• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Felcia electrical problems.. 1.9d
Sign in to follow this
Followers 0
2 posts in this topic
Hello, I recently bought a 1998 Felicia 1.9d, really love it, but I am experiencing a couple of issues:
- The left hand dipped headlight seems to work intermittently, have checked the wiring around the actual lamp and everything seems fine there, sometimes it works, sometimes it doesn't, i have noticed that it tends to work more often when the car has actually been moving.
- The fan/blower/heater, whatever is the correct term, also seems to be operating intermittently, when it is working it is either full force or just a little. The temperature aspect works fine but the actual blower has been on and off since i bought the car..
the third enquiry I have is to do with the clutch/transmission, i'm not sure if it is even a problem, but there is a very noticible clicking sound whenever the clutch is engaged or disengaged, and often a slight rattle as i am travelling along.
Any help here would be very much appreciated as it would be really good if i could sort these problems out by myself rather than going to a mechanic.
Regards, Andrew.
Share this post
Link to post
Share on other sites
Heater blower - have a look on here about the brushes; a common issue is that they stick a bit, stopping power getting into the motor, or the springs can give up.
Other electrical issues - the fuse boxes on Felicias can give trouble, often because of the water leak that is common, so have a look at the fuse box (again, common thing on here, search for fuse box).
Gearbox noise is difficult with a description like that, but search for "fifth gear nut" or similar, see if that is what you're getting?
HTH
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
