2012 Elegance TSI A5
I have a strange noise coming from the passanger side dash area. This is present under all conditions once the ignition is on. Based on replys to other postings it might be fixed by recalibration of the Climatronic, but I do not know which buttons to press, or under what conditions! The Climatronic controls are shown on page 90/91 of the Octavia II facelift owners manual.
Can anyone please help?
Ignition on engine off. Hold AC and max I believe until the lights start to flash.
Adam
Adamal,
Thank you for the suggestion, but after several attempts I have concluded that it does not work.
Everyone,
Are there any other combinations to try?
Thank you
With the ignition on but the engine off, hold down the ECON and the bottom left of the four oblong buttons for airflow.
That's the usual recalibration method
The controls are only as follows,
windscreen defrost
air to windscreen
air to head
air to footwell
recirc
rear window
AUTO
OFF
Blower speed
Dual
A/C
LH temp
RH temp
Please which of teh above should I use?
