to see if I needed any reducers or clamps on it. I bought it cheap and had a suspicion something may have been not quite right, turns out the Flexi pipe is nackered. At first I thought the light was coming from the Lambda sensor hole but after covering it up, it seems not!
And the split...
I can get a new Flexi for £12ish so in going to call a local powerflow dealer and see how much they will charge to replace the old one!
Also 'cleaned' the airways with this cleaner, seems to have made it smell a bit fresher and can't complain for a quid!
Needed a cam belt sticker after loosing mine so hunted online and found a website that offered free samples, rude not to :D
  • Like 1
Link to comment
Got ready to do the brakes today, went to my 'rents house as my driveway is sloped and I don't like working on it!
Got the car in the air and wheels off, stripped off the retaining springs and went in the garage to find no socket or Allen key in the size I needed... Damn!
While the wheels were off I knew my horn needed sorting as the CAI fouled on it so I cable-tied it out of the way, got a piece of mesh and bent a temp bracket up! The outside temp sensor was just hanging as well so I bolted that back up...
When I tied the horn up I didn't think and left it pointing up, water got in so I got what I could out, will have to see if it's nackered it or not!
Gave the TB a clean as well, was very grubby when i opened it fully...
Before:
After:
Finally, whilst the front wheels were off I gave the calipers a coat of smooth green, better to do it now whilst the old discs and pads are in!
Link to comment
Finished off the rear brakes today, found something else to change now though!!
And my bump stops...
Not too bad though, about £16 delivered for a new pair :)
Link to comment
Thanks Rob!
Got the new Pagid Discs/Pads fitted... My god, how awesome it is not to cringe as you hit the brakes and feel the steering wobble because of warped brakes!!
Link to comment
Had some great news today, well for me anyway!!
I contacted Milltek to see if I could pursue a warranty claim with the split flexi in the Sports Cat, wishful thinking seeing as I bought it 2nd had and you need to be the original purchaser for warranty claims.
They said they can supply a replacement flexi for £34 or so. I asked how much it would be to get it fixed and fitted to the car by them, they said they can't fit it to the car but they would put a new flexi in for the same price if I got it to them. Brilliant customer service IMHO, I was expecting a flat "no". I'll get it sent off next week, very very happy though, puts the sports cat at £140 now but it's still a bargain!!
Link to comment
I think the guy I bought it from just saw the flexi blowing and decided to get rid rather than repair, very pleased and can't fault Milltek's customer service at all, even their replies via email have been within the hour every time!
Not Charlie, a guy called Jon? Very helpful!!
Link to comment
Air con problems this week, changed the pressure sensor & found there was no gas in the system.
Found the cause of the problem, inflicted by who ever fitted the Intercooler, started by filling the system with Nitrogen, pressure held to start with but then started dropping off.
Took the front end off to try and see where it was leaking...
Re-filled the system with nitrogen, sprayed some fairy liquid about and spotted the culprit..
Clamp part of the jubilee clip was chaffing on a pipe on the condenser and wore a hole through...
Phone pic but you can just about see the pin hole...
Tried to solder it but heating it up created another hole, new condenser time! Happy we found the leak though!!
Link to comment
I always try to park as sensibly as possible, tuck the car into a corner spot somewhere, it usually takes me 10-15 mins to find a spot I'm happy with, evidently ruined in a split second by someone parked in the neighbouring bay...
Luckily it hasn't dented and I have removed the mark with a bit of Autosol but Grrrrrrr!! :(
Link to comment
it's sooo annoying when people couldn't give a shiny ****e about their car so your's has no chance. I bought a new Mini Cooper D last year for her indoors and within a week there was a crease put in the rear quarter by some t*sser.
Link to comment
Have to say i'm very impressed with Milltek. Exhaust came back today, not only did they replace the flexi but they also reinforced the flange and included a new fitting kit, spot on job!!
Link to comment
Few bits been arriving in the post for the car...
New Condenser, Drier, Oil & Fuel filters and Rear Bump Stops.
Did the condenser and drier today....
Crash bar and front panel off, condenser disconnects from the radiator by 4 screws and a couple underneath. Quite time consuming as you need to be both careful and methodical.
Got it all back together, just needs to be re-gassed now. Then had a complete nightmare. Went shopping and got back, thought I would just pop the bonnet to check everything is ok... Nothing.
Little did I know that when you take off the front panel, the cable is prone to coming away from the mountings, making the cable useless.
Bumper off again, Intercooler and slam panel off again, engine under tray off. 3 hours later after some help from the father-in-law and he managed to get it popped open from under the car. 5 mins later it was back together and sorted out... Lesson learned!!
Mini service next and replace the bump stops before MOT.
Link to comment
MOT time today...
Passed with no advisories :D very happy. Tester said it is a very very clean car.
Going to service it next week and change the bump stops over.
Spark Plugs were ordered from eBay, when they came I had to pay £3 as postage wasn't covered, complained and had a full refund today so a full set of NGK's only cost me £3 :)
Next in the pipe line enhancement wise is to get the sports cat on, get a new spring for the 007P and then give R-Tech a call :D
Also need to get the air con tested and regassed now the new condenser rad is fitted!
Link to comment
Air con is now regassed and working, ice cold now :) the past couple of weeks haven't been much of an issue but I wanted it working for winter months to demist quickly :) Total cost for Air Con was;
£40 - Test/regas
£66 - Rad/Condenser
£15 - Receiver/Drier
£22 - HP/LP Switch
Moving on to today.. service time. Didn't have time to replace rear bump stops as the weather turned. Started off with the fuel filter. Presuming the date on the old filter (08/04/06) was date of manufacture but doesn't look like it have been changed recently...
No point in wasting what's left in the filter... :D
Oil next, old gunge..
And then spark plugs...
Didn't do the coolant as it was done a month or so back with the Cam Belt :)
Next job will be to get the rear bump stops fitted, change the gear box oil and get a better filter for the CAI :)
Link to comment
Tonight's work was fitting this...
Found £1 under the centre console, £64 now :)
Came from an Octavia so the rear cup holder still works...
And all done...
I thought £65 delivered was quite reasonable considering Golf Leather arm rests are £70+ on eBay and you would need to buy Octavia trim from the dealer...
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
