Top boost pipe replacement DIY :)
Recommended Posts
Hi Carl. It's Aqib Iqbal. I was just wondering that you know the 60mm to 51mm 90 degrees silicone pipe. Is there another couplings which goes into the EGR. Is that type D by any chance because I got abit confused reading yours. I thought there's only one coupling that goes into the cooler which is type A am assuming.
Link to comment
Share on other sites
yeah 45deg will work fine
I got swagged ends, will this be enough.. cars remapped to 170
got the bends from ash, and 4x Tbolt clamps for top and bottom.
I think i will need to sort the bottom 90 degree fitting, also ...
Edited by FromTheDarkness
Link to comment
After i done my top boost pipe and seeing how bad my bottom one was i decided to make my own bottom one up here's a few pictures of how it looks
these pictures where taken while i was making sure it all fitted ok :)
Ive been struggling with this for half a day, no way my 90deg elbows, and 90 deg pipe will fit, there is not enough lengh, impossible.. how ever ive managed to do it with 45deg pipe, it does bring it up higher, cant finnish it as i only had 59 -60 t clamps >< thought i had 60-63, got to wait till friday now damit... and i have to order another 45deg pipe as i used the top one!!
Your 90 pipe must have longer legs than 150mm ,,,
Link to comment
I don't know the exact size of the metal 90 pipe I'll see if I can find out the size if that's going to help
Its a issue to need legs longer than 150, 150 is the standard size, i cant find any 90 degree bend with longer legs, another option to all this might be to use silicon pipe with the silicon pipe couplings that ash do ?
Link to comment
I didn't buy my metal pipe my old man got it from his work. We just cut it down to make it fit. You could buy the couplers I didn't do that as I was trying to keep the cost down. I've bought a front mount now so will be putting that on when the weather's better
Link to comment
first dibs on that 90 pipe when you do :P
Link to comment
I've got the correct pipe 70° angle with couplings, just need whatever colour silicone bends you want.
Would fit stock with egr or without.
Will be getting rid in a few weeks.
Its the bottom we are on about, 45 degree/ 70 degree 150mm legs (all ebays sells it) easy to sort the top out. But the bottom on the other hand requires longer legs than 150mm, and i cant find a 90 degree with 200- 250 legs anywhere, I have managed to get a 45 degree on the bottom, but its right on the ends, and a bit close to the aux belt for my liking, not sure how much vibrations when running but its really close.
lies i just found this, i bet its too long lol .. http://www.ebay.co.uk/itm/330893766818?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Link to comment
would this work?
- 45 degree elbow
- 57mm external diameter
http://www.ebay.com/itm/190886048856?rmvSB=true
This is what ive ive tried but 51mm, the problem is the leg length, the silicon hose is right on the edge, so i cant recommend this long term. You want enough silicon hose on the leg to get 2x t clamps on, to ensure it doesnt blow off, with the 150mm leg length you have linked its not possible, also the 45 degree @ 51 is very close to the aux belt, add another 6mm you are probably going to be touching it ><
Link to comment
How much you after posted mate.
Link to comment
  • 4 weeks later...
What type of clips are you using to secure your pipes together mate?
Link to comment
Has anyone successfully done the lower boost hoses yet with parts from e-bay?
Need to get round to doing mine at some point just don't want to go ordering the wrong parts for the job!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
