• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Where is the glow plug relay?
Sign in to follow this
Followers 0
4 posts in this topic
I'm having cold starting issues with my mk2 2007 vrs diesel estate. I've been reading the forum's many thousand posts on glow plugs etc. I've had the glow plugs changed, to no avail. I now want to test the glow plug relay, but I can't find it... People seem to talk about relay 109, but I don't seem to have one? I've looked under the dash, and in the under bonnet box.
Could someone point me in the right direction.
Many thanks,
Matt
Share this post
Link to post
Share on other sites
I think it might be under the fuse box in the engine compartment. don't know for sure or how to ID it better. HTH
Share this post
Link to post
Thanks, I've found a PDF online for a Jetta, Bora and Golf which looks like it show the procedure to get to the relay (or "automatic glow period control unit J179" as it calls it). Once the snow has cleared a bit, I'll investigate; if it turns out to be right I'll see if I can post a link to the PDF for future reference for others.
It does indeed show the relay as being under the fuse box, looks like you need to remove the battery tray, then slide it out.
Cheers,
Matt
Share this post
Link to post
Ok,
Have had a chance to take a look for the glow plug relay / control unit; and I found it...
These instructions are from memory, and are for my 07 vRS Estate (your mileage may vary)
You need to remove the battery, and the front ½ of the battery shroud, it has 2 small clips at the bottom and then slides upwards. The relay is located under the under bonnet fuse box, and slides out (towards the engine), the relay can then be unclipped. My relay has the following part numbers on it: “0 281 003 038”, “905”, “038 907 281 D” and “RB6”.
[IMG]http://i684.photobucket.com/albums/vv209/matthew-kent/Skoda/P1020343.jpg[/IMG] [IMG]http://i684.photobucket.com/albums/vv209/matthew-kent/Skoda/P1020342.jpg[/IMG]
Hope this helps anyone else looking for their relay. I've ordered a new one, but as I removed the battery it was showing signs of bulging at the sides so I'll be replacing that as well when the relay arrives...
Matt
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
