• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Alternator Problem
Sign in to follow this
Followers 0
2 posts in this topic
I've read a lot of the topics about alternator problems and I'm pretty sure its the alternator itself which is at fault but would like some reassurance before I buy a replacement. Just before I got home christmas day all of the electrics went, leaving me with just the engine running and the side lights so i managed to crawl the short distance left to home. I checked the voltage on the battery, 12v when the engines off and below 12 when running but no warning lights show up on the dash so it sounds like it might be the load sensor wire problem.
Tonight I tried having a closer look at it, all the cables seem in good condition so I turned the engine on and revved up past 3000 and the battery warning light flickers, then check the voltage, and its 13.5v. However within about 30 seconds the voltage has dropped back down to below 12 and no amount of revving can stir it up again. Does anyone think this sounds like a faulty alternator since all the cables look intact? I'm hoping for a 2nd opinion before I try buying a new one.
Share this post
Link to post
Share on other sites
[quote name='pocketmonkey' timestamp='1325018786' post='2623953']
[/quote]
i just had a very similar problem and it turns out it was the smart charging in the ecu but the ecu is repairable
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
