My key fob opens / closes another Skoda!
  • Please log in to reply
12 replies to this topic
#1 DanHam
DanHam
    Addict
  • Members
  • PipPipPipPipPipPip
  • 5,331 posts
Posted 19 June 2012 - 11:29
I have a 55 plate Fabia VRS. A woman in work recently bought a Skoda Superb on 06 plate. Now last night she parked quite close to me. When I was leaving work I went over and unlocked my car and hers unlocked too! When I lock mine - hers locks too!
I went back into work and asked her to come out side and explained and she thought it was a big joke until I proved her wrong. Her key does nothing for mine though.
Anybody else had this issue?
Any ideas??
I did take a short video in which you can kind of make out.
http://s735.photobuc...nt=b272aff9.mp4
#2 rwbaldwin
rwbaldwin
    Briskodian
  • FREEDOM
  • 6,258 posts
  • Car:Octavia TDi 110
Posted 19 June 2012 - 11:40
Does the key open the other car's door?
Are all the keys the ones that came the with cars?
#3 DanHam
DanHam
    Addict
  • Members
  • 5,331 posts
Posted 19 June 2012 - 12:08
What as in insert the key into the lock? I've not tried that.
I've only had my Fabia 4 weeks, she's had hers about the same amount of time.
If they are the original keys or not then I cannot answer that sorry mate.
#4 rwbaldwin
rwbaldwin
    Briskodian
  • FREEDOM
  • 6,258 posts
Posted 19 June 2012 - 12:16
Yes - try your key in the other car's lock.
If it does open the other car, then contact Skoda UK.
#5 gullyg
gullyg
    Advanced Member
  • Members
  • PipPipPipPip
  • 953 posts
  • Car:MK3 Octavia vRS Estate TDI
Posted 19 June 2012 - 14:24
From what I understand the fobs work on a rotating code produced from and algorithm and starting input.
There is only a limited number of possible codes these transponders can use so it is possible though unlikely you will be able to open someone else's car.
I'll try and find more info when I get out of work.
I wonder how this affects insurance. Presumably the steering lock won't work but you "could" take stuff out of the car if you were so inclined.
#6 Huxley vRS
Huxley vRS
    Uber Member
  • Members
  • PipPipPipPipPip
  • 1,923 posts
Posted 19 June 2012 - 14:28
Be interesting to know if the key is the same aswell as the coding.
Id be contacting Skoda UK with both reg numbers and the issue.
#7 Dark_Hero
Dark_Hero
    Charlie
  • FREEDOM
  • 7,766 posts
Posted 19 June 2012 - 17:09
Ask her if you could try to start her car too. Then definately report it to Skoda
#8 grr666
grr666
    Addict
  • FREEDOM
  • 8,146 posts
Posted 19 June 2012 - 17:57
Her cars central locking has learned your key.
Did this by mistake with our SDI and my old VW Bora.
Didn't bother changing it back as I sold the Bora to a mate
of mine.
I'd bet she was sat in her car with the engine running and the doors
locked at the same time as you had just got out of yours and zapped
it shut.
You're not the first.
http://uk-mkivs.net/...297/984027.aspx
Can be easily undone if you google it but you will need her co operation too.
Your key won't start her car or manually open the doors.
Just found you a useful link
http://www.autokeysq...ogramming-guide
  • Southy likes this
#9 anewman
anewman
    Briskodian
  • Members
  • 6,528 posts
Posted 19 June 2012 - 22:15
locked at the same time as you had just got out of yours and zapped it shut.
Sounds like a big security risk. So if you own a VW key, you can just look out for people starting the engines, locking the doors, and press your own button to gain access at a later date?!
#10 grr666
grr666
    Addict
  • FREEDOM
  • 8,146 posts
Posted 19 June 2012 - 22:34
Essentially. Yes. I only discovered it by accident myself.
But when I did some digging around on the web I soon found mention of
others with the same fault. As I said, I never bothered to try and rectify it
as I sold the paired car to a pal of mine anyway. But it seems easily reversible
if the little guide I linked works.
#11 TriggerFish
TriggerFish
    Enthusiastically miserable
  • Members
  • PipPipPipPipPip
  • 4,674 posts
Posted 20 June 2012 - 18:51
I had this like Gary with a mates Golf syncing to my Polo. Annoyingly, it knocked the Polos RCL out, so I had to recode it with VAGCOM. Think VW wanted about £45 to resync them!
#12 Coffin Dodger
Coffin Dodger
    Jimbo
  • Members
  • PipPipPipPip
  • 561 posts
Posted 20 June 2012 - 20:57
Works across the range, my mate has a VW Caddy van and a Lauren and Klement Octavia and can unlock the car and van with both sets of remotes, keys are different though and will not open or start the other model.
#13 DanHam
DanHam
    Addict
  • Members
  • 5,331 posts
Posted 20 June 2012 - 22:41
Sounds like a common issue then. I'm not to worried about it and don't really want to start fiddling with it tbh.
Thanks for the help!
