• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
How to - Mk1 Octavia halogen - xenon conversion
Sign in to follow this
Followers 0
36 posts in this topic
Over the last few weeks ive been working on fitting DEPO xenon headlights to my Mk1 Octavia VRS. I looked at genuine units but seemed far too expensive just to have xenons. I took some pics as i was doing it so thought i would put a bit of a guide together incase anyone else would like to have a go :happy: Its my first guide, Ill try my best lol
Parts req
N/S & O/S DEPO xenon headights, Total cost around £100 on ebay
2 x original halogen looms(got some from scrappy to save mine) cost few £'s
2 x xenon looms(supplied with DEPO's)
H7/D2s xenon/HID kit,around £30 on ebay
H1 & H3 for fog/main beam, few £'s
Tools req
Side cutters
Soldering iron
Heat shrink to suit cable
Solder
Step one
Get your halogen looms and cut off the H4 connector, Its the white one in this pic. Leave the three wires around 100mm long(white, yellow and brown)
Step 2
Cut the long grey, white and brown wires from the xenon loom. These are feeds for fog light and main beam
Step 3
Remove the xenon loom from the light casing and insert haolgen loom(Connector just clips out)
Should have something like this
Step 4
Using sidecutters/wire strippers, strip the 6 ends of the wires.
Tin each end with flux cored solder.
Slide 20mm length of head shrink over each wire as far away from joint as possible(heat will start to shrink it if it gets too hot)
Step 5
Grab your HID kit, It has an input lead and output to bulb
I used a D2s HID kit so I cut the input plug off.
Strip the outer insulation to reveal a black and red wire.
Strip the ends of these two wires as prep as in step 4
Step 6
I decided to mount the HID ballast to the rear of the light casing. I just positioned the ballast in the best place, marked through, drilled and bolted with the bolts in the kit
Step 7
Solder the wires as follows
White ---- White
Yellow ---- Red(HID)
Brown ---- Black(HID)
Brown ---- Brown
Grey ---- Grey
Then slide heatshrink over the joint and heat
As seen in this pic
Step 8
Thats the loom done, Now just need to connect to the correct bulbs and screw the casing to the headlight :-)
Note- These have no adjustment motors fitted, I havent decided how i will do this. A few suggestions have been use cable ties tempory or make a new bracket for halogen motor.
Hope this is some help, Could have done with more pics but you get the idea
2 people like this
Share this post
Link to post
Share on other sites
i've recently went down this route but ordered my passengers side headlight to be informed they have ran out of stock, but can you update us with whats been going on in the last couple of months
1 person likes this
Share this post
Link to post
Did you have to modify the indicator stalk at all? I remeber I had to do this to my Audi (B5) to stop the HID bulbs going out when you use main beam as it's not very good for the ballasts for them to be clicking on and off all the time.
Just curious as I am thinking upgrading to HID as well.
Share this post
Link to post
its the negative thats switches the power so just bridge the 2 negatives
Share this post
Link to post
Just looking at the wiring, if it was negative switched surely bridging the negatives would iluminate both bulbs all the time?
After some research it seems the best way to achieve having the dipped beam on all the time would be to take power from pin 7 of the headlight switch to power the dipped beam rather than the stalk (just like the Golf does), as can be seen from this diagram http://mit.edu/dennis/www/vw/switch.html.
Has anyone tried this?
Share this post
Link to post
After some research it seems the best way to achieve having the dipped beam on all the time would be to take power from pin 7 of the headlight switch to power the dipped beam rather than the stalk (just like the Golf does), as can be seen from this diagram http://mit.edu/denni.../vw/switch.html.
Yes, did it on my previous Bora and on my Octavia. Ran a wire from the back of the light switch to the fuse box. I think that the wire at the fuse box end is yellow with a green tracer.
Edit - I believe that I connected to pin 8 though (used a wiring diagram supplied by VW).
1 person likes this
Share this post
Link to post
Cool thanks, well I've got ELSAWIN so I'll have a gander at the wiring and go down this route. Just received my depo lights so will have a crack at this soon!
Share this post
Link to post
do the depos not have adjustment facility? or no motors fitted?
Share this post
Link to post
they have the headlight adjustment motor mount, but not motors, i try'd retro fitting the old standard motors, but they dont fit in any way, so zip ties it was :D
But Beam pattern is Awesome, no more peps flashing me cause of hids in old headlights, and 100w fullbeam for the back roads, just awesome
Share this post
Link to post
so i wonder why the depo motors are different, how much are oe xenon motors i wonder, and would they fit?
Share this post
Link to post
I think I am right in saying that oe xenon motors have 4 wires and i believe work as a stepper motor as they continually adjust on the move. It is not that hard to fit original level motors, you just need a bit of patience, and lots of heavy things to throw when it doesn't go as you want. :rofl:
Cost of oe xenon motor is not cheap I'm afraid, but then nothing oe xenon is.
Share this post
Link to post
hi Phil, was hoping you would reply! so how far have you got? yes didnt think of that, kufatec sell the levelling kits iirc, i wonder if they include motors....(he leaves to go look at kufatecs site!)
Share this post
Link to post
ok no would be the answer to that then!
kit comes with wiring and levelling sensors, but not motors for the headlights, also they are about £350 for the kit!
1 person likes this
Share this post
Link to post
My lights are completely done, have now got a pair of headlampwash jets, and am bidding on a larger bottle and pump. Going to get jet housings sprayed when the weather gets more sensible, and the temperature eases off enough to let me bend in the cold to actually fit it all.
Share this post
Link to post
If you want to go the oe motor route, the part number is 1U0941295B and the price is - are you ready for this....................£55+VAT each. new halogen motors are £33+VAT each.
Share this post
Link to post
it's a joke, cause i badly want the headlight leveling motors in mines, but i kept the loom for the 3 wire headlight motor, just incase theres a retro fit job i can do
Share this post
Link to post
did you fit motors phil?
Share this post
Link to post
Yes, I have the halogen levellers in my lamps at the moment, although eventual plan is to go self level from an appropriate donor car at a semi sensible price. At least this way I have control of the beam direction when loaded. Look at Gee's thread, you swop over/modify the looms in the lamps to retain the correct loom-lamp connection, which lets you retain the wiring for the standard level motors. Just dont throw the depo looms away if you eventually intend to go self level like me.
Share this post
Link to post
nice one phil, would really like to see them with the motors fitted, fancy catching up one eve so i can take a squizz?
Share this post
Link to post
Sorry for delay in reply mate, they are at my son's team bodyshop at the moment - was using their plastic welding gear for another secret squirrel project, so did them there. seemed simpler to leave them there as they will be fitting and painting the bumper jets for me. Will pm you when they are accessible as they are burried behind a load of Focus panels at the moment :rofl: .
Share this post
Link to post
Hi you say loom just clips out just on with the same cannot get plugs out do they push in or outwards cheers.
Share this post
Link to post
was a bit of a pig for me to get the loom to fit properly so i did without the back covers atm
Share this post
Link to post
The plugs come out of the headlamps rather than pushing in if that makes sense, the lugs that hold the plug in run along the longer axis of the plug, and can be a little stiff to squeeze when they are new.
Play a hairdrier over the lamp for about a minute to soften the plastic strength of the plug and it gets a little easier, you can just get your fingers on the plug through the reflector opening in the lamp body.
All of this is hugely easier with the lamp out of the car and on a flat surface in front of you.
Hope it helps
Share this post
Link to post
i got them out in the end, just i dont have the headlight motors so tiewrap to hold at desired hight atm thats also an other reason i dont have the covers on
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
