Changing headlight bulbs on a MK2 VRS
x4cs
Recommended Posts
bit of guidance please....
Ive popped the black rubber resin type cover off and i can see the bulb....
I want to know if i need to look out for any specific clips etc that release the bulb from the headlight enclosure before i go snapping something.
Thanks ,
Link to comment
Share on other sites
The bulb holders are very tight
If you see where the lugs of the bulb holder are located there is a small screw
If you loosen this screw the bulb holder turns very easly
After replacement tighten the screw
Link to comment
They're quite stiff, don't be afraid to use some force. I spent half hour on first one plus cuts & scrapes on my hand. Then got the knack and did the other in 30 seconds
Ha! Im in the same boat. Not quite half an hour on the first, but i was afraid of breaking it as i twisted.
Link to comment
Just changed my bulbs for something brighter, spent 20 mins trying to get it back in the wrong way! Thought I was careful not to get it twisted around. And I laughed when the lady in Halfords asked if I needed them fitting for me.
Link to comment
  • 5 months later...
Hi all,
I should be picking up my new VRS at the end of the month, I've got a question about the headlights and bulbs though.
I also own a Monte and the headlights were poor, so I bought these 'OSRAM NIGHTBREAKER PLUS H7 BULBS 90% BRIGHTER' and they are an improvement, now, looking at the new VRS in the brochure it appears to have the dark lenses like the Monte, do you know if it also has the same bulbs in as the Monte, if so I'll buy some new bulbs that can be fitted before I pick it up.
Thanks in advance.
Link to comment
  • 3 years later...
Having frightened myself out of changing bulbs,(due to bad press on getting old ones out),to ones with which I could see.I realised today I had,metaphoricaly,grown a pair and changed the bulbs in ten minutes!!
  • Like 3
Link to comment
They are quite accessible compared to many modern cars, but expect a lot of swearing trying to fit them. Especially in the dark and wet, not recommended!
The comment about Halfords, the one time I had bulbs fitted by them, they were....you guessed it, upside down!
Oh and single bulb in the black pack VRS for both main and dipped.
Edited by TeebsVRS
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
