GTB2260VK with vacuum conversion and flange fully rebuild and balaced for 1.9/2.0TDI
XMANTURBOS
Recommended Posts
what sort of power do you get with a 2260 ? and would you be able to supply manifold as well so basically all i have to do is fit it ?
cheers
well it depends on your engine condition, supporting mods and tuner skills.... stock PD130 injectors are good for around 230-250bhp It's not direct fit you will need to readjust downpipe, weld dp flange, fit new boost pipes, oil feed, oil drian, adjust VNT etc...
Link to comment
Share on other sites
sorry to be a pain but could anyone on here list all stuff i would need maybe a rough price and were to get stuff
cheers
well here is a list of what I can supply:
dp flange £20
braided oil feed £40
DIY oil return extension £15
EGR delete (if you want one) £50
Gaskets, oil ad oil filter you can source from dealers, silicon boost pipes and clamps are available from Darkside or there are plenty on ebay
Link to comment
WOW! Impressive, especially for what is potentially around £800 worth of bits including mapping!
Just wondering, alot of cars on DD have PU filled gear linkage ends. Anyone any idea what they have done, and what bits have been filled and the potential benefit?
Edited by amk2vr6
Link to comment
ok since there is so many people interested in the turbos which aren't back until September maybe there will be someone interested in the brake caliper carriers for 312mm upgrades (from 288mm ATE 54 brakes) ? £70 + delivery for the pair:
sand blasted and powder coated in red (there will be some paint chips here an there due to shipping and handling )
Just wondering, will these work with standard OCTY II VRS Calipers and 312mm discs?
Link to comment
Just received my gtb2260vk from xman, quick, easy and well packaged. He's been nothing but help for the last month helping me make my choice and giving me options and advice, highly recommend
Link to comment
Hi xman750, so I've got a blt fabia! I'm after 2260 turbo! But what else do I need to do and what else do I need to buy along with the turbo to bolt it on the car
Many thanks nick
2.75-3" downpipe
boost pipes
exhaust manifold gaskets
new oil, oil filter etc...
stronger clutch would be recommended as well as 312mm front brakes
What I can supply is:
GTB2260vk turbo welded onto stock 1.9TDI manifold £650
dp flange £20
dp gasket £5
DIY oil return extension kit £15
4bar MAP sensor £40
EGR delete kit £50
Here are some pics of GTB1756vk fitted onto Fabia ASZ:
http://postimg.org/gallery/6xhwu4qo/
fitting GTB22 will be pretty much identical
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
