• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Stop /start technology
Sign in to follow this
Followers 0
38 posts in this topic
I've been asked the question on another general forum I frequent, if the battery suffers on account of the engine being started vastly more frequently, thus leading to a much shortwer working life?
I replied that I wouldn't have thought so, but upon thinking about it, then yes, I suppose it will.
What do you lot reckon, and will the high cost of more frequent battery changes wipe out any fuel saving costs?
I was pointed to this interesting link on s & s systems too btw....
[url="http://www.thetruthaboutcars.com/2011/06/the-shocking-truth-about-start-stop-systems/"]http://www.thetruthaboutcars.com/2011/06/the-shocking-truth-about-start-stop-systems/[/url]
Share this post
Link to post
Share on other sites
reckon frequent drain of the battery is bound to have an adverse effect - also wear and tear on the starter motor and fly wheel
Share this post
Link to post
From what I gather, the artery is an upgraded version of the non start stop car and should cope adequately.
Likewise, the starter motor is also a more robust unit.
No idea about the flywheel but I guess that it will have been looked at by the designers/engineers.
Share this post
Link to post
Fifth gear did a test of a megane with stop start, fuel economy was increased by approx 10% but after sitting at road work traffic lights for 2 minutes the car restarted itself because battery was getting too low running the electrics etc.
Cant imagine it will do the engines any long term good, increased wear to starter etc. I would have thought firing a closed cylinder rather than starter motor would be a better way to start back up
Share this post
Link to post
From what I've read about it, there are 3 ways of starting the engine:
1: Conventionally with an uprated starter motor
2: Using a starter motor that is in constant mesh with the engine
3: Which I think is the clever way, on a petrol engine stopping the engine at an exact position whereby a squirt of petrol and spark will start the engine.
This technology serves a purpose in which it gives the car good emissions and fuel economy results, fine when the car is under warranty, but it could render a car uneconomical to repair in later life, leading to earlier replacement and the associated emissions with making a new car.
Share this post
Link to post
[quote name='Rob 4x4' timestamp='1357325335' post='3074568']
[/quote]
Yup it won't shut off if battery is too low, or drain too high due to things like ac being on full.
Share this post
Link to post
Uprated battery, starter, charge state monitoring and in some cars, smart charging regime all contribute to the system. In these cars, the battery is larger in my experience and is well looked after. My Mini Cooper D had the stop start system and I had no issues with battery or starting system in 153,000 miles.
Chris
Share this post
Link to post
[quote name='gadgetman' timestamp='1357330455' post='3074727']
[/quote]
In the citigo, the A/C, heated seats etc shut off when the engine is not running under start stop conditions.
The car has to fit various parameters before the start stop will activate.
For example: engine up to temp.
Share this post
Link to post
Tiff Needell did an experiment in a Renault Megane on Fifth Gear recently (series 21, episode 8).
Fast forward to 20 minutes in the see it here...
[media]http://www.youtube.com/watch?v=Ydf77bz1HLk[/media]
It works, but you've got to spend most of your time in stop/start traffic to see the benefits.
Share this post
Link to post
[quote name='silver1011' timestamp='1357382854' post='3075395']
[/quote]
really?!
2 people like this
Share this post
Link to post
Environmentally pandering claptrap like so much other stuff these days.
Share this post
Link to post
[quote name='andypandypoos' timestamp='1357388967' post='3075523']
really?!
[/quote]
You know what I mean!
If the bulk of your mileage is motorway rather than urban then you aren't going to see the benefit.
Share this post
Link to post
Batteries for Stop / Start are nearly twice as much as a Standard battery
Share this post
Link to post
[quote name='budfox' timestamp='1357393153' post='3075600']
[/quote]
Saves me somewhere between two and three hundred quid a year, which i can spend on fuel for my non eco car.
Chris
2 people like this
Share this post
Link to post
Stop/Start batteries are differant to your average car battery and are designed to cope with the drain from the starter motor,
The battery is constantly monitored by sensors to how much life it has in it, volvos have to be 70% charged for stop start to work and if there is to much current been pulled or weathers to cold it won't stop,
TBH its a pain as for mr rep its fine as the cars used regular but for the oaps etc who just use car to go to shops and back twice a week then wonder why it doesn't work
Share this post
Link to post
I sat behind a car with stop start recently in a traffic jam.
Although I've never driven one I'd imagine it would get on
my t1ts very quickly. The short pause before this one could move away
would become very trying if it was my car.
Share this post
Link to post
If you don't drive in an urban area it's just added weight. SWMBOs BMW has it and we see the engine stop maybe once a month. We just don't drive on roads that make use of it.
Share this post
Link to post
[quote name='grr666' timestamp='1357466503' post='3076806']
[/quote]
The sharan starts within a second. As normal depends how quickly the driver reacts.
I will turn it off when creeping along as yes that does get boring quickly. Blurb says should be stationary for min 20 seconds otherwise you should turn off (in my case else it eats adblue)
Share this post
Link to post
Had it on a hire car and staff shuttle, (A class merc and ford galaxy). Didnt find it too annoying in either case tbh. It only turned off if I was in neutral and foot off the clutch, so that was only times when I would be sat for more than a few seconds anyway. Soon as I touched the clutch it sprang back into life before i`d even got it into gear, so no delay pulling away for me.
Share this post
Link to post
My dads land rover has stop/start on it and even when i am the passenger it annoys me. It stops the windscreen wipers when stationary so everything becomes blurry with all the water on the screen and it just unnerves me every time it stops by its self.
It annoys him as well because every time he gets in he turns it off, but even that would annoy me. Every time you start the car you have got to press a button to get the car to behave the way you want it to.
I know that the landy has a more robust starter motor than those not fitted with stop/start and it also has a bigger battery as well.
Share this post
Link to post
Every start stop system I've seen you dip the clutch or on an auto a brake /accelerator tap
Share this post
Link to post
I've experienced it on a manual Volvo, where I actually didn't mind it (handbrake on and neutral). I later drove a DSG Scirroco with it and I very quickly looked for how to turn it off as it kept cutting the engine at junctions just as I was about to go. Does a diesel really use so much fuel on idle that its worth turning off the engine for what must be 30 seconds in a 30 minute drive?
Share this post
Link to post
Must admit, my system is pretty low tech., but I use my hand to turn the key if I consider I'm going to be stopped for more than 20 seconds.
Share this post
Link to post
[/quote]
Mazda actually did that on one of their engines. So no starter motor was required to restart. The engine stopped in a certain position so that all was required was a spark and it fired up again. Obviously wouldn't work with a diesel though.
[quote name='Mr Ree' timestamp='1357548082' post='3078359']
[/quote]
I used to do that up until we started getting hot starting issues and it would take a good 5 seconds to turn over and start! lol
This also puts more wear on the non-stop start battery and starter.
Stop-start will only work if the battery is above a certain level. You may shut the engine off and not know that the battery is fairly low and put undue strain on it.
Phil
Share this post
Link to post
[quote name='fordfan' timestamp='1357326226' post='3074599']
[/quote]
That's what happens on Toyotas with the stop and start on them. Plus they get batteries designed for stop start as well. There are fuel saving benefits, not vastly but there are. Plus you get lower emissions so can get cheaper road tax too.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
