• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
removing steering wheel?
Sign in to follow this
Followers 0
9 posts in this topic
i have just bought a momo 280mm team wheel and was wondering if anyone has removed there wheel as air bag needs removing anyone done this and how easy is it to do thanks
Share this post
Link to post
Share on other sites
If its anything like the octavia its easy. Done it loads of times.
The airbag has clips that you access via two holes in the rear of the wheel when you turn the wheel 90 degreed. poke a flat blade in and lever outwards. Close your eyes and picture what you can feel through the screwdriver. Its easy when you know how. Then there is a connector to pop off the airbag. You should disconnect the battery really, i did to begin with but then did it without.
Then a Spline bolt and voila. Careful with the indicator reset and steering lock thingy, mark it or i take photographs.
Share this post
Link to post
Yep as the Octavia. Pop the wheel off, undo the nut and swap over. Make sure you have the right boss kit, MOMO have been supplying the wrong kit and their customer service is awful. Once done you'll need to clear the airbag light with vagcom iirc.
Share this post
Link to post
Follow the cruise control retrofit guide, it deals with wheel removal, airbag should be as per Octavia/Polo.
Share this post
Link to post
Iirc... Vw say removing the battery at least 20 minutes before removing/altering any airbags.
I've also seen them removed with the battery still attached.
And I've also... Been told the story from a guy at Mercedes when an airbag went off when he was leaning over trying to remove the bolt or somthing, airbag went off, hit his neck and killed him. Don't know how true it is but always best to watch what your doing!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
