Aero and economy mods, what have you done or have you thought of doing? What CAN be done?
Recommended Posts
Afaik you only have to have a rear view mirror in the car, however if you obstruct you view in this mirror by loading the car you then need the side mirrors to comply with the law. I did consider a mirror delete but finding a suitable one to go in the car is a pain. I was looking instead at fitting some more aero ones from an A2 or lupo that way still get all the electric and heating etc and the car still looks fairly oem. Some of the contraptions on the hyper miler sites would look very strange on the road, but if fuel keeps increasing then I think it will become more common.
I am hoping to get to 50 whilst retaining the stock look )sub stock in this case as bits are going to be coming off :D) 6th gear and final drive mod is what I am awaiting prices for. Or someone's thoughts on drivability with a complete o2m diesel box swap?
Link to comment
Share on other sites
If you get a chance when mine up and running again you can try the diesel box
It is poss and the gear alone in not that expensive its the cost of removing box stripping etc would cost more than you would gain IMO
So my box is out so going to take end cover off and have a look on Monday ;-)
Link to comment
Just a thought... But flat sheet is not as aerodynamic as the original belly pan...
More hard-wearing definitely but less aerodynamic.
Reason being the uprated belly pans come with a kind of golf-ball like indentation, which improves laminar air flow.
The golf ball indentations do not improve laminar flow, but introduce turbulance into the flow much earlier than normal. This helps the boundary layer stay attached to the surface rather than separate from the underside and has the effect of reducing drag through removing the very low pressure areas which arise from detached flow
Link to comment
Here's a quick one...
Wheels.
Thinner the better when it comes to mileage...
Wider the wheels, the more rolling resistance as there's more tyre coming into contact with the road.
Just depends how far you want to go with the whole hypermiling thing.
Link to comment
Nice explanation. I did google the golf ball effect but couldn't particularly be bothered to explain - so cheers ;)
Link to comment
wheels already changed to Audi 15" pepperpots with 195/65/15 winters so they are
Narrower
Lighter
Higher Silica Compound
Lower Rolling Resistance
Higher Pressure
got to get around to fitting the under tray as it arrived yesterday. Also need to remove mudguards and blank some of the grills.
Link to comment
Cheers Clive that would be a big help, just need to know how well 1st copes as once I am rolling I can manage most things. It is never going to be used to Tow so as long as it can manage a good hill start then I will be OK as future plans include BT or Hybrid, possible 1.9/2.0 kit just going to be more of an evolution than a project :D
Link to comment
Well you know where to come when you want bt conversion ;-)
dude, he is detuning...he will want a smaller turbo conversion..not a BT conversion;>
Link to comment
Who said anything about detuning? No no no not I dear sirs. :D
My whole tuning journey has been to uprate what breaks. Hence the o2m questions as the o2a was replaced a couple of xmases ago when it went pop. As I am at nearly 150k on the original turbo I think it may be on the cards, eventually :D
Link to comment
... o2a ...
shirley, you should had an o2j in it ?
Consider you're thinking of playing with gears, should have kept the old box and converted that to 6spd
much lighter setup - 14 - 15Kg - allegedly
If you thinking of changing gears, you ideally need to think about stripping the lot
Go for a 5spd vrs setup + diesel 6th
Remember you need to factor in the cost of the front peloquin diff
If you mess with gears and don't fit one, I'll come and beat you with a cold wet haddock smiley-taunt006.gif
Link to comment
Nope! They have been lightened so its a performance mod :D
are they smaller? ie the brake surface area? if they are...its a detune :rofl:
Link to comment
  • 9 months later...
Been a while since I updated this one. But the madness continues ;P
Mud guards are off (four of them as it is an elegance), and kind of chopped up the back ones to make tyre spoilers(ish).
Also had a play with using tape to block front vents. But had some overheating issues caused by a fuse so removed it again.
Need some tyres so looking for recommendations for the best low rolling resistance, four seasons or winters in 195/65/15
Also need to look seriously at smoothing out the rear underside and exit but doubting my fabrication abilities :D
Link to comment
I know that some cars can get up to 20% improvement from smoothing underneath with the rear bumper being the biggest problem as it catches the air like a parachute. Having looked under the skip the rear is really bad shape and like clive says would benefit from a nice diffuser. Biggest problem is trying to make something durable and cheap. four poster ramp would help.
Link to comment
  • 2 months later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
