New Badges fitted with pictures
Recommended Posts
So........ :blush:
The badges you purchased for your Combi will these fit the Mk2 Octavia FL 2010?
If so I will buy the same part numbers........... can you confirm please. :think:
Rick
Will be able to inform you tomorrow as I will be fitting them than.
I can say the wheel caps fit like a dream.
1978771_10201602707693888_946455957_n.jp
  • Like 1
Link to comment
Share on other sites
Replaced all the badges on my car with the Mk3 ones.
Before
After
Before
After
Wheel before
After
Link to comment
Looking good mate :)
So these part numbers are for the FL estate - is there a different part number for the rear hatch badge or is it the same? I want to fit to a mk2 2011 FL hatch.
Front: 1ST 853 601A AUL
Rear: 5JO 853 621A AUL
  • Like 1
Link to comment
Agreed they do look trick....... If they do fit the 'MK2 FL Hatch' I'll order a set tomorrow and get mine changed over too
Link to comment
The part numbers above are the part numbers I used for my 09 estate. From a skoda dealer here in belfast (ish). I am not sure if they fit the hatch.
Link to comment
I'm sure the front must be the same though? Saying this the front does not fit perfect, as in its the right size, but the grommets on the back of the badge don't line up with the holes. I snapped the plastic grommets off and just glued the bugger on. Beware also, the sticky tape on these new badges are worse than useless, so you will need to add an adhesive of your choice.
The rear, on an estate, is a perfect like for like swap. Holes and grommets match up, just pushes on perfectly lined up, with a bit of super glue for good measure! :)
Link to comment
The new badges ooze quality and are nothing like the old ones
They will not have the same issue at all.....
BTW These part numbers also fit the hatchback...perfectlly
Ahh good news :)
So you didn't have to break off the pins on the front as per comments above? And is yours a FL?
Link to comment
Hey guys
I'm still following this thread even though I fitted my badges to my 2012 Fl Vrs hatch some months ago now but am a little confused as to why people would still be ordering badges that the need the lugs breaking off the back to make them fit as if you see my. Previous post you do not need to order these as the correct ones for the Fl hatch have been available sometime now hope this helps
Well after reading every post on this topic for the last few months and still being left a little confused as to what would or wouldn't fit my 2012 octavia Vrs probably more down to me being a bit thick to be fair I ended up speaking to Rainworth Skoda who informed me that they now make the new front and rear badges for my exact car which have the lugs in the correct place and fit perfectly. I can now confirm this after fitting both new front and rear badges today. The part numbers were as follows
5J0853621AAUL
5J0853621AUL
Both cost £18.99 each delivered
Only took 2 days to arrive and look absolutely fantastic on my white car with black magic front grill hope this helps anybody that is still a little confused
Paul
  • Like 2
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
