Where is the radiator fan relay?
Recommended Posts
Octavia 2 BKD engine code. I can not find the relay for the radiator fan and I never saw them working....non of them two! The climatronic is not working anymore and the system is full of gas!...HELP! :(
Link to comment
Share on other sites
I assume you have the two fan variant as it's a 2005...
Check fuse 54 in the E box. This provides power for the fans.
There isn't a relay as such - the fan controller in part of main radiator fan and controls both fans.
You need to get the car scanned for faults
Link to comment
I have done a scan and I think there is nothing wrong. I just change e fuse for the rear doors and I don't know what to do next. This is the result of the scan before to change that fuse for the rear widows, headlights washer and alarm. Can anyone see anything wrong in the result?
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBBE21Z Mileage: 134040km/83288miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HF    HW: 028 101 139 1
Component: R4 2,0L EDC G000SG 8658
Revision: 12345678    Serial number: SKZ7Z0E2851075
Coding: 0000072
Shop #: WSC 24059 576 91804
VCID: 6EFD19010007
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70     0105
Coding: 0000641
Shop #: WSC 73430 790 00000
VCID: 3FA3944517ED
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0304
Shop #: WSC 00000 000 00000
VCID: 3B5BE05503F5
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
Component: Bordnetz-SG     H34 0803
Revision: 00H34000    Serial number: 00000003025060
Coding: 418A0F020004140000110D000000000000087F075C
VCID: 3A55E5510CCF
Part No: 1Z2 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 73430
3 Faults Found:
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
01333 - Door Control Module; Rear Left (J388)
            004 - No Signal/Communication
01334 - Door Control Module; Rear Right (J389)
Address 15: Airbags        Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 K    HW: 1K0 909 605 K
Component: 04 AIRBAG VW8 024 0700
Revision: 07024000    Serial number: 00378D05XTV0
Coding: 0012340
VCID: 3449CB692EAB
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AK    HW: 1K0 953 549 AK
Component: J0527         036 0070
Coding: 0002042
VCID: 7BDB20554375
Part No: XXXXXXXXXXX
Component: E0221         007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 941 D
Component: KOMBIINSTRUMENT VD1 0914
Coding: 0007401
Shop #: WSC 25014 576 175503
VCID: 3851FF5932C3
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E    HW: 1K0 907 951
Component: Gateway         H09 0110
Revision: 09         Serial number: 27001051250124
Coding: 3D3F0740071303
VCID: 29772A1DF969
2 Faults Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 27
                    Reset counter: 61
                    Mileage: 133802 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:19:46
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 27
                    Reset counter: 61
                    Mileage: 133802 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:19:46
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
Component: IMMO            VD1 0914
VCID: 3851FF5932C3
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0166
Coding: 0000118
VCID: F4C98B69EE2B
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
            012 - Electrical Fault in Circuit
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 354FF66D25D1
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG             0301
Coding: 80F802007F2D8505485F861004
Shop #: WSC 25014 576 104585
VCID: 7BDB20554375
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component:     NGS n.mounted
Component:     IRUE No Answer
4 Faults Found:
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000118
VCID: F5CFB66DE551
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 A    HW: 01. 01. 03
Component: Radio FO3         0008
Coding: 0000402
VCID: 2C79D309F69B
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
VCID: 3D5FEE4D1DE1
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 3
                    Fault Frequency: 52
                    Reset counter: 100
                    Mileage: 147847 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:33:00
End ---------------------------------------------------------------------
Edited by Octavia MK1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
