• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Upgrading alternator
Sign in to follow this
Followers 0
8 posts in this topic
Heyup,
Want to look into upgrading my alternator, but don't know where to go.
Mainly as I'm putting quite a lot of amp/bass items in the boot... and not sure if the normal alternator will be too happy about it!
Advice?
Share this post
Link to post
Share on other sites
From 2004 onwards, the diesels have either a 90 or a 120 Amp alternator, matched to a 44 or 80 Ah battery.
If you've got the 90, I'd guess it would be an easy upgrade to the 120, getting the bigger battery at the same time.
Share this post
Link to post
Is there a way to tell which I have?
I know the battery was replaced at one point in its life.
Share this post
Link to post
Sorry Volf, but I need to correct my first post above.
Just checked my mk2FL 1.9 TDI 2009 Vehicle Data Plate 'Optional Equipment' codes: I've got a140A alternator ('8GU'), and 60Ah battery ('JON'). So much for the standard spec! :think:
I guess it just depends on what was lying around handy in the parts bin when the car was built!
Look at the end of the alternator away from the drive pulley, where there is a plastic cover that goes over the brushes and regulator gubbins. There will either be a small plate riveted to it, or numbers stamped on the cover, that say something like '14V 120A'.
Share this post
Link to post
Ahh, I've just had a look (After cleaning it!) And it's a 140A :)
Thanks!
Share this post
Link to post
Right on, Volf - won't need better than that.
Share this post
Link to post
My '12 1.6CRD has a 61Ah battery (don't know the alternator).
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
