New Badges fitted with pictures
Recommended Posts
Colour coded my grille surround and ordered up some new badges to finish the job off
Should get around to fitting next few days when it stops raining!
  • Like 2
Link to comment
Share on other sites
I found that on the Octavia, the front badge (1ST853601AAUL) fits better on the back than the "630" does.
The "630" badge is flat, the "601" has a curve to it. The tailgates on the Octavias have a curve too.
My Scout now has 2 x 1ST853601AAUL. :) :)
Both cars are pre-FL ('07 and '57)
This is a "630" on the back of the hatchback.....
.....and this is a "601" on the back of the estate (Scout).....
It should also be noted that the front fits on perfectly as it sits on a dome, but the back needs a bit of packing out as the new badges are a little bigger than the old ones, so they don't sit in the indent. I used 3 strips of 3M 1mm VHB tape and the above is the result.
It should also be noted that fitting both the front and back requires the plastic tabs to be broken off the new badges.
Edit: Correction, I have a 630 on the back of the hatch, it's the 630 that's flat, not the 621.
Link to comment
Can anyone confirm the following part numbers will fit a 2007 Octavia VRS Hatch:
1ST853601AAUL
5JO853621A
These are the ones I used on my 2006 hatch.
1ST 853 601 AAUL
5J0 853 621 AAUL
Link to comment
I too became confused about which of the front badges to buy and eventually settled on the following;
1ST853601AAUL
5JO853621AAUL
The rear was an easy fit, the old one being removed with the help of some fishing line and the new one being easily located with the pins at the back. The front, on the other hand, was much more difficult to remove and without the help of the locating pins, much more difficult to position accurately.
The job is done now and the new badges look much better than the old on my 2010 Octavia vRS Estate. I would be interested to find out if there is a proper front badge that is easier to fit as despite all of the comments written in this thread, there still seem to be some confusion over the correct front badge.
I bought a set of these, but I am not entirely sure that they are genuine Skoda parts.
http://www.ebay.co.uk/itm/4x-new-genuine-Skoda-Alloy-Wheel-centre-caps-Fabia-Octavia-Superb-Rapid-Yeti-/121302532178?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&fits=Car+Make%3ASkoda&hash=item1c3e31c052
Although they have a Skoda logo on the back, the moulding is not well defined and they were wrapped together in a single package without any labelling of any kind. They do fit, however and look okay, but I somehow wish I had spent the extra £5.00 on the real things from a Skoda dealer
Not to step on any toes but there is a correct front badge you can buy and fit the has the alignment points in the right place.
5J0 853 621 A (without the AUL after it) will fit the front of the Octavia 2.
Check eBay AND dealer for best prices.
Link to comment
1ST853601AAUL
5JO853621AAUL
I take it then just the A suffix of the 621 part is the rear and uses the two lugs?
Link to comment
To crystallise this once and for all, here are the CORRECT part numbers to fit the from and rear of the mk2 Octavia (pre-FL and FL)
5J0 853 621 A - front of the Octavia 2
5J0 853 621 AAUL -will fit the rear of the Octavia 2.
All locating lugs are in the correct position, and both badges curve the correct amount to fit the grille and bootlid. Simples.
  • Like 2
Link to comment
Thank you. I'll order some now.  :kiss:
:rofl:
Edited by amk2vr6
Link to comment
I'm not too keen on the 'Fashion Faux Pas - Fat Bloke' sticker that you've put in it's place though Alan! :giggle:
I see FUBAR was of a similar opinion!
I thought he was wearing a bra!!
Link to comment
Warning!
I ordered the 5J0853621A (without the AUL) for the front grill for pre fl Octavia 2 as it was recommended. I didn't want to snap the pins. The badge is actually 10 mm smaller than the original one.
Link to comment
Warning!
Yeah I noticed this while searching online. Its 8mm actually. 80mm as opposed to 88mm
However, I tried to order the A suffix, and the chap at TPS said they dont do them - they only do the AAUL part.
Still haven't bought any :)
Edited by amk2vr6
Link to comment
Yeah I noticed this while searching online. Its 8mm actually. 80mm as opposed to 88mmHowever, I tried to order the A suffix, and the chap at TPS said they dont do them - they only do the AAUL part.Still haven't bought any :)
Go for the 1st853601aaul, got it from ebay for 12.49
Carefully cut the pins to flush and just in case I put some double sided sticky pads into the centre of the badge.
Seller is silburyskoda2010
Hope it helps
Link to comment
Hope it helps
And just to confirm (again) this will fit front and rear of VRS hatch?
  • Like 1
Link to comment
Just bought these tonight. Hope they help in relation to pricing, etc.
6AD44C11-97C7-4A38-A6F6-5FD9393F2E26_zps
I have these fitted to my 2010 FL Octy. The rear is a perfect fit. The front you will have to remove the locating pins. And the wheel caps are spot on too.
Link to comment
Is your Octy the Estate?
Link to comment
So the wheel badges are part number 5JA 601 151
Front Grille - 5J0853621A (Curved and 80mm)
Front Grille -  1ST853601AAUL (Curved and 89mm)
For the Octavia Mk 2 Estate
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
