• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Number Plate Light Bulb Fuse Blowing Constantly
Sign in to follow this
Followers 0
3 posts in this topic
Hi All,
A quick one.. my car passed it's MOT the other week no problem (thank God) everything fine which is expected as i've spent some dough on it in the last year.
Now coming home the other night my friend driving behind me said 'your rear bulbs are out' and to my surprise they were.. whipped the trims of the bulb covers (after much swearing + rounding of corroded self tappers) Both bulbs intact.
Fuse 4 in my fuse box 5A had blown.. which controls the rear plate bulbs. There was a small build up in the fuse holder of that fuse of some white gritty sort of stuff.. gave it a clean and replaced the fuse which immediately popped when I turned the sidelights on again.
Now I know it isn't to do with the washer pipe toward the rear (as this has disconnected at the washer bottle).. All I know in the rear is that my CD player stopped working after pushing it down too hard. I don't suppose the CD Changer comes off the same fuse?
Aside from that I'm stumped. Suppose I'm better of whipping the already rattling rear boot trim off the tailgate and checking for a poor earth or shorting of wires.
Anyone got any suggestions? I am an ex auto electrician so competent with testing tools.. I'm just being lazy and hoping someone else has had the same problem and can give me a starter for 10 before I start tearing the rear end of the car apart.
Cheers :)
Share this post
Link to post
Share on other sites
Somewhere there is a dead short to cause the fuse to blow immediately. I would check all the bulbs and bulb holders first, a poor earth will show up as a dim lamp.
Share this post
Link to post
Right.. got fed up in the end.. pulled the boot trim off belled out with my multimeter both sides of connector brown/black going to ground both sides.. no problem and no sign of the other violet/green wire going to ground either side.
popped a new fuse in with all of the bulb holders/harnesses loose with no problems whatsoever both bulbs working then keeping the sidelights on I decided to build it all up again and moving the wires back to their original position it blew again.. obviously rubbing somewhere but without another pair of hands wobbling wires whilst I bell it through I wont be able to find the location.
I will update as and when
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
